Question about Whirlpool Dryers
When i push the button to start I just get a hummmmm
  • Whirlpool Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley or a faulty motor.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place, some seals are furnished with the cement to glue it in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
Note:The way the belt goes back on is, as the belt comes off the drum has to be doubled (pushed together to form a loop) and goes under the idler pulley then to the motor.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please rate me
Posted on Oct 12, 2010
When should I use the trim tabs
trim tabs on a car or truck . HUMMMMM not sure about that
Jan 07, 2016 | Cars & Trucks
How do i get my 2009 mitsubishi out of park, it is stuck
HUMMMMM seems you need to step/push down on the brake pedal firmly
Feb 25, 2015 | 2009 Mitsubishi Outlander
Wash machine stopped working we hear a hummmmm but it will not work?
did the belt come off , some of them have a fuse on them , the dealers will not tell you that ,take the top cover off and look for the fuse ,
Dec 01, 2014 | Washing Machines
My dryer isn't working
where is the lint filter in the door or on the top of the dryer? You may have something in the blower blocking the motor from turning. but if you hear a hummmmm sound and nothing you have a bad motor. try pushing the start button and turning the drum at the same time. can you jump start it? if yes you have a bad motor.
Sep 21, 2009 | Dryers
F6 error... microwave not working
is the microwave itself working? because same thing happened to us apparently the guy who changed the bulb didnt unplugg the thing first and well it burned a part of the circut board cost us about 90 dollars to fix it.....
Oct 05, 2008 | Roper MHE14XKB Microwave Oven
Will not turn on..
Hi trishis26,
If it was the motor you would still be able to hear it trying to start. The will make a loud hummmmm. Since it is doing nothing you most likely have a bad thermal fuse.
Other possible problems include the door switch, the start switch, the timer, the breaker in your home. If you need more help, just let me know and I will be happy to try to help you figure it out. Good luck.
Mike
Sep 29, 2008 | GE DBSR453EBWW Electric Dryer
Dryers Logo
171 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
