Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
XP PASSWORD i JUST GOT BACK FROM IRAQ MY 15 YEAR OLD PUT A PASSWORD ON MY DESK TOP AND FORGOT IT HOW CAN I GET INTO IT NOW
  • Ekse May 11, 2010
    is it a startup password which comes up when you press the power button or in windows when you login?
  • Microsoft Master
  • 13,433 Answers
If the problem is solved please close the thread with a “FixYa” rateing.
Posted on Jun 01, 2008
  • 114 Answers
I have a much smaller solution. it does work. Turn on your PC. keep constantly pressing F8 until a menu pops up. choose safe mode. when it boots up, click administrator. Open the start menu, click control panel, user accounts, then your user. and remove the password. or change it.
    Guru:
  • 1,342 Answers
    President:
  • 2,712 Answers
Thanks to oldnovii for this solution:
As long as you have your Windows XP CD, you can get back into your system using a simple but effective method made possible by a little known access hole in Windows XP.
This method is easy enough for newbies to follow – it doesn’t require using the Recovery Console or any complicated commands. And it’s free - I mention that because you can pay two hundred dollars for an emergency download of Winternals ERD with Locksmith which is a utility for unlocking lost Windows passwords. See here http://www.winternals.com/products/repai...
ERD is an excellent multi purpose product, but you should know it is not a necessary one if you have a healthy system and your sole problem is the inability to logon to Windows due to a forgotten password. Not necessary because you can easily change or wipe out your Administrator password for free during a Windows XP Repair. Here’s how with a step-by-step description of the initial Repair process included for newbie’s.
1. Place your Windows XP CD in your cd-rom and start your computer (it’s assumed here that your XP CD is bootable – as it should be - and that you have your bios set to boot from CD)
2. Keep your eye on the screen messages for booting to your cd Typically, it will be “Press any key to boot from cd”
3. Once you get in, the first screen will indicate that Setup is inspecting your system and loading files.
4. When you get to the Welcome to Setup screen, press ENTER to Setup Windows now
5. The Licensing Agreement comes next - Press F8 to accept it.
6. The next screen is the Setup screen which gives you the option to do a Repair.
It should read something like “If one of the following Windows XP installations is damaged, Setup can try to repair it”
Use the up and down arrow keys to select your XP installation (if you only have one, it should already be selected) and press R to begin the Repair process.
7. Let the Repair run. Setup will now check your disks and then start copying files which can take several minutes.
8. Shortly after the Copying Files stage, you will be required to reboot. (this will happen automatically – you will see a progress bar stating “Your computer will reboot in 15 seconds”
9. During the reboot, do not make the mistake of “pressing any key” to boot from the CD again! Setup will resume automatically with the standard billboard screens and you will notice Installing Windows is highlighted.
10. Keep your eye on the lower left hand side of the screen and when you see the Installing Devices progress bar, press SHIFT + F10. This is the security hole! A command console will now open up giving you the potential for wide access to your system.
11. At the prompt, type NUSRMGR.CPL and press Enter. Voila! You have just gained graphical access to your User Accounts in the Control Panel.
12. Now simply pick the account you need to change and remove or change your password as you prefer. If you want to log on without having to enter your new password, you can type control userpasswords2 at the prompt and choose to log on without being asked for password. After you’ve made your changes close the windows, exit the command box and continue on with the Repair (have your Product key handy).
13. Once the Repair is done, you will be able to log on with your new password (or without a password if you chose not to use one or if you chose not to be asked for a password). Your programs and personalized settings should remain intact.
This security hole allows access to more than just user accounts. You can also access the Registry and Policy Editor, for example. And its gui access with mouse control. Of course, a Product Key will be needed to continue with the Repair after making the changes, but for anyone intent on gaining access to your system, this would be no problem.
And in case you are wondering, NO, you cannot cancel install after making the changes and expect to logon with your new password.
Cancelling will just result in Setup resuming at bootup and your changes will be lost.
Ok, now that your logon problem is fixed, you should make a point to prevent it from ever happening again by creating a Password Reset Disk. This is a floppy disk you can use in the event you ever forget your log on password. It allows you to set a new password.
Here's how to create one if your computer is NOT on a domain:
Go to the Control Panel and open up User Accounts.
Choose your account (under Pick An Account to Change) and under Related Tasks, click "Prevent a forgotten password".
