Question about KitchenAid KUDC25CH Dishwasher
Hi, During the Soak & Scrub cycle I notice
Hi, During the Soak & Scrub cycle I notice that on the third wash when the detergent dispenser door open the unit does not fill with water but just runs the cyle without water and although the cycle completes it has just left the detergent in the unit. This also seems to happen on other cycles where the water does not fill. It seems like if I let the machine sit for a while and then restart the water then fills. Any thoughts on what to do? Thanks, Dean
  • 76 Answers
SOURCE: Bosch Aquasensor Detergent Dispenser door wont open during cycle
Behind the dispensor door there is a small selanoid you will need to replace this, test to see if its open circuit, alternatively you can just place the detergent in side the machine before you put it on a wash cycle is this would have the same effect. the only cycle you can not do this on is the one with the prewash, I think its number 1.
Posted on Nov 18, 2007
  • 5911 Answers
SOURCE: Detergent Fill Dispenser
The dispenser is usually controlled by an actuator of some type. This can consist of a small electric wax motor, switch or mechanical assembly. Some dispensers come equipped with an actuator as one complete assembly, while others have separate components that can be purchased separately. I would need your complete model number (located somewhere along to door opening) to be sure what type you have. I can locate a part number for you and give you some guidance on how to make the repairs yourself, if you wish to pursue this on your own and avoid the cost of a repairman. Post back with comments and let me know. I hope this helps you.
Posted on Jan 28, 2008
  • 86 Answers
SOURCE: tablet drawer,dispenser wont open at all
Hi, well you we need to check the ribbon cable in the door lining to make sure that none of the cables have been broken with the movement of the door. If they are fine then you should replace the dispenser unit if you are getting 240v to the dispenser solinoid.
Get back if you have further problems...................?
Posted on Mar 07, 2009
SOURCE: Bosch diswasher detergent dispenser doesn't open during wash cycl
I've been told we can replace the dispenser. See Part AP2834000
Posted on Mar 31, 2009
  • 111 Answers
SOURCE: Dishwasher Detergent Dispenser not opening
An automatic dishwashermag-glass_10x10.gif detergent dispenser door can become stuck for a few different reasons. Some problems are easy to fix, while some require more work. Repairs are basically the same no matter what brand of automatic dishwasher you have, although specific parts might be required. Fortunately, even if the detergent dispenser needs to be replaced, the problem is not an emergency. The dishwasher will clean dishes fine even with a stuck detergent dispenser.
    Fixing a Stuck Automatic Dishwasher Detergent Dispenser
  1. Step 1 Move the basket that holds silverware as far from the detergent dispenser as possible, or make sure no tall items are blocking the dispenser. Also, keep other items such as plates and pans away from the dispenser. Anything that winds up touching the dispenser during the wash cycle can cause the dispenser door to stay closed. Run the dishwasher to see if this solves the problem.
  2. Step 2 Remove the front door panel according to your instruction manual, or find the manufacturer's instructions online, which will probably be in a PDF file. The panel is typically held on by 6 to 8 screws along the edge, which you can see when the door is open. With most models, you won't need to remove the screws at the bottom of the door, which are part of the hinge assembly.
  3. Step 3 Clean the detergent dispenser thoroughly from the inside of the dishwasher and the exterior side as well. Accumulated detergent and other material can interfere with the spring mechanism or halt the pivot action of the door. Use very hot water and a micro-sized brush. You also can use a mix of hot water and vinegar.
  4. Step 4 Most dispensers have a bimetallic strip or switch, attached by screws, which triggers the door release. With the front door panel removed, locate the switch, and push on it gently with a screwdriver until the dispenser door opens. You might simply need to adjust the alignment of the switch.
  5. Step 5 Purchase a new switch if re-aligning the old one does not fix the problem. Typically, these switches cost under $10. See Resources for a link to different manufacturers where you can buy the part.
  6. Step 6 Label the two wires connected to the switch so you can correctly reconnect them afterward, and then remove them from the terminals by holding the slip-on connectors --- not the wires --- and pulling firmly. Use a pair of needle-nosed pliers for a better grip. Then remove the switch from the dispenser by removing the screws holding it in place. Connect the wires to the terminals of the new switch, and attach the new switch to the detergent dispenser. Replace the door panel.
  7. Step 7 Run the dishwasher again to see if the switch replacement has done the trick. If not, decide whether to replace the entire dispenser according to the manufacturer's instructions, or call a repair technician.
Posted on Nov 14, 2009
LG Inverter Direct Drive 7.5kg Front loader WD12020D
purchase a couple of washing machine cleaners from a local supermarket or homeware store. there will be on the console two buttons with a * next to them, turn the machine on and press both these buttons. the machine will display "tcl" normally, insert 1 cleaner into the drawer where detergent goes and press start. run a couple of times to make sure it has all flushed through
Apr 10, 2014 | Washing Machines
My dishwasher is not cleaning dishes well
A dishwasher may clean poorly for a number of different reasons. Before replacing parts or looking for a fault I suggest going through the following checklist:
  • Make sure you are not using a rinse only cycle, test using Hi Temp Wash cycle and Hi Scrub.
