Question about IBM TravelStar 40GN 20 GB Hard Drive
Cannot Open when connected
Ibm travelstar USB 2.0 not opening
  • 3 more comments
  • Anonymous Aug 15, 2008
    I connect harddrive IBM Travelstar 20 GB Model IC25N020ATCS04-0 (made in Thailand) to PC via USB port but cannot open ,LED is light .How can I do , I have no driver.Pls. help me.
  • Anonymous Nov 13, 2008
    connected light is on, but nothing pop out
  • Anonymous Jan 29, 2009
    I have same problem. I have IBM Travelstar 40G,
  • Anonymous Mar 09, 2009
    I have the led on, but no hard disk is showing.
  • Anonymous Apr 30, 2009
Posted on Jul 19, 2008
Not coming up when connected pls help
Posted on Oct 21, 2008
I need a new a new cable (fits an unusual 5-pin socket) for an ibm travelstar external hard drive
the dearlership should know what you need. the reason the socket is so different is to let you know, the stuff in which contained in this part is very sensitive and could major problems if you are not sure what your doing
Apr 13, 2012 | IBM TravelStar 40GN 20 GB Hard Drive
I have travelstar IBM harddrive i want to coonect to laptop through IDE to USB addapter
Hi
Buy the external hard drive case to market, IDE cable put the hard drive IDE slot and put the power and close the case, now connect your USB cable connect your laptop and hard drive...
Good Luck
May 20, 2011 | Computers & Internet
Unable to download folders (photos, personal documents, etc) from 5 y/o Pentium PC to IBM TravelStar 2.0 USB External Hard Drive with following message appearing... "Cannot create and replace (folder)...
Can you "read" any files from the external disk-drive?
Can you "delete" any files/folders from the external disk-drive?
Can you click 'File' and 'New' and 'Folder' to create a new folder on the drive?
Dec 11, 2010 | IBM TravelStar 40GN 40 GB Hard Drive
I have a problem with opening IBM portable 40 Gb USB 2.0 hard drive. Should I have drivers for it?
microsoft tends to have generic drivers for porta drives but i would go to IBM's site and check under support for a driver
Jan 04, 2010 | IBM TravelStar 40GN 40 GB Hard Drive
I had all my data informations in this HDD but I cannot open it now. It always shows when it access a mass storage drive in USB but I cannot access it.
Hello and thank you for using Fixya's services.
You can take the actual hard drive out of the casing and slave it to a working desktop. You can then retrieve your information and use the computer to reformat the HDD. After this put the HDD back in the casing and try to attach to computer. If it doesn't read, then more than likely the USB connection or casing is messed up. You can always keep it slaved to desktop and continue to use, except now it will be internal and not removeable.
Hope this helps!
Nov 20, 2009 | IBM TravelStar 40GN 20 GB Hard Drive
Connect external hard disk IBM travel star 80GB USB port 2
Unless it's windows 98 you don't need a driver. If your computer can't see it, it's probably broken. Try plugging it in to another computer and see if it can see it
Oct 01, 2009 | IBM TravelStar 40GN 40 GB Hard Drive
Getting files off an old IBM TravelStar 20 GB Hard Drive
You can buy an adaptor that will connect your hard drive to a pc.
Ribbon cable from your secondary drive on pc goes into the adapator. Adaptor also coonects to laptop harddrive.
You also need to change from being a master driveto be a slave drive . see linkbelow.
http://www.hgst.com/hdd/support/tva/tvajum.htm
You can then copy file to pc a usb memory stick.
Oct 13, 2008 | IBM TravelStar 40GN 40 GB Hard Drive
Ibm Travelstar usb 2.0
I assume you can't see it in Windows? When you connect it can you hear the drive spin up? If not then there is a hardware problem - motor failure, jammed platter. If you hear it clicking or clunking then it is likely to be a stuck head or actuator. If so sometimes you can give the drive a sharp **** to and fro to try and spin the platter - don't do to long though. If this doesn't work then you would need the data removed by a data retrieval company.
If the drive does spin freely you may be able to fix by doing in order:
running check disk (properties of drive then tools)
using a data recovery program of which there are a few
using commercial data retrieval company.
Hope this helps
Jul 16, 2008 | IBM TravelStar 40GN 40 GB Hard Drive
IBM TravelStar 40GN 20 GB Hard Drive Logo
913 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
