Question about Acer Aspire 5600 Series 5630-6951 Laptop
Dvd writer not reading dvd but reading cd - Acer Aspire 5600 Series 5630-6951 Laptop
  • ahirprem Sep 11, 2008
    I have DVD & CD writer in compaq laptop, read CD writer but not read DVD writer
  • tichworld Sep 30, 2008
    my sony vaio n120g cant read cd can play dvds and cd+rw.pliz help
Throw it out
Posted on Aug 21, 2008
Simply throw it
Posted on Aug 14, 2008
For a cd/dvd dual lens there r 2 lasers & thus 2 pots on the back of the laser lens. If u have problem with running dvd's then only tweak the dvd pot in forward direction a bit.
Tweak the dvd laser via forward rotating the potentiometer (preset). Do not over tweak the laser. You can also use digital multimeter to check the value of potentio/pots meter before & after adjusting it.
If the problem is fixed then u can update the firmware too for latest support.
Else the better way is to visit a technician/engg. or to purchase a new one.
Posted on Jul 03, 2008
  • raman101 Jul 03, 2008
    it's raman101 back here:
    Note: This process is applicable to all cd/dvd laser lens repair.
    Even for gaming consoles like PS1/2, XBOX etc assuming u have already taken the laser lens out of the console casing.
    + Your dvd writer may be a little different in it's design.
    1. First of all, take out ur cd/dvd writer from the pc cabinet.
    2. Open the four screws located on back of ur dvd writer & flip the same screw side outwards.
    3. Move the tray out by pinning in a needle like substance into the small whole available on the front side just below the tray.
    3. Now take out the front cover (on which the dvdrom, rw, disc rewritable, light scribe etc is written) by pressing the two buttons available on sideways of the casing left & right front near front.
    4. To fully take out the dvd tray, u need to concentrate on the 2 pins available on left & right inside where the tray is blocked by them.
    Clean the laser head & assemble the dvd system, it may fix ur problem. Otherwise move on further.
    5. Take out the PCB/PBA(Printed Board Assembly) by unscrewing all the screws available on it & do remember to carefully take out all the ribbon cabels attached to it.
    6. Unscrew the 3/4 screws(all) available on backside of the laser lens assembly (i.e. at the end of the 2 lens rods on which laser lens slides) to take it out.
    ---------Hoping u have carefully detached the laser assembly out of ur dvd system.-----So shall we move on....
    7. Now u need to find out 2 potentiometers available on back of the laser lens.
    look : A round circle/screw with 3 ends, 2 on one side & 1 on other. Basically it is a resistor which changes value on rotating it clockwise & anticlockwise.
    * * 3 ends around the screw.
    For a dvd laser lens i.e. dual lens, the lens assembly is having 2 pots meter.
    potentiometer = pots meter = preset. That we call it.
    8. So u need to erect the laser by increasing it a bit at a time.
    Rotating clockwise means increasing voltage & thus solving ur problem. Remember not to over tweak it.
    For this, take out ur digital multimeter & set it on resistance i.e. in ohm's at 1000/2000 so that it can read higher value's of resistance.
    If u have problem reading only dvd's then only change the value of dvd preset & not of the cd preset.
    Put the two scrobs black&white of the multimeter at the 2 ends of the preset which are located on same side to get a reading in resistance/ohms. Note the reading or u can even mark the starting location if u want to get back at the starting point where u have started from.
    *********Remember not to over tweak the preset.
    Now check out the dvd preset out of the 2 preset available. This cd & dvd may be printed near the preset otherwise u need to check it urself. The preset may be placed at different location's for different model's of the dvd laser lens.
    Tip: If u rotate the cd preset a bit counter clockwise, then neither the cd nor dvd is going to rotate/spin. But counter clockwise rotating the dvd preset means the dvd laser becomes week & no more dvd can be run but cd's can be run.
    ------Hopely u may get success in getting the right preset. If not then do rotate both preset a bit clockwise i.e. 100 or 200 ohm's of resistance at a time.
    A bit means a degree or a gauge of a hair.
    9. Set the whole assembly & run the dvd writer.
    Danger: Not to look at the red laser as it's quite dangerous.....
    + Do increase a bit more & more until u succeed in erecting the laser.
    Remember not to set the dvd/cd laser preset resistance to zero (0) this can damage the laser lens dvd section.
    10. I know this all is not sufficient to u guys, it takes a lot of experience to correct the problem. Not only this i know one of u guys may not even understand my tech. language. Sorry for this :-] But i really want to help all of u for free.
    It is assumed that ur dvd laser lens is having problem & not the other circuit's of the dvd system. The above guide is only for laser erecting.
    How to check if ur PBA Integrated Circuit i.e. ic's is having problem......Put ur finger on all the ic's one by one & check if anyone is more hot/shorted within...... You need to replace it with a new one or from the old dvd writer of same brand. For bthis u need a hot gun (to remove the mounted ic).
    ^^^^^^^^^^^^Check this out:-
    Link to u tube: How to assemble/dissemble a dvd writer:
    part 1: http://www.youtube.com/watch?v=WpmoG5Kpm...
    part 2: http://www.youtube.com/watch?v=wk3E1P8Rp...