  • Check that you are using proper detergent, as suggested in the manual.
  • Make sure you are using rinse aid.
  • Make sure that dishes and pans are correctly positioned in the baskets.
  • Check if stains go away when you soak the glasses in vinegar. In that case the problem is hard water. Correct the amount of detergent as from manual.
  • Check that the arms are free to rotate.
  • Check for leaks in the duct to the upper spray arms, make sure that the upper spray arm is well mounted.
  • Make sure that incoming water from the house has pressure and that hot water has temperature specified in manual (e.g 120F-50C).
  • Check for food obstruction in the drain or disposer.
  • Check that the drain hose at the back is not kinked.
  • Check that the machine is completing the cycle.
  • Try running a light cycle with both sides of the detergent cup filled with soda or Jet Cleaner product.
If none of the above is the problem, then improper cleaning may be caused by a faulty part. Parts that may result in poor cleaning if faulty are:
Accumulator Filter connected to pump
  • Drain hose, duct and drain lines
  • Detergent release system.
  • Spray arms.
  • Spray arm ducts and flappers.
  • Seal and Chopper Kit (if installed)
  • Wash Impeller pump.
Dec 11, 2011 | Dishwashers
The fabric softner is not draining during the cycle
Normally caused by undissolved soap residue. Switch off machine from mains, Remove detergent drawer from washing machine, there might be a small plastic clip that need to be levered by hand before the drawer can come out completely. Soak detergent drawer in a tub of water, rinse under tap and wash thoroughly until all soap residue has been washed away. Replace drawer.
Jan 15, 2011 | Frigidaire ATF6000ES Front Load Washer
How do i get all the dog hair out of maytag front loaders after i wash my clothers theres still dog hair on them & yes i clean the filters
Make sure you are using the proper amount of "HE" detergant based on our water hardness. Soil and pet hair are suspended in the wash engymes during the was cycle to be taken away during the drain cycle. Use of a non "HE" detergant will produce an over sudsing condition and soil will be suspended in the suds and redeposit on the garments and inner basket during the drain cycle. Using a lesser amount of non "HE" detergant will provide an insufficient amount of wash engymes and also give you the condition you are experiencing. Try using a combination of a granular "HE detergant added directly to the load of clothes along with a liquid fabric softner added to the dispensor. This should help you out. Of course shaking out the garments outdoors that have heavy deposits of pet hair would help as well.
Nov 22, 2010 | Maytag EPIC MFW9700S Front Load Washer
Maytag a112 manual on how to add bleach AND fabric softener
Choosing Your Detergent, Bleach, and Fabric Softener..
Learn what the different items you need to wash your laundry.
Liquid Laundry Detergent and Fabric Softeners
When using liquid laundry detergent, you do not want to poor it directly on your laundry. The dyes in the liquid laundry soap could stain your clothing. You will want to start your washing machine and add the liquid laundry soap while the water is filling the washing machine.
You then can add your laundry once you have about and eighth of the washing machine tub filled. This will ensure your laundry doesn't become stained by the detergent. You should only add the amount that is poured into the cup to the fill line. When you add more, you could find yourself wading through mounds of bubbles overflowing from your washing machine.
The same reasoning applies to liquid fabric softeners. However, liquid fabric softeners are added to the washing cycle after the initial washing cycle is finished. You will want to add the fabric softener once the washing machine has filled with water and started to agitate. This keeps the fabric softener from touching the laundry and will work it into your clothing better.
Powdered Laundry Detergent
You will want to add one cup of loose laundry detergent to your washing machine in the same manner you would do the liquid laundry detergent. By doing this, the powdered laundry detergent will dissolve easier.
When adding bleach to your laundry, there is a small triangular cup in the corner of your washing machine. By adding one cup of bleach into that dispenser, the bleach will be added to the laundry at a precise time during the wash cycle.
Setting Your Washing Machine
Most washing machines have three or four cycles. For instance, the Maytag Washer I have has four cycles, regular, permanent press, delicate, and soak.
Regular Washing Cycle
The regular cycle is used for the following types of clothes and other apparel:
• Jeans
• Towels
• Blankets
• Sheets
• Quilts
• Bedspreads
The soil types for this cycle are heavy, normal, and light. This means clothes or other articles that are lightly too heavily soiled should be washed in this cycle. This is due to the washing cycles can be set from a minimum of eight to fourteen minutes maximum. You can use all three of the water temperatures in this cycle.
1Permanent Press Washing Cycle
The permanent press washing cycle is used on the clothes that may or may not need to be ironed.
Such as:
• Blouses
• Shirts
• T-shirts
• Under garments. This would be your unmentionables and socks.
• Jackets
• Sheets
• Baby Clothing
The soil types for this wash cycle are normal and light. The washing times for the permanent press cycle are six minutes to ten minutes. You can use all three washing temperature modes for this cycle as well.