This will initiate a wizard.
Click Next and then insert a blank formatted floppy disk into your A: drive.
Click Next and enter your logon password in the password box.
Click Next to begin the creation of your Password disk.
Once completed, label and save the disk to a safe place
How to Log on to your PC Using Your Password Reset Disk
Start your computer and at the logon screen, click your user name and leave the password box blank or just type in anything. This will bring up a Logon Failure box and you will then see the option to use your Password Reset disk to create a new password. Click it which will initiate the Password Reset wizard. Insert your password reset disk into your floppy drive and follow the wizard which will let you choose a new password to use for your account. Just in case your laptop isn't set to boot from cd, it probably is, you just have to go into the BIOS and make sure sure that the cd is is set to bootable and it is set to boot from cd before your hard drive. Try it with your Win XP cd first and if it doesn't work and you don't know how to go into the bios and set it, add another comment and I'll come back and tell you how to do that. This looks long and involved but it doesn't really take that long. Good Luck.
Or you could try this: Windows Password Recovery
Hope that helps!
Reset my facebook password
Click the "Forgot your password?" link just below the password box on the Facebook sign-in page.
Jul 29, 2014 | Apple Power Mac G4 Desk Top Computer
I Had used my lap top And my desk top computer and my pass word went into both. How do I clear this up. I want my desk top--Don't matter about my lap top.
your Facebook account is tied in to an email address. Go to Facebook.com and under the login boxes there is "Forgot your Password" link. Hit this and then insert your email address and a temporary password will be emailed to you. Use that to log in and then change your password to one that you will remember. Good luck.
Oct 08, 2013 | HP LaserJet 9050 Laser Printer -...
I have a emachine w3619, i let my son use it and he changed the login password and cant remember it. and i cant figure out how to get into my computor. how do i go about getting into my computor
Which Password? Bios Password? Hard Drive Password? Windows Welcome Screen User Logon Password?
Which Operating System? Windows XP? Windows Vista? Windows 7?
OK, if you are running Windows 7, Microsoft tightened security on it so you've got to have a password reset disk which 99% of the people who own laptops with windows 7 fail to do. It should be one of the first things you do when you buy the laptop. Otherwise, you're faced with reinstalling the Operating System or possibly doing a System Recovery.
If you're on Windows XP or Vista try this:
Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see the Safe Mode option. Select SAFE MODE and let the computer boot up. When it gets to the User Login screen it will show the Administrator userid and the userid for which you forgot the password. Sign in as the Administrator (hopefully you didn't put a password on it and forgot it too). Once the desktop appears it will look different, the screen will be darker and the icons bigger, but this is normal for safe mode.
Click Start/Control Panel/User Accounts
When the User Accounts screen opens, click on the userid for which you forgot the password. Select the option to REMOVE PASSWORD.
Reboot your machine.
Apr 28, 2012 | E-Machines eMachines Desktop PC
Can't get to my desk top because my kids put on a password and forgot the word. what do I do?
well if you donno the password
well try opening safe mode with internet
to open safe mood ,,
1.restart the computer and while the computer starts keep pressing f8 or DEL so it shows you an option for openinf with safe mood with internet
and if the safe mood opens without a password fallow the instruction given here
http://www.ehow.com/how_2090927_remove-forgotten-password-windows-xp.html
Nov 21, 2008 | Gateway Computers & Internet
My yahoo mail password is missing,,
hi I'm just to chang my password but i'm forgot it i remmember old password.my old password is q123456 .I want to access my yahoo password that i changed
Sep 30, 2008 | Belkin (F5D5231-4) Router
Password assistance
Following it
1> Restart machine
2> Press F8
3> Goto in safe mode
4> Select Admin a/c
5> If desk top is comming then
6>right click on my computer
7> go to manage
8> System tools >> local user and groups >user >select your name or account >right click >option would be com >set password >next >next > finish
9 >its ok
10> restart machine and check it
Jun 20, 2008 | Dell Microsoft Windows XP Home Edition
Locked out of computer
for windows xp start in safe mode
(when the computer is starting press F8 and choose safe mode)
when safe mode loads go into your control panel and make a new user restart the comuter noramlly and choose that user and then just delete the old one
Jun 06, 2008 | Averatec 3200 Notebook
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
151 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
