Question about Acer Audio Players & Recorders
I do not get sound from my speaker, the control panel shows it to be sending a digital signal. How do I change it to analog so the speakers will work.
    Master:
  • 633 Answers
Try changing the default sound device from high definition audio output to speakers. You can find it under sound in control panel.
Posted on Oct 17, 2010
When I connect my laptop to my tv with an HDMI cable the video works but the sound comes out the laptops speakers. How do I get sound to the tv?
What operating system are you using? If you are using Windows 7, right click on the Volume icon on the system tray and select "Playback Devices". A window would pop up showing you speaker and HDMI. Select HDMI and then choose the "Set Default" Button on top of the OK button. Thats it! If you want the sound to come out of the laptop again when you disconnect the HDMI from your TV, you have to do this again, then choose the speakers.
Cheers!
Mar 01, 2011 | Vizio 42 in. LCD TV
Trying to connect BA735 speakers to a MacBook? No sound? Are they compatible?
Those speakers were originally supplied with Gateway computer system that had sound cards with digital outputs. While some versions had analog and digital sound inputs, most often the speakers had digital input only. The on-board sound in the eMachines is analog output only, so the speakers are most likely not compatible with your computer. If you want to use those speakers, you will need to locate a PCI sound card with digital output.
It's a matter of the output from the computer's sound card (built-in) being incompatible with the speaker input. The card is sending out analog sound wile the speakers are expecting digital input. Downloading a driver won't help because that doesn't fix the root problem. You need to get speakers designed for analog input, or a sound card with digital output. As it stands now, your computer just can't use those speakers.
Since your using a MacBook there is no option for this Pci Digital Sound Card.
Feb 03, 2011 | Boston Acoustics BA735 Computer Speakers
What are the classification of simple machune
Specifications Display Image Aspect Ratio: 16:9 Widescreen Modes: Conventional 4:3 Comb Filter: 3D digital Additional Features: V-Chip, parental control Diagonal Size: 42" - widescreen Display Format: 1080p (FullHD) Resolution: 1920 x 1080 V-Chip Control: Yes Image Contrast Ratio: 2500:1 Brightness: 500 cd/m2 TV Tuner Stereo Reception System: MTS Secondary Audio Program (SAP): Yes Analog TV Tuner: NTSC Video Features HDTV Ready: Yes Analog Video Input Signals: NTSC Input Video Formats: 1080p Remote Control Type: Remote control Audio System Sound Output Mode: Stereo Sound Effects: Virtual Dolby Digital Speakers Included: 2 speakers Additional Features: Mute button Speaker(s): 2 x right/left channel speaker - built-in Connections Connector Type: 1 x composite video input ( RCA phono ) ¦ 1 x S-Video input ( 4 pin mini-DIN ) ¦ 3 x audio line-in ( RCA phono x 2 ) ¦ 2 x component video input ( RCA phono x 3 ) ¦ 3 x HDMI input ( 19 pin HDMI Type A ) ¦ 1 x digital audio output (coaxial) ( RCA phono ) ¦ 1 x audio line-out ( RCA phono x 2 ) Power Power Device: Power supply - internal Power Consumption Operational: 240 Watt General Product Type: 42" LCD TV TV Tuner: 1x analog, 1x digital Width: 41.3 in Depth: 10.2 in Height: 29.7 in Weight: 55.1 lbs HDCP Compatible: Yes Digital Television Certification: HDTV Digital TV Tuner Digital TV Tuner: ATSC, QAM Additional Specifications HDMI: Y More Information Model No.: DP42848 Shipping Weight (in pounds): 67.0 Product in Inches (L x W x H): 41.3 x 10.2 x 29.7 Assembled in Country of Origin: USA and/or Imported Origin of Components: USA and/or Imported Walmart No.: 000503420
hope this will be helpfull to you.
GoodLuck
Feb 02, 2011 | Sanyo 42 in. LCD TV
Speakers are the correct wattage. Speakers are attached to stereo correctly. Can't hear music from fm broadcast or from cd player. Is this easily fixed?
