CAS SW20 Portion Control Scale Logo
Posted on Oct 12, 2010
How to calibrate a CAS sw20 scale? - CAS SW20 Portion Control Scale
1 Related Answer
thakurdadabh
DADA BHAI THAKUR
  • 77 Answers
  • Posted on Jun 11, 2014
SOURCE: Calibration
http://www.cas-usa.com/cas.../AP1%20-%2060LB%20Owner's%20Manual.pdf
Calibrate cas ap-1 scale
Calibrate a mega weigh mgp-1014 digital pocket scale
Calibrating a digital pocket scale like the Mega Weigh MGP-1014 ensures that it provides accurate measurements. Here are the general steps for calibrating such a scale:
Note: It's important to refer to your scale's user manual for specific instructions, as calibration methods can vary between different models.
What You'll Need:
  • Calibration weights (these are weights with known, precise values)
  • The Mega Weigh MGP-1014 scale
  • A clean, stable surface for calibration
Steps:
  1. Read the Manual: Familiarize yourself with the user manual that came with the scale. It should provide specific instructions on how to calibrate the scale.
  2. Clean the Scale: Ensure that the scale's weighing platform is clean and free from any debris. This helps to prevent interference with the calibration process.
  3. Power On: Turn on the scale and wait for it to stabilize, displaying "0.0" or the default reading.
  4. Tare (Optional): If your scale has a tare function, you can use it to zero out the weight of any container you plan to use to hold the calibration weights. Place the empty container on the scale and press the tare button.
  5. Select Calibration Mode: Many scales have a calibration mode that you need to access. Refer to your user manual to determine how to enter the calibration mode on the Mega Weigh MGP-1014.
  6. Add Calibration Weight: Place a calibration weight of a known value onto the scale's platform. The weight should match the unit of measurement you plan to use (grams, ounces, etc.).
  7. Calibration Procedure: Follow the specific instructions provided in the user manual to initiate the calibration procedure. This usually involves pressing buttons or following on-screen prompts. The scale will often ask you to confirm the weight value of the calibration weight you added.
  8. Confirm or Adjust: The scale should display the weight you added as the calibration weight. Confirm that the displayed weight matches the known value of the calibration weight. If there's a discrepancy, follow the manual's instructions to adjust the calibration setting accordingly.
  9. Repeat if Necessary: Some scales require calibration with multiple weights to ensure accuracy across the scale's entire range. If this is the case, follow the manual's instructions for using additional calibration weights.
  10. Exit Calibration Mode: Once you've completed the calibration procedure, exit the calibration mode according to the instructions provided in the user manual.
  11. Test with Known Items: After calibration, test the scale's accuracy by weighing objects of known weight to ensure that it's providing accurate readings.
Remember that the exact calibration process can vary depending on the scale model, so always refer to the user manual for the most accurate instructions. If you're unsure about any step, it's recommended to contact the manufacturer's customer support for assistance.
2answers
How to calibrate?
just look up calibrate .there ar many ways to calibrate .
I need to get manual/user's guide for scale CAS LP 1000 (need to re-program the scale...) Thanks!
you can find the user's manual on the CAS corp. site..here's the link...just scroll down to the downloads section on the left and u can download there http://www.cas-usa.com/lp1000n.html
2helpful
2answers
My scale starts out with 7.2 instead of 0.0
try removing battery if this does not work you have a faulty weight sensor
Top CAS Measuring Tools & Sensors Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a CAS Measuring Tool and Sensor Expert? Answer questions, earn points and help others
