Question about Datamax I-4208 Thermal Label Printer
The printer is datamax I 4208 give me an error top of form fault
  • 4 Answers
Try moving the sliding green media guide out from the wall about 1/4 to 1/2 inch, until the white line is under the label path. This green piece holds the label sensor, which needs to be under the labels so it can sense the gap between labels (or the black mark on the bottom side of the backing, if there is no gap). Also, on the printer menu you must choose whether your stock has a gap (aka web) or black mark (aka reflective).
Posted on Nov 18, 2010
  • Al Vodka Feb 17, 2012
    You may need to recalibrate the sensor after fixing the gap as well. If you power off, hold down the feed button, turn on the printer, and hold for 3 seconds, the printer will redetect the differences in the media btw label and backing.
Top of the form fault
Move your green sensor. If still not working, you have to perform manual calibration.
Aug 06, 2013 | Datamax DMX-I-4208 Label Printer
My printer still says top form fault
snosel: The label sensor need calibration. Press and hold FEED button by 5 to 8 seconds. This method is a quick calibration. Or maybe need to make the complete calibration in printer menu.
Roberto Martinez
padrino99@prodigy.net.mx
Mar 27, 2011 | Datamax DMX-I-4208 Label Printer
WE HAVE A DATAMAX CLASS PRINTER AND IT'S GIVING ME AN ERROR " TOP F FORM FAULT" WE DO NOT HAVE THE MANUAL. CAN YOU PLEASE HELP? THANK YOU
Most likely problems:
Wrong sensor set in the media type area. Gap, Reflective.
If the incorrect meday sensor is set, the unit will give a TOF error.
If you hae pressed the feed button and kept pressed for at least 4 labels, and it does not automatically calibrate, check the type of sensor.
If you still get error, and the correct sensor is set, do a complete calibration.
You can downlad the user manual at Datamax-ONeil Web site.
Feb 24, 2011 | Datamax I-4208 Thermal Label Printer
Top of Form Fault error
It means that the printer did not get a good calibration on the label. First make sure the label sensor is in the proper position. Look at the green bar that the label passes underneath and make sure that the white line (the sensor) is positioned over the label. Then calibrate by pressing and holding the FEED key for about 5 seconds until the labels start to feed. After a few labels feed out, the printer should now have a good read on the size of the label and be ready to go.
Hope that Helps !
May 14, 2010 | Datamax DMX-I-4208 Label Printer
Top of form fault
Top of form fault - I assume you hit "Feed" button and still got the form fault... if so:
1. check paper sensor position, sometimes just 1/8" one way or the other will make a difference.
2. calibrate the printer to the stock you have loaded - calibration is EASY, just press and hold the feed button until the printer cycles 8-10 times. Let go, should say "Calibration Complete". Hit "Feed" again to see if your top of form fault is fixed.
Jun 10, 2009 | Datamax M-4208 Thermal Label Printer
Datamax dmx-m-4208
press MENU then enter(cancel) then FWD(feed) appear sensor type then press ENTER(cancel)
then choose continuous >>>
Feb 10, 2009 | Datamax M-4208 Thermal Label Printer
Datamax I4208
position fault is normally a problem with either the formatting or the printer is not calibrated correctly.
Hold the feed button down until at least 3 labels pass by the sensor.
Also check to see the sensor is directly over the die cut on the label if more than 1 up label
Sep 22, 2008 | Datamax M-4208 Thermal Label Printer
Datamax i - 4208
If you use ms-access you must have installed the windows driver, therefore you must enable the cutter in the printer properties. Position fault is that it does not detect the label, must be press the FEED key or to calibrate, press the FEED key for 5 seconds to calibrate the sensor label.
Sep 01, 2008 | Datamax M-4208 Thermal Label Printer
DatamaxI class 4208 top of form fault
The printer must be calibrated or the type of sensor is wrong. Verify that the sensor type is correct for your label (gap or black mark) and you can calibrate it by pressing the FEED key for about 5 seconds approximately.
Jun 22, 2008 | Datamax M-Class 4208 Thermal Label Printer
Datamax I-4208 Thermal Label Printer Logo
2,039 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Kevin Brown
Level 1 Expert
Greg Cann
Greg Cann
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
