Question about Kairak KAI-KRP89S Prep Table 89""L (3)door HL R R ss raised pan chiller wpoly cut brd accepts (12) 13 pans ...
I have a Kairak 102 S....the chiller is freezing everything....the bottom is the correct temp....the bottom has water in it...the drains are clear.. Ice build up around the compressor....all fans are working.
Hi I have a Maytag model MFI2568aes my vegetables and fruit chillers are freezing everything. Chiller control is moved to the top which is cold, levers on chillers are far right. HELP. Gilbert cell...
Air is controlled by the damper located in the top portion of the refer section behind the ice maker assembly. Make sure the damper can open and close. If stuck open, this would allow air to enter all the time and cause freezing. Most likely the issue is found the the damper has failed to close when needed causing freezing. Double check the temperatures to the freezer, it can"t be any lower the -2 degrees, but you can raise it to 2 degrees to see if this corrects your temperature issue. The software was designed to bring in air from the freezer to produce ice first, then migrate to the refer section, if too cold for the freezer it would migrate into the refer causing freezing of veggies and produce.
I hope this information helps.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Nov 16, 2013 | Refrigerators
Solenoid opening is noisey
make sure you have the full voltage that is needed. it will be on the name plate.
Apr 19, 2011 | Kairak KAI-KRP72S Prep Table 72""L (2)door...
PLEASE I NEED YOR HELP KAIRAK COMPANY PHONE #
(800) 833-1106
sample parts list
For parts and manual you gotta go to PARTSTOWN
Tell em Mobi sent ya. LOL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 30, 2010 | Kairak Prep Table 65""L (2)doors HL R ss...
Kairak modle#krp89s condenser fan and comprssor not comin on
It is possible that your main contactor is defective.,This in connected at the compressor motor and can be detached. This is the starter contactor for the motor . Now check the lines of the fan for continuity. If there is voltage coming to the compresor and not working you will check the contactor and then the motor. get help if you are unable but keep this information for getting a good estimate for the work that your technician gives you. Hope you try this out. Good day
Jul 31, 2010 | Kairak KAI-KRP89S Prep Table 89""L (3)door...
Kairak cold table not getting cool
Clean the condenser
check the fan motor. and the relay.
The place for parts is www.Partstown.com
HERE is the parts list.
Aug 30, 2009 | Kairak KAI-KRP48R Prep Table 48""L...
I have water leaking on the floor due to a clogged defrost drain (probably) but I can't locate the drain on either side. Checked under the bottom compartments on both sides. Water is turned off and still...
You have to take everything out of the freezer side and remove back panel. There are 2 white hex screws around where the second shelf normally is. Top half (where fan is) comes off first, then bottom half comes off (it may be stuck if coils are frozen, let defrost a little). You will see stainless steel drain pan below coils. Also could be ice maker water supply or water chiller behind lower drawers on refridge side.
Jul 27, 2009 | Jenn-Air JCD2389G Side by Side...
Water freezing in the bottom of the freezer
Side by side fridge? Use a turkey baster and HOT water to make sure drain is clear. Jetting hot water may unclog drain. Drain has a loop in it under fridge. check to see if water flows through drain. You may need to install a drain heater which connects to defrost heater circuit. If so, suggest that you have a tech correctly diagnose problem. Algea can build up in rubber drain under fridge, so a LITTLE bleach poured into drain will help kill it. Use a tablespoon of bleach.
Jul 24, 2009 | Kenmore 54613 / 54616 Side by Side...
Crosley Servidor WCR17/E K3 Top Shelf and Drain Plug Freezes Over
first thing I would suggest is to flush the drain line. defrost any ice in the drain and then flush warm water thru the line until it flows freelyif  your having a hard time getting the line flushed out you may try using a large syringe or turrkey baster filled with warm water to forcfully flush water thru the line. this will most likely fix the problem.
you didnt mention if food was freezing in the refrig as well as the drain but there may be an off chance that the temperature control could be bad. since this is a manual defrost unit it depends on above freezing temps to help keep frost off of the cooling coil. if the temp control goes bad it will allow sub-freezing temps and possible drain freeze ups. so if the drain continues to freeze you will need to replace the temperature control.
if it comes to that, the control actually has a part number on it since maytag cant find your model number.
message me back if you have any further questions. thx peyton
Jan 30, 2009 | Crosley CRS40 Manual Defrost Compact...
Kairak KAI-KRP89S Prep Table 89""L (3)door HL R R ss raised pan chiller wpoly cut brd accepts (12) 13 pans ... Logo
42 people viewed this question
Top Kairak Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Kairak Refrigerator Expert? Answer questions, earn points and help others
