Question about Eljer Home
If the floor and tub are level do i need to grout under it or does it sit on the pads glued to the bottom.
  • 10,865 Answers
Hello. If it is level you do not need to add grout. Joe
Posted on Oct 12, 2010
Testimonial: "very helpful. I almost grouted a perfectly level tub."
Can plywood be glued to tile floor before laying vinyl planks ??
There are cement based compounds on the market that will allow you to just go over top of your tile floor. Make sure your tile floor is not loose anywhere, clean the floor well and use a patching compound over the existing tiles (this will fill in the grout lines and any uneven areas of the tile). It may take a couple of coats, maybe even 3 to get the floor smooth and level. You should be able to install your vinyl right on top of this and not have the added height of the plywood. If you insist on the plywood you could use a good quality construction adhesive with drilling and installing screws.
Mar 06, 2015 | Building Materials
If floor is level and tub is level do you need to grout it or does it just sit on pads that are on bottom of tub.
No grout needed when it is already level.. 4 Thumbs up please. thanks. Joe
Oct 12, 2010 | Home
Using the Shark steam cleaner on floor with unsealed grout
Yeah it will work fine...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Jul 09, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Washer jerks after spin cycle
most of the time your brake pads are worn down. the pads are glued on the rotor so when they are worn the spot of glue grabs the tub and stops it quickly.instead of the pads slowing it down.
Jan 23, 2010 | KitchenAid KAWS700L Top Load Washer
EMBLEM, ELJER TUB. DO I CEMENT THE NEW TUB INTO THE FLOOR? HOW MUCH CEMENT AND WHAT KIND?
The tub should just sit on the floor, and caulked around to seal out any water. If it as a fiberglass tub, you might want to put some grout under the bottom to help support it.
Apr 29, 2009 | Home
Kenwood Steam mop
The Manufacturer suggests you clean the hose by removing the water tank dammed if u can get it off though.
Nov 26, 2007 | Eureka Enviro Steamer 310 Stick Vacuum
Home Logo
141 people viewed this question
Top Eljer Home Experts
john h
Mike
Donni Steen
Are you an Eljer Home Expert? Answer questions, earn points and help others
