Question about RCA 25404RE3 Corded Phone
The cord will not stay in the receiver - RCA 25404RE3 Corded Phone
  • 44 Answers
Do you mean the cord between the handset and the phone, or the phone and the wall socket? Either way, has the plastic clip broken off the plug? If so, you will need a replacement cable
Posted on Oct 12, 2010
    Sergeant:
  • 270 Answers
There should be a little clip to retain the cord in the handset. If this clip is gone, the cord needs replacing. This clip is a plastic protrusion on the clear (most of the time) connector to the handset or phone. This clip must be depressed in order to remove the cord. If it has been forced and broke off, it will not longer retain the cord.
Cables and cord as well as connectors can be purchased and installed quite easily.
Standby light stays on but receiver will not start on my pioneer vsxd903s
Have you tried to take the power off the receiver completely? (pull the power cord and wait a few minutes before you reconnect)
If this doesn't work, your receiver might have some kind of defect. In this case you should have it repaired.
Aug 21, 2016 | Pioneer Audio Players & Recorders
Tip
Loose memory
My receiver lose the memory after of power cord stay disconnected about seven days. Any body now where is the backup battery?
on Sep 01, 2008 | Pioneer VSX-D810S Receiver
Onyko tx nr616 receiver keeps shutting off. Only stays on for approximately 3 seconds. Can you help?
The amp protection circuit has been activated. Remove the power cord from the wall outlet immediately. Disconnect all speaker cables and input sources, and leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect the power cord and reconnect an input and a pair of speaker wires onto the unit. If the receiver still does not turn on than you will have to bring it in for service. Turn up the volume and if the receiver doesn't shut down, power off the receiver and add another pair of speakers. Power up the unit again and turn up the volume. If it doesn't shut down, power off the unit again. Now connect all your input sources and turn on your receiver. If the unit shuts down again, your unit will need to be further serviced at an authorized Onkyo service center.
Sep 30, 2014 | Onkyo Tx-nr616 7.2 Thx Certified Network...
Garmin nuvi 200 keeps shutting down
You may need a new power cord, I have the nuvi 250w and the cord is getting bad after a year. The battery will only run it for a short time.
Sep 16, 2009 | Garmin nuvi 200W GPS Receiver
Yamaha HTR-5760 goes to standby 2 seconds after power on
Maybe your device got the audio amplifier IC damaged
Jul 02, 2009 | Yamaha HTR-5760 Receiver
Standby light stays red and will not turn unit on.
Try to reset the macroprocessor. Unplug the unit from AC, hold both buttons SPEAKER A and SPEAKER B and plug the cord in outlet. After display flashes several times release the buttons. No result? - repair shop.
Apr 05, 2009 | Denon AVR-1906 Receiver
Denon AVR-2309ci receiver keeps losing power after a few seconds
This is a defective unit. bring it back to best buy and have them replace it.
Jan 02, 2009 | Denon Audio Players & Recorders
Onkyo TX-DS989 not staying on
This sounds like the action of some protection circuit that is monitoring some condition or voltage that isn't within its design limits. If it was mine, I'd look for an Onkyo forum to see if others have experienced the same problem.
Sep 10, 2008 | Onkyo TX-DS989 Receiver
I have a Garmin Nuvi 760. The end cap which screws in and holds the fuse in for the traffic receiver power cord is broken. Anyone knows where I can get a replacement part without buying another power...
This is a known problem with the 760 traffic receiver power cords. Call Garmin Customer Service (you may stay on hold for 20 minutes or so). When someone answers, explain the problem and they will most likely send you a replacement screw cap and fuse assembly for free.
Jun 12, 2008 | Garmin GPS
301 Power Problem
you might have a grounding issue or electrical power. dish receivers need a specific amount of volts, what you can do is take an extension cord n connect it to the rcvr and take the other end of the extension cord n plug it in on another outlet in another ROOM, then see if it powers on , if it does something is wrong w/ the outlet even if u have A tv or other appliace plugged in, if it doesnt turn on then call dish network n get replacement receiver
May 13, 2008 | DISH Network 301 DTV Receiver
RCA 25404RE3 Corded Phone Logo
63 people viewed this question
Top RCA Lands Phones Experts
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
