I have charged my phlips wireless headphones since 1 p.m. yesterday until 10.30 this morning. I have tried to use them but without success.
I have the ariel, the charging wires, the headphones and a separate adapter with a plug plus a little adapter to link to other equipment.
Could you help me use this product? I am not obviously understanding what does go where other than I think I have charged it correctly as the red
light comes on the headphones.
-   unit has worked ok since xmas now the green light will not go off even after10 hours charging THE BATTERIES CAN BE CHARGED BY AN EXTERNAL/OTHER CHARGER SO THEY SEEM OK RED LIGHstillworks and set transmits on both channels is the internan charger US don
-   Guest
Jun 19, 2008
-   Hi
I have just purchased a set of Philips Wireless Headphones SBC HC8440 and I have been looking on the internet of a manual or better instructions. The instructions that were supplied with the product are just pictures and
they are not very clear.
I am not technically minded and it does not clearly show which lead goes into which socket, I'd hate to blow them up or worse still myself.
Thanks MREED-   mavineire
red usually means its not charged or connected properly there should be a matching led green light that comes on with the manual im reading this is what its stating
you also have to sync the head. with the base unit
Hi there! OK I know it is little late to response but if someone will google it,
might find the solution, they are still selling it though. I just got
my set as a xmas present so here is the way it works..
First plug the batteries into the headset, there is gonna be small
power in it, however you have to charge it. So connect the small
charging cable into the base unit and the headset and make sure the
switch on the head set is off. Green LED light will appear on the base unit. Let it charge for 16 hours. After is charged you can unplug the small charging cable.
OK now how it works.
The base unit needs to be always plugged-in to the electricity
supply. Connect the audio connector from the base to the e.g. TV, PC,
DVD player, mp3 player... After you plug-in the audio connector red LED light will automatically light on the base unit.
There is is two channels what you can use, that's in case if you have
two of the same wireless sets. So if on the base is set to # 1 the
headset needs to be also on # 1. Then if you have second headset choose
channel # 2 on the base and also on the headset # 2, so they are not
crossing each other.
Now press switch on button on the headset and red LED light will appear. There is nothing wrong with the red light. That's just the way it is..
OK that's it. Adjust the volume on the headset and you should be able to listen to the music.. :)
I have 2 sony cd players that I want to hook up too a reseiver.I would like to know which model is...
(More)
I have 2 sony cd players that I want to hook up too a reseiver.I would like to know which model is best cdp 265 or cdp 302\r\nThanks,
Ken
