Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Sub zero vacuum condenser
How do I get the grate off the top of refrigerator to vacuum condenser?
  • 828 Answers
Top of grill is held by a spring. Pull out the top and lift the grill to remove. It can then be dropped down out of your way.
Posted on Jun 02, 2008
Need owners manual for a Sub-Zero 695 and maintenance manual
If your trying to remove the grill plate thats located at the top of the machine what you need to do is open both the freezer and the refridgerator doors and look up. There are three vertical phillips head screws that you'll need to remove first. After that you'll be able to pull the grate forward and remove the springs, one on each side that keeps tension on the grate. Once those are removed, the grate will be easy to take off.
Apr 26, 2012 | Sub-Zero 695/S Side by Side Refrigerator
My 650 sub zero keeps alerting me to vacuum condenser even after I do so. What should I do?? My condenser is at the top of the frig.
I have found the users manual for this unit, and that my give you more information. Click HERE
Hope this gives you some relief
Joe
Aug 30, 2011 | Sub-Zero 650 / O Bottom Freezer...
The Vacuum Condenser message has come on. Where is the Condenser in my Sub Zero fridge Problem ?
The condenser is the coil on the outside of the unit that rejects the heat. most Sub zeros I have serviced had top mounted compressors and condenser coils .just find the compressor and the coil. Be careful of the fan. they just want you to check on it
Jun 25, 2011 | Refrigerators
Just had the condenser fan motor replaced on my 550 sub zero refrigerator. I forgot to asked the serviceperson the following questions: Does the fan continously stay on and what is the normal sound of...
Good day,
On models with 2 compressors the condenser fan motor runs 24/7. It must since the compressors run randomly and that motor must be on since it handles both units.
Fan noise is subjective. It itself makes little noise but the blade does. If for example the blade was changed from the nylon style to a metal blade (good idea) then it would be somewhat louder.
If the noise is not objectionable then I would use it as is.
Oct 06, 2010 | Sub-Zero Bottom Freezer Refrigerator
My Sub-Zero side-byside freezer is at 35 degrees and says "vacuum condenser". What does it mean and what can I do?
At the top or bottom of your unit you have a removable panel that covers your compressor and condenser, you should hear a fan, that is your condenser fan, those coils need to be cleaned with a vacuum or dryer brush
Sep 03, 2010 | Sub-Zero Refrigerators
I need to vacuum the condenser in a sub zero,
The condenser coil is located behind the cover on top of the two doors and when you take it off you see the coils that look like a radiator (fins and copper pipes) ,turn of the refrigerator and with a brush and a vacuum clean the coil very carefully and don't push to hard against the fins.
Aug 24, 2009 | Refrigerators
Subzero--Vacuum Condenser Signal Won't Turn Off
The vacuum condenser indicator keeps flashing on and off. I did vacuum the unit, the the indicator lights keeps flashing on and off. How can I reset it and keep it off?
Thanks,
Rob
Aug 22, 2009 | Sub-Zero 650 / O Bottom Freezer...
601R sub zero vacuum condenser notice
Your problem might be serious enough to warrant a repairman's visit. But this was my experience: An official Sub Zero repair company in NYC told me this: If the "vacumm condenser" light keeps flashing after you've opened and cleaned the condenser grill, then either pull out the plug for the Sub Zero refrigerator or turn off the circuit breaker (or fuse) in your house that leads to it, wait for some minutes and then turn back on. It is NOT enough to turn off the unit using its own internal on-off switch - it has to be totally disconnected from the AC. I did so, waited 15 minutes, turned back on, and it worked!! I had vacuumed the condenser grill twice but the "vacuum condenser" light kept flashing AND the refrig would go bonkers if set below 38. Now the flashing warning is off and it's down to 35. Great !!!
Jun 27, 2009 | Sub-Zero 601R
Sub-zero model#3211-rfd, side by side, freezer working fine, but refrigerator not cold enough, alwaus stays 40F, even i turn to the max.
Have you cleaned the coil? Pop the grate off the top of the fridge and vacuum the coil as well as the grate thoroughly.
J
Jul 30, 2008 | Sub-Zero Refrigerators
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
238 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
