Question about Frigidaire FWSB5700DS Top Load Washer
I have a frigidaire fwsb34rgs0 top loading machine. It works through the complete cylce ok but when the spin cycle starts and throughout the spin it makes a loud buzzing/vibration sound. It just started doing this. Would that be the transmission or something else possibly?
  • 213 Answers
SOURCE: Frigidaire top-load washer Loud noise during spin
its either the upper spin bearing or lower spin bearing. the upper can be replaced by itself but the lower requires the transmission the be replaced
Posted on Nov 20, 2007
Coldcut
  • 1554 Answers
SOURCE: banging tumbler during spin cycle
Be certain that nothing got under the rubber skirt, pull it back and look /feel under it .
inside the tub are the large wiper arms solid and not come loose.
open the top access panel (3 screws in top rear )
and open the bottom access Panel (3 screws in bottom front)
Dissconnect power .
Look at the springs and arms that attach to the tub are they secure.
is the large stone concreate slabs secure.
move all these items and push at them all secure?
you can run it while open but the bottom has a switch on front right that has to be closed.
look watch listen.
Posted on Feb 27, 2008
  • 156 Answers
SOURCE: Frigidaire FWT647GHS0 Front Load
you have a bad rear bearing in the rear housing the rear housing is a warrenty part for life on the part but there is parts that should be replaced at the same time expereance guy can do it in about 2 3 hours if not chould be a long hard prosses
Posted on Mar 03, 2008
  • 6 Answers
SOURCE: my frigidaire washer model#fwsb34rgs0 stoped
pump not pomping the waterout or yur drians clogged
Posted on Mar 30, 2009
  • 5 Answers
SOURCE: My model #gltr1670aso makes loud noises during spin cycle
Usually this is due to either the drum support breaking or the back bearing being bad-neither easy to fix- or worth it. Try lifting the drum up and down, if it moves up and down they are bad. I see this a lot, and the price of repair isn't worth it. Craig
Posted on Aug 02, 2009
Frigidaire model # GLMV167OAS Makes a loud buzzing noise during the spin cycle. Completes the cycle but clothes are still sopping wet. What to do???????
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 22, 2011 | Frigidaire ATF6000ES Front Load Washer
Kenmore Elite Top Load..Rinse water keeps running in Spin Cycle. Clothes are soaking wet when spin cylce is complete
the fill valve is an electric magnet valve and sounds like it is stuck unplug machine disconnect water lines plug in and when u turn on does it click, if yes then unplug try to slide a long qtip in and if it goes in replace valve
Jul 06, 2009 | Kenmore Elite 45986 Front Load Washer
Washer stopped in the middle of the cycle
sounds like motor if nothing stuck between tubs or in pump ,check these first if ok you have bad timer
Nov 12, 2008 | Kenmore 22422 Top Load Washer
Nov 20, 2007 | Frigidaire FWS833A Top Load Washer
Frigidaire FWSB5700DS Top Load Washer Logo
126 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
