Question about Microsoft Windows XP Professional
Could not paste excel sheet on Load Runner Box
I had copied an excel sheet from my local machine and pasted it on Load Runner Box (on different machine) but i the message displayed on Load Runner Box as "no enough memory OR file is read only OR The file may already opened" somthing like this sort.
But the file was not opened and there was enough space available on the machine
the folder in which i was triying to copy the file was read only, i tried to remove read only option for the folder and file in that folder, but i could not as when i opened the same folder next time it was read-only.
Thanks in advance
  • yormaikel Jun 05, 2008
    necesito los driver ati rean
  • sachin dyade May 11, 2010
    which operating system u are using?
Try downloading excel viewer ,,,,on other machine
Posted on Jun 05, 2008
How do you copy and paste one excel spreadsheet to another making sure the headers are lined up correctly.
right-click the sheet you want to copy, select "copy to", then either select the position within the current document, select annother document (needs to be open in the same excel instance) or select "new document". check the box "copy" to copy, leave unchecked to move.
Jan 01, 2016 | Microsoft Excel Computers & Internet
How do I copy an excel sheet into word showing grid lines
Show or hide drawing gridlines Drawing gridlines appear only in Print Layout view.
  • On the View tab, in the Show/Hide group, select the Gridlines check box. " alt="Word Ribbon Image">
Sep 29, 2014 | Dell Computers & Internet
How do i import an excel sheet to suretrak
In Excel create Activity IDs and Descriptions and copy those two columns. While in the Activity ID box in Suretrak (with no activities below) select paste. You should be able to at least input the Activity IDs and Descriptions. I haven't played with pasting Durations, Starts, etc. If the Suretrak columns match your Excel columns, you may be able to paste as much info as desired.
Jun 07, 2010 | Primavera SureTrak Project Manager 3.0 for...
I had data on sheet one and for same the text format on another i want to copy data in the sheet having text format for particular cell reference which is there on first sheet
Try using "Paste Special". Select the data you want to copy. Position your cursor on the new sheet. Select Edit / Paste Special. Try the "Values and number formats". If that doesn't copy all the formatting you want, on the second time select "Formats". I often do this as a two step process: do a normal cut and paste, then go back and do a "Paste special" selecting "Formats" to get the formatting correct.
Jun 26, 2009 | Microsoft Excel for PC
Dear Sir, In case there are atleast 80 files or more having same format containing datas in columns in each file with different figures, I want to merge all file in a single sheet in one shot. Kindly...
If the column names and orders are same across files, then you can directly use the MS Excel's import data function, this will do your job.
Alternatively, if you want to do it manually, import each file in separate excel worksheet using data import wizard or simple copy paste of data (in latter case you have to use Text-to-Col feature of excel), and then manually append all figures (copy-paste in one go) to any external excel sheet.
Then finally, export/save as that external sheet to any filename of your choice.
Hope this helps.
Thanks.
Mar 24, 2009 | Microsoft Excel for PC
Unprotect an Excel sheet
Print or convert it to pdf then you may copy/paste from the pdf to a new unprotected sheet.
Doesnt work for formula.
Feb 18, 2009 | Computers & Internet
Tools protect workbook& sheet
Open the protected sheet... Go to edit and click select all. Go back to edit and click on copy. Open a new excel sheet, go to edit and click on paste. Now you have the copy of the protected sheet without the protection.
Jan 23, 2009 | Steinberg Cubase Studio 4 Upgrade Version...
Copy-paste
it should be
=7/4  or =100/30
and excel will give you a numeric result.
Oct 18, 2008 | Microsoft Excel for PC
Formula
You can copy any selected cell(s), and then in the sheet you want a link in, select 'Paste Special' from the Edit menu, and then choose 'Paste Link.' I have assumed that you're working in Excel, since you mentioned sheets. The pasted link will update any time you open the second sheet with the links in it.
Oct 13, 2007 | Microsoft Office Standard for PC
Microsoft Windows XP Professional Logo
132 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