Many of the current stereos and receivers have a toggle switch for analog and digital sound input, and many of the devices that are coming out like HD FM, DVD, Blu-Ray players, some higher-end MP3 players...etc. can output in 5.1 or higher surround sound. In order to control the individual speakers in a system like that though they have to send the signal out in a form of data that has to be processed by the receiver before it can be sent to the speakers.
So all that being said if you have an analog (or normal) device plugged into a receiver but it's set to listen for a digital audio signal you won't hear any sound at all. It works the same way if you have a digital device hooked up to an analog input.
To fix this just look through the manual that came with the stereo and see if there's a way to make sure it's set correctly for the device. Some devices also have settings you can alter on them so that they can send analog or digital signals to the receiver. I would say to check into whichever part is newer, and easier to work with. Once you get them talking the same language you shouldn't have any problem with it.
May 20, 2010 | Audio Players & Recorders
No sound windows vista lap top boston ba7500g
Hi friend,
You should check computer speaker another computer if it is working you should check you lap top sound drives....then you need to update your sound drives...
With Regards
Dec 31, 2009 | Boston Acoustics BA7500 Computer Speakers
Connecting BA735 digital 3.5mm plug with S/PDIF coax jack
The male mono plug (from the left small speaker) should be connected into the right speaker (small speaker with controls) . After plugging the multi pin cable from the control speaker to the sub-woofer you need to plug in a signal source from your computer (or any other digital signal) into the sub-woofer. This digital input looks like an ordinary RCA plug but carries many channels of audio. That connects to the enabled digital output of your computer. Some computers output digital through a 3.5mm jack others look just like an RCA phono jack. If you are lucky some BA735 sub-woofers have a second input that is a standard 3.5mm stereo jack and it will take analog audio from computer, DVD, MP3 player or the like. I have three sets of these speakers that I love because of their big volume considering such a small size.
Mar 29, 2009 | Boston Acoustics BA735 Computer Speakers
I have a Dell Inspiron 630m computer with these speakers
Assuming you are using digital BA735.
Use the dongle that came with your Inspiron. It gives you a digital output which can go into the BA735 speakers.
I use one set of BA735 with two computers. Computer A sends digital out and Computer B sends analog. BA735 plays both. I listen to music using digital while the analog from the other computer alerts me to the incoming messages in Pidgin.
I did have to change bios settings on one computer to use the on-board audio.
To enable digital output in XP, click on the speaker icon > Advanced > Select Enable SPDIF. You can leave the PC Spk Mute unchecked if you want the analog output as well. That's all.
I hope you are able to enjoy the rich sound of BA735. It's beautiful. My ears thank a lot for replacing those desktop speakers. BA735 hardly takes up any space . Two small speakers are perched on the hutch and the bass module is somewhere behind the desk, completely invisible.
Jan 11, 2009 | Boston Acoustics BA735 Computer Speakers
Analog mode unfunctional
Dear kaarlo125
In regards to your card not working in analog mode the card can only do analog or digital not both. So for analog to work you will need to turn off the digital mode. You should be able to do this in the Audio HQ. There should be a check box that you will need to uncheck. However it is been awhile since I had my Live card working so I am not directly sure where it is at but if you have trouble finding it let me know and i can set the card up on my test system.
As for the speaker test there is not a real test for digital speakers because the audio is a compressed signal. Now there has been AC3 files rigged to work like a speaker test but this was not avalible with the Live card.
Let me know if you still have trouble. If you do I will need some more info:
Make and Model of your speakers.
Model of the Live Card (Also did the card come with your computer.) The link below will show you how to find the model number on the Live card.
http://support.creative.com/kb/showarticle.aspx?sid=46261
Issken
Dec 30, 2008 | Creative Labs Sound Blaster Live! 5.1...
Boston Acoustics Digital BA735 Speakers with no Analog input.
Dec 27, 2008 | Boston Acoustics BA735 Computer Speakers
Boston Acoustic BA735 digital CD quality 16 bit/44.1khz speakers
Dell laptops come with a proprietery s-video dongle. It gives you a digital output which can go into the BA735 speakers.
Dec 16, 2008 | Boston Acoustics BA735 Computer Speakers
54 people viewed this question
Top Acer Audio Players & Recorders Experts
 Mikey
Mikey
ray gallant
Are you an Acer Audio Player and Recorder Expert? Answer questions, earn points and help others
