Question about Kenmore 22422 Top Load Washer
Kenmore Elite Hi, I have Kenmore Elite which just recently starting to leak from and through behind the holes of the back plate, the hose connection looks okay..The water dripped about 1 cup of water. Any ideas what is the cause?
    Genius:
  • 1,028 Answers
Could be spash over be sure washer is as level as possible
Posted on Jun 02, 2008
Why is water leaking from back of kenmore elite refrigerator?
Also, can be a crack on the plastic hose, close to the inlet water valve.
Aug 16, 2014 | Kenmore Refrigerators
It leaks
where does it leak from,could be drain hose, or pump or connections to and from drain hose and from pump,, look for rusted clamps under neath,,,or holes, also chek waterhose connections,when loking underneath chek for water spots on hoses and pump..
Oct 10, 2012 | Kenmore Elite Oasis 27052 Top Load Washer
Barracuda automatic pool cleaner
try hose into skimmer hole maybe air leak from plate make sure swivel end of hose on cleaner maybe air leak if sticking out of water
Dec 26, 2011 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Periodic water leaking from Kenmore Elite K701
hello Adrian. I am suspicious that the standing drain pipe behind your machine may sometimes over flow. To find out, pack some dry newspaper around the drain hose where it enters the drain line behind the machine. If that newspaper gets wet you will know that the drain is sometimes overflowing. If that is the case, snake that drain or force a garden hose down it and run hot water thru it for ten minutes. J.
Jul 05, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Leak from bottom of connector
If a nail gets inside the pump it can wear a hole in it. I opened my pump and a top to a hanger was in there. It over time rusted and became sharp and wore a hole through right below where the rubber hose gos in. Consequently the water in the bottom of the plastic tub sits there and even though it's not draining water makes it's way through. I used a soldering iron to melt similar plastic. I put a tube in to creat a mold and backer so the plastic simply would not go through, I used the long end and kept rubbing it. It's a thorough bond. I put it back together and no leak. The plastic is simply plastic and not pvc so pvc pipe glue will not work. You can't order that part by itself either, you have to order the whole pump. I still have beeping but found if you turn the dial it figures it self out and only beeps between cycles on the machine rather than through the entire wash/rinse.
May 20, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Got a Kenmore Elite HE3t Front Load washer from my old man, hasn't been used in 5 years... sat in my basement for the first month i lived here unhooked and unused... FINALLY, got a dryer, hook everything...
A burst hose or a broken hose connector clamp most likely. Open the back after disconnecting power. Use bright flashlightto see where its dripping from and confirm the hose-clamp is brokem/ open or a connecting hose is burst. Carry broken hose to hardware store like Rona for a replacement tubing, cut to size and re-instal, voila!
Dec 13, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
My Kenmore (Mod # 665.17842400) dishwasher stopped towards the end of a rinse cycle (dishes were almost clean). A pool of water is in the bottom now and the controls don't come on anymore. I just...
You may have a small leak in drain hose. check the hose when the unit is draining, you may see the leak.
Let us know if you need further clarification.
Thanks for contacting fixya.com
Dec 03, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Washer leaks
When my husband came home he took the washer apart and it was the pump. Small pin hole leak in this glob of gray sealer that seals the two plastic parts together. Just been waiting to fail, I'm sure. Thanks for your help.
May 28, 2009 | Kenmore Elite 45986 Front Load Washer
Tub won't fill with water
You have a bad inlet valve. The valve is behind the hoses, you cant get to it one of two ways. Either through the top by removing the knobs and screws and face plate. or by removing the panel behind the hose
Feb 09, 2009 | Kenmore Elite 45986 Front Load Washer
Water comes out the bottom of washer as fast as it goes in the top
hazy, it's possible it's running out your pump. You need to pull the cabinet off to get a real look at where the leak is coming from. Check out the pics...and post back.
Apr 23, 2007 | Kenmore Elite 20972
Kenmore 22422 Top Load Washer Logo
69 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