Delicate Washing Cycle
The delicate washing cycle is normally used for sweaters, cotton, silks, and other fabrics that need to be washed with care.
The soil types for the delicate cycle are normal and light. The washing times for the delicate cycle are four and six minutes. It is best to wash your delicate clothes in warm or cold water. Always wash clothing that is more than forty percent cotton in cold water to prevent shrinking.
Soak Washing Cycle
The soak cycle would be used for heavily soiled clothing, such as, football and baseball uniforms. This will help rid the uniforms of caked on mud and grass stains.
You can also use this cycle if you wish to only bleach your white's once a week or once a month with bleach.
Washing Your Laundry
Choose the cycle you need for your laundry. Add the laundry detergent, fabric softener, and bleach (remember regular liquid bleach is for white clothes only.) Start the washing machine and let fill to dissolve the dry detergent or to mix in the liquid detergent.
Now add your clothes to the washing machine. Clothes the lid so the washing machine will continue to wash your clothes.
If you are using a Laundromat, put your clothes in the washing area and shut the lid or door. Add your detergent and other cleaning items in the correct compartments. Put in the correct amount of change so the washer will start.
Thanks for contacting
Nov 13, 2009 | Maytag Washing Machines
Dishes, glasses & silverware have white film, look unclean!
If your dishes or glassware appear with a white film or a white powdery residue or spotted following a complete wash cycle, adjusting the amount or type of detergent you?re using and adjusting your hot water heater?s water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water.
Next, you?ll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, wash the glass with warm water and concentrated dishwasher detergent or a high-phosphate detergent (such as Glass Magic).
If the film comes off, it is probably caused by hard water minerals, improper amounts of detergent, or unsuitable water temperature.
Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn?t anything you can do to make it clear again. But you can avoid future etching by taking these steps:
1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don?t use extra-hot settings such as ?Power Scrub,? and use the ?Energy Saver? dry cycle.
2) Adjust the detergent amount.
3) Don?t pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
A common cause of poor washing results is improper loading?dishes that block or impede the spray arm(s) or prevent the soap dispenser from opening. On the other hand, if your dishwasher has chronic problems with good washing, the problem may not be your dishwasher. A good first step is vary the amount of dishwasher detergent you're using and try switching brands.
Other possibilities: Your home?s water pressure may be too low, your water may be too hard, or the water temperature may not be hot enough.
In order for your dishwasher to fill to the appropriate level, water pressure should be from 20?120 pounds per square inch. If you suspect that your water pressure may be low, turn off all faucets or other users of water (such as washing machines and sprinklers) and then put a half-gallon jug under the kitchen faucet. Turn on the hot water full-blast. If the jug doesn?t fill within 14 seconds, your water pressure may be too low for proper dishwasher operation. Call your city water utility to discuss your options, or avoid drawing water elsewhere in the house or yard during dishwasher cycles.
The right amount of detergent to use depends on how large your load of dishes is and how hard your water is. Hardness is measured in grains of minerals?the more grains per gallon you have, the more detergent you?ll need. If your water has 12 grains or more of hardness, fill both dishwasher soap cups completely with detergent. If that doesn?t work, consider installing a water softener. (For more information, see the article Water Softener Systems.
To check water temperature, hold a meat thermometer under the hot water faucet for two minutes; if it doesn?t register a minimum of 140 degrees F., turn up the temperature dial on your hot water heater. (However, if you have a newer dishwasher that heats the water internally, it isn?t necessary to turn up your hot water heater.)
If your dishwasher has worked fine in the past but suddenly your dishes aren?t clean after the dishwasher completes all cycles, listen to the spray arm(s) spinning inside during the wash cycle. If spinning poorly, wait for the machine to cool down, remove the spray arm(s) by unscrewing the hubcap(s), lifting the arm(s) off, and then cleaning out the spray holes in the spray arm(s) with a stiff piece of wire.
Please rate the solution if you feel I've helped you
May 11, 2009 | GE 24 in. Profile PDW9280JSS Built-in...
Water Softner Dispense wont empty - Kenmore Elite Quiet Pak 4 HE3t
I'm sure you heard a small motor running from time to time during a cycle. That moves an "arm" which sends water to the different chambers during a cycle. Fabric softener is dispensed when water goes to that chamber and dilutes the fabric softener. That chamber then empties by a siphoning action.
If you want to narrow down the problem a little to help trouble shoot -- put some wet rags in and run the Rinse and Spin cycle with some fabric softener. If the softener is not dispensed, then you know that the water isn't being sent to that chamber properly.
If you are intrepid enough to take the top off your washer, do that and see if the arm appears to be moving during a normal cycle. Maybe the arm got dislodged or broken during the move.
If water isn't being diverted properly, I think this calls for a real repair person.
Jan 27, 2008 | Kenmore Elite 45986 Front Load Washer
Open Questions:
See all KitchenAid KUDC25CH Dishwasher Questions
KitchenAid KUDC25CH Dishwasher Logo
35 people viewed this question
Top KitchenAid Dishwashers Experts
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
