Question about GE Profile 23.3 Cu. Ft. Counter-Depth Side-by-Side Refrigerator - Stainless-Steel
Freezer coil keep iceing up right side tempt gets warm
    President:
  • 834 Answers
The problem is most likely either the defrost timer, and/or the defrost heater element(s) are faulty. The problem is that the defrost heater elements are not functioning properly and the evaporator core is actually freezing up and blocking the air flow through the evaporator core and also freezing up the thermal sensor, and when that happens there is no longer enough cold air being circulated through the refrigerator (that is actually how the unit operates and air must be able to flow through the evaporator core and then be circulated throughout the refrigerator to properly function) and as a result the refrigerator stops functioning and food can even thaw out in the freezer although the freezer seems to be iced up. (Usually at the rear wall where the evaporator core is located)
(Air flow through the evaporator core and cold air circulation and re-circulation through the refrigerator is performed by the air circulation fan and it also must be functioning)
Be sure to only use a blow dryer (with a towel on the bottom of the freezer) to thaw out the evaporator core and do not use any hard or sharp objects or the evaporator core can be damaged. The defrost timer can be located inside of the refrigerator itself, (see lower image) or it can be mounted outside usually either behind the air intake cowl or kick panel at the front base of the refrigerator, or most likely located behind the service panel on the rear of the refrigerator, and usually if the defrost timer is turning then it is most likely working, however the defrost timer can move very slowly and you can place a mark on the timer and the housing to check after about fifteen minutes to see if the position on the defrost timer has changed. The deforst timer on newer digital models can be built into the circuit board and is not a seperate timer mechanism.
Here are some images that should be similar to your situation to help assist you, and let me know if you require any further assistance.
6afffreezer coil keep iceing up right side tempt gets - 8f81cb6.jpgass=
Posted on Oct 12, 2010
I am having trouble getting new fridge cool enough in fridge. Should it get below 40 f in fridge on mid setting of both freezer and fridge section
fresh food tempt should be 38 deg ( this is good ) and 40 is close . as it will be 5 deg up and down freezer thempt should be around 5 to 15 deg or ice mker will not work . make sure the coils ore clean and fans are working or these tempt can not be obtained . mm feed back pls
Jan 01, 2011 | KitchenAid Architect Series II KSRG25FVMS...
My ice maker does not make ice anymore.
if freezer is too warm it would cause this ck tempt it must be 15 deg or colder . 0 to 5 is best . if too warm / clean the coils an make sure fan is going . . also ice build up in back of freezer may be problem ..mm
Oct 24, 2010 | Roper RS22AQXKQ Side by Side Refrigerator
My freezer has dropped in temp to -6 and my refrigerator is rising in temp and only blowing minimal cool air. The fridge is less than one month old.
ck the back of the freezer / look for ice build up / if evap coil is blocked the fresh food side isnot getting cold air and the tempt of freezer is dropping . is sounds like a defrost problem caused by main board failure or heater / defrost themo . / fresh food will keep getting warmer and soon the freezer will also .. mm
Oct 16, 2010 | GE Profile PSW26P Stainless Steel Side by...
I have a side by side and it started beeping, the doors are closed and it just keeps beeping. How can i make it stop?
ck the tempt / the beep is a code or a alarm // look behind the toe grill and see if the tec sheet is there and it should tell you what is going . / I would think that the fan inside or under neath is not going and the tempt in freezer is too warm . ck for a dirty coil under neath and clean it when your there . also ice build up on the inside back wall of freezer . hope some of this will help mm
Oct 16, 2010 | LG Refrigerators
My refrige runs but tne freezer stopped freezing and eveything thawed ,also ice machine . my refrige part seems to be fine
tempt in freezer is or should be 15 deg or lower to 5deg/ the ref gets its cold from the freezer . so if freezer is failing the soon so will the fresh food side . look for ice (frost build up on the back of freezer . / and if so the cold coil is blocked and there is no air flow through it .. if you find this you have a defrost system failure . ck the heater in freezer and the defrost terminator and the aditive defrost control . these are the things that cause this problem. A D C is most common .. hope this helps mm
Oct 11, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
Freezer not making ice. Top of freezer is warm. Bottom of freezer still keeping things frozen. Refrigerator side seems to be fine.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 30, 2010 | GE Profile PSC25PSWSS Stainless Steel...
Ice maker has stopped working. I have check all settings and made sure there is no blockage
ice mkers quit when tempt in freezer gets too warm. freezer needs to be 15 deg f lower to 0 deg ..no lower . ck your settings and make sure the coils are clean and the fans ore going .. mm
Aug 10, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My side by side refrigerator and freezer is not keeping cooling temperatures. Freezer had frost in ice dispenser, then began dripping water-had a few ice-sicles and then noticed food defrosting and...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
uiot45
Apr 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Kitchenaid artchetice ss side by side built in beeping three times every two minutes, We have been having problems with ice maker but for much longer than the beeping has been happening. Also door open...
the beeping may be the tempt is to warm . caused by door not closing properly . ice mker / if fisrt to quit when temprs art too high.. so ck the coils under neath the frig and the fan . / clean the coils and make sure the fan is going . and ck the fan in the freezer also both must be going to maintain tempts . thes should help problem .. ****
Jan 03, 2010 | KitchenAid KSCS25FKSS Side by Side...
Ice maker not making ice
ck the tempt in freezer side should be 15 deg or lower to 0 deg . . adjust tempt control first / clean coils in back /and make sure both fans are going .. mm
Dec 07, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile 23.3 Cu. Ft. Counter-Depth Side-by-Side Refrigerator - Stainless-Steel Logo
202 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
