Here it is;
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&ved=2ahUKEwjk-43IkbmDAxWWVkEAHYpPBzsQFnoECBEQAQ&url=https%3A%2F%2Fsterilizers.com%2Fmanuals%2FMDT%2FChemiclave-EC-Series-ServiceManual-5500-6000-AfterAdi.pdf&usg=AOvVaw17fp4dQQ4rtdl2qmJv2xVy&opi=89978449
Generally speaking you should only send low frequencies to subs. The highs, while lower in power than the lows, will over time harm the voice coils. The ideal way to do this is to use an external crossover netween the main output and the amp input with the higher range going to a general set of speakers. Send the lows through the second channel of the amp and then to the subs.
In short, while not recommended, yes you can hook them up in parallel.
One side of the amp has failed and repair is NOT DIY. Take it in for servicing. This amp has many components in the power amp and repair is complicated. A failure can lead to 20 components being damaged. Failure to replace all damaged ones can result in immediate failure destroying the replaced ones.
