Question about Sony KP-61V85 61" Rear Projection Television
I have a sony kp-61v85 color rear video projector and it has a red haze across the middle section of the screen like its out of focus. A tv repair man replaced 2 cv boxes and the picture got clearer and brighter but the original problem still remains. Whats the problem?
  • Sony Master
  • 8,457 Answers
The tv have a problems is known as a convergence problems,it dead.The R,G,B colors lines mis alignment,have colors shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resitors are dead.These parts on the tv convergence board,must be replaced to solved tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Posted on Oct 12, 2010
I have a Sony color rear video projector KP-46WT20 and it has not been turned in about 2 years. I recently tried turning it on by plugging it in but it won't turn on instead, the standby button light...
The lamp is dead most likely. the blinking is actually coded as a message depending on the number of blinks. if you check the troubleshooting section of the manual it will tell you what the blinks mean
Mar 12, 2011 | Sony KP-61V85 61" Rear Projection...
Sony rear video projector.KP-53S65. Turned on the TV today and has a double image and the colors are off. No previous malfunction. Any suggestions?
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest a shop.
Jul 03, 2010 | Sony KP-53S65 53" Rear Projection...
KP-57WS520 Sony Projector - No picture
5 times blinks shows incorrect white balance (AKB) error. TV needs Screen Volts (G2) adjustment.
Take off lower front panel, find Focus Block that has 6 control knobs, adjust Screen volts of each CRT (red-green-blue) and problem will be solved.
Be Careful while working in TV.
Let me know if you have further question.
Thanks.
Dec 09, 2009 | Sony KP-57WS520 57" Rear Projection...
Sony 46 inch proj tv picture is bowed in the middle and color is
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 29, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-53V25 Color Rear Video Projector Powering off unexpected
possible crt problem, they have to be reseated, if not then the convergence is failing expect to pay around $300-350
Jul 26, 2009 | Televison & Video
Sony rear projector TV problem, KP-61v35
This is a problem with the vertical circuit. This can be as simple as poor connections at the vertical IC or a defective IC. If you can solder, you should be able to fix this yourself. Let me know if you wish to attempt the repair and I will supply additional details and instructions.
Dan
Feb 26, 2009 | Sony KP-61V35 61 in. Rear Projection...
Color video rear projector...........color red is misaligned
convergence amplifier ICS !!! replace them and associated pico fuses ICS # start with STK
Dec 22, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sony color rear video projector KP-43HT20
get the tv degaused that should fix the problem
Jul 23, 2008 | Sony KP-61V45 61" Rear Projection...
Sony KP-61V85 61" Rear Projection Television Logo
169 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
