Question about Brother MFC-8460N All-In-One Printer
Line is on paper once printed - Brother MFC-8460N All-In-One Printer
  • 1,110 Answers
A dark line on printed pages that are printed directly from the computer are most likely coming from the Drum Unit.
A dark line seen after making a COPY of a document using the feeder on top, is caused by a dirty scanner glass.
In the first example the fix is to replace the drum unit.
In the 2nd example you need to clean the scanner glass. The glass can be seen by lifting up the automatic feeder on top of the machine and exposing the large original glass. The document feeder glass is the smaller thin strip of glass that is located just to the left of the large glass. Clean this strip well with a cloth/paper towel and a bit of glass cleaner.
Good Luck and Thbak You for using Fixya.
WheatlandServices
Posted on Oct 12, 2010
Prints a line top and left
You may have to do a clean and wick on the cartridges. Please Follow the Below Steps:
Take 2 Paper Towels one should be Damped with Luke Warm Water and the other one should be Dry.
Take the Cartridges out of the Printer and on the bottom of the cartridges where you have the ink coming out of place the Damped Paper Towel on It and Remove it, Do the Same Procedure thrice.
Once thats done, Place the Dry Paper Towel in the same mentioned way. Try to Print.
Good Luck!!!!!!!
Feb 15, 2012 | Epson Stylus Photo R300 InkJet Printer
The printer is not printing receipts and the error indicator is blinking on and off, what is the solution to this?
Flashing (approx. once every second): Out of paper
Flashing (approx. twice every second): Mechanical error (Buzzer sounds once.)
Most likely your paper feed is giving you the error. Remove the current feed, ensure there are no paper jam & insert fresh paper.
If
Mechanical Error :: Quick blinking Buzzer Sounds continuously for a pprox. 1 second :: Reset the Power
switch
Paper End Blinks.:: Buzzer Repeats a short 3-time sound twice at intervals of 0.5 second.:: Set a new paper roll.
Paper Near End Blinks.(Once a second) :: buzzer Repeats a short 3-time sound twice at intervals of 0.5 second.:: Set a new paper roll.
Mechanical Error : If the printer mechanism has a greater load due to a paper jam, etc., the buzzer will sound and the SEL/ERROR lamp will blink to stop the printer mechanism.
Paper End : If the printer has run out of paper, the paper sensor in the paper path near the print head will detect the end of the paper roll, turn on the buzzer, and blink the SEL/ERROR lamp to stop the printer mechanism. If the paper is inserted into the paper path, the paper will be loaded.
Paper Near End : If the paper is running out, the paper near end sensor will be activated to turn on
the buzzer and make the SEL/ERROR lamp blink. Even after the paper near end is detected, a command can be used to print by the specified number of lines. (See a description on the command for setting the number of print lines after paper near end detection)
Finally
Backup Data Clear : When the power is turned on, depending on the SEL switch operation, the
backup data in the input buffer will be cleared according to the flowchart on the next page.
To clear the input buffer, turn on the power while pressing the SEL switch.
The following messages will be printed.
"Clear Data in Buffer"
"Cleared Data in Buffer"
To print the data in the input buffer, simply turn the power on.
The following message is printed and the data in the input buffer is printed.
"Power Down(Data in Buffer)
Dec 13, 2010 | Citizen iDP-3550 Matrix Printer
Cannot empty the print que print jobs on IMac status is Deleted, except for last line which says "printing", but it is not printing
This is most likely because an error with the printer is making it impossible to delete the final print job. The most common error is no paper or a paper jam. Look for blinking lights on the printer and any error messages. Feed more paper if necessary. Once you fix the problem, reset the printer or press the blinking button.
Feb 21, 2010 | Dymo LabelWriter Thermal Printer
Our Brother HL-5140 is not printing. It doesn't
Replace the paper pcik-up rolly assembly. MAKE SURE TO get a good look at how the existing one is installed before removing it. It needs a little tweeking to get the new one in and everything lined up correctly.
Also replace the separation page on the paper tray itself.
Look for part number PF-1 Kit or OEM PART #: LJ7920001
The only diagrams I could find on-line of the inside of the printer I found by searching for "brother pl-prn067". Look at pages 8-9.
Dec 09, 2009 | Brother HL 5140 Laser Printer
I have an Epson R1800 and when I load Roll 13X19 matte media and try to print I either get a "jammed media" message or the printer trys to print without feeding the media.
I had a similar problem trying to print epson pro canvas. I finally learned the "trick". First I generally cut an appropriately sized pice of canvas from the roll. Then I attach a HEADER. This is dome by cutting a piece of 13" wide photo paper in a three inch length (so you have a piece 13" x 3") . Draw a line at 1.5 inches and place some sort of adhesive (I use a double sided tape gun) on one side of the line. Line up the canvas/paper with the line and make sure it sticks to the header.
Now you should be able to manually feed the header/paper into the printer - once the header passes the correcct point the printer will "grab" it a position it correctly for printing.
Hope this helps
nickerjo,
leaningpalmstudio.com
Oct 26, 2009 | Epson Stylus Photo R1800 InkJet Printer
Picture crops strange
HP Photosmart 7550 printers
  1. Ensure that the memory card has been removed from the memory card slot.
  2. Make sure plain white paper is loaded into the In Tray.
  3. On the control panel, press the Menu button. Using the directional arrows, select Clean Cartridges .
  4. Press the OK button.
  5. After confirming that paper is loaded into the paper tray, press the OK button.
  6. Once the level one clean cartridge test page has printed, examine the printed page. If the print is not clear and/or there are lines in the color bars, continue to Step 7. If the print quality is acceptable and there are no flaws with the color bar, select No using the directional arrows, then press OK .
  7. Press OK to print the second level clean cartridge page.
  8. Once the second level clean cartridges test page has printed, examine the printed page. If the print is not clear and/or there are line in the color bars, continue to Step 9. If the print quality is acceptable and there are no flaws with the color bar, select No using the directional arrows, then press OK .
  9. Press OK to print the third level clean cartridge page.
Dec 08, 2008 | HP PhotoSmart 7550 InkJet Printer
Black lines across my printer paper
potential driver error; reload driver. Once reloaded, go through all setup procedures [alignment of print head, etc]. Do not skip steps. The printer utilizes the setup features [user interface] as a calibration which is fundamental to its performance.
Oct 15, 2008 | Epson Aculaser C1100 Printer
Printer is not aligning paper properly.
Please try the following to resolved that issue:
1. Make sure the printer is turned on and the desired tractor is selected (the corresponding tractor arrow should be lit).
2. Open the upper cover.
3. Press the Top of Form button to enter top-of-form mode. The printer beeps once, and the Top of Form light turns on.
4. Use the Micro Feed buttons to feed the paper to the desired top-of-form position. The “A” on the ribbon protector shows you where the bottom edge of your first line of text will print. This position is based on the first printable line of text. If your software inserts a top margin of five lines, your text will actually print five lines below the top-of-form position.
5. Press the Top of Form button again to exit and save your new top-of-form position. Then close the top cover.
Jun 10, 2008 | Epson DFX-9000 Matrix Printer
Multiple Problems Printing
Replace the print head, and all should be just fine.
Jan 06, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Brother MFC-8460N All-In-One Printer Logo
123 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