    Checkout google, utube, metacafe, torrent, limewire etc to get more information on this topic.
    If ur problem is fixed then plz. do download the latest firmware available on the website of the product u r using. Run a virus scan & flash ur. dvd writer.
    If anyone needs more help then contact me...........Indian....
    +919914822969 (mb.)
    plz. don't blame me if ur dvd writer got crash. Do it at ur own risk.
    or simply refer to a tech or purchase a new one.
    I really like to thank fixya as it provides a tech platform & share user personal reviews.
    My real e-mail address is: raman.msn@hotmail.com
    :)Now,
    Happy guys!!!
Tweak
    Scholar:
  • 119 Answers
That could only constitute to proplems within the writer, possible circuitry or laser malfunction. the best thing is to get it checked by a technician. I assume that you have tried different dvds on your machine because some dvd writers do not recognise certain dvd formatts. thanks
Posted on Jun 01, 2008
  • 114 Answers
There has been lots of problems going on about DVD drives not reading DVD's but reading CD's. So at this point, all i could say is to get a new DVD writer.
2 Suggested Answers
20YrsCompExp
  • 227 Answers
SOURCE: acer extensa 5620 notebook dvd-cd rom doesn't read
go to device manager under System Properties. Locate DVD/CD Drives, expand it, select your drive, right click and then left click on properties, select the General tab and check the state of the device IT SHOULD indicate the device is working properly, if so or if not, select the Driver tab unomstall the driver, reboot, see if Windows will reinstall the driver as it should recognize the device as a new drive. If not return to the device manager and reinstall the driver.
Posted on Mar 28, 2009
Dvd writer not read any cd/dvd for last 3 month..?
1. If still in warranty, return for another
2. Clean read lens (purchase cd lens cleaner)
3. Purchase new drive (preferably a different bland)
Aug 04, 2012 | Samsung SpeedPlus DVD-Writer 20x, Black ...
My samsung dvd writer shown all songs dvd but when we are burn rewritable dvd the matter does not read by my writer dvd shown zero fill only. why please tell me that.
your CD ROM is combo drive which means you can read and write cd but only read dvd you will have to by DVD writer which is normally with all DVD rom
May 01, 2011 | Samsung (SW-208) CD-RW Burner
I bought my SAMSUNG DVD supper writer one year ago . I use Win 7 . It was good up to now . Now , My DVD writer cannot read DVD or CD . I checked plug of DVD writer , my PC told that DVD writer is still...
I would say you need a new CD/DVD. This one appears to have given up. These days, they are not very expensive. var fctb_tool=null; function FCTB_Init_3ebe2b55d0d94800b072c8db741693f5(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_0ef9312c3bb74669a836f0f462a4530a(t) { fctb_tool=t; start(fctb_tool); }
Jan 07, 2011 | Computers & Internet
The writer is not reading
Hi, you can try a cleaning CD as writers are suseptable to dust; if this does'nt work it is probably a faulty laser and you will need to replace the writer.
Jul 05, 2010 | LG GSA-H55N DVD-RAM Burner
This writer read only cd
I had the same problem.
It's the fault of writer .
So, I suggest you to buy a new writer.
Jul 03, 2010 | LG GH22LS40 DVD-RW Burner
MY HP 840i dvd-rw can read CD but can't read DVD
if you have cd writer and dvd rom then change your cd drive with cd/dvd writer because in the case of cd writer and dvd rom it gives error but sometimes the dvd play also but computer freeze from sometime and when we copy data then give us error messages i give you suggest to buy new cd/dvd writer
Jun 29, 2009 | HP Computers & Internet
Cd is not reading by dvd writer but dvd is running smooth
1.when you write on dvd writer always select low speed to write such as 8x or 16x
2. most of the dvd writer do max speed while wrting the Cd or Dvd
3. due to this reason your cd is not reading
4. you can try a new disk write in slow speed,then check with your cd.
Jun 22, 2009 | LG GSA-H42N 18x DVD RW DL IDE Drive...
DVD writer not reading disks
change ide cable 1st ok get back with me thx nick
Feb 03, 2008 | Computers & Internet
Dvd writer for toshiba satellite pro
HP dvd1040i 20x Super Multiformat DVD Writer
Price: $69.99
  Internal drive (double layer)
 Write speed: 8x double layer, 20x DVD±R, 48x CD-R
Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
Read speed: 16x DVD-ROM; 48x CD-ROM
Lightscribe disc-labeling technology
one-year limited warranty....
HP dvd1040e 20x Super Multi DVD Writer
External drive (double layer)
  • •   Write speed: 8x double layer, 20x DVD±R, 48x CD-R
  • •   Rewrite speed: 8x DVD+RW, 6x DVD+RW, 32x CD-RW
  • •   Read speed: 16x DVD-ROM; 48x CD-ROM
  • Lightscribe disc-labeling technology
    Price: 109.99
    These are the best DVD writers....
    Lightscribe technology is where you can burn your pictures on the disc as a label..... This is Hp's latest technology
    Oct 22, 2007 | Computers & Internet
    Acer Aspire 5600 Series 5630-6951 Laptop Logo
    182 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
