Question about Ryobi 26CC, 22 In. Hedge Trimmer
I have the housing off and I am trying to figure out how to get to the spool housing so I can fix a broken pull rope, what tools, directions etc. And diagram or picture if possible. Thanks ek
    President:
  • Ryobi Master
  • 1,545 Answers
Remove the tube that holds the flex-drive shaft from the front of the motor cover.Remove the rear engine cover. Remove the throttle cable from the carburetor. Mark and unplug any wires for the on/off switch that go to the ignition coil (underneath front cover) if possible. Now if you have pulled the driveshaft tube out of the way, the clutch drum is up next. Inside it, screwed into the very end of the engine's crankshaft is a Torx #25 screw. A skinny-bladed scredriver may also fit it. Before you loosen it, you will have to lock up the engine. To do so, remove the spark plug. Pull on the starter until the piston is down, then insert a length of clean, soft rope into the engine. The engine will come up and compress the rope, thus locking it in place to allow clutch drum and clutch removal. Loosen the T-25 screw inside the drum.. It probably won't come completely out...it is made this way. Next, remove the clutch. It is screwed onto a small threaded section of the crankshaft Removal is counterclockwise.. It will be pretty tight. To help, apply peneterating oil. Whack the ears of the clutch near the center with a dull flat-blade chisel and hammer unless there are bolts. then use wrench. It will turn counterclockwise for removal and there will probably be a removal direction arrow on it's face. After getting that off, remove the Torx screws holding the cover to the engine. The starter unit should be mounted inside as it mates with the bottom of the flywheel to start the motor. Remember to preload tension (5-7 turns) on the starter unit before installing the rope. Make sure the handle is installed. Jam the unit with a screwdriver or vise grips or something to keep it from retracting so you can insert and tie off the new rope. Then remove jam device and let recoil pull your new rope into place while holding the pull start handle. Reassemble and you are done. Disassembly requires Torx head drivers T-20 and T-25. Here is a link for pictures to help.
http://www.ereplacementparts.com/article/1771/How_to_Remove_a_Trimmer_Clutch.html
Posted on Oct 12, 2010
  • Roy Cagle
    Roy Cagle Oct 12, 2010
    My apologies as I have given you weed whacker removal instructions that may or may not be pertinent to the type of machine you are working on. Please post back as I still would like to be of assistance.
How to replace starter rope in lawn mower
First assemble the following: Pliers, large vice grips, 'c' clamp or a bench mounted vise and new rope. Remove therecoil housing from top of engine. Turn it over, find the end of the broken rope and on pull it until it is fully extended but do not remove yet. While holding the rope extended place clamp device on the rope housing clamping the spool and housing. Be careful not to put too much pressure on the housing, just enough to hold the two pieces. Carefully remove old rope and thread the new rope through the small hole in the housing and into the slot in the pulley. Tie that end of rope into a knot to prevent rope from coming out. While holding other end of rope, carefully remove the clamp from the housing and slowly let the rope rewind into the housing. Replace rope housing onto top of motor. HOW TO Replace Broken Lawnmower Pull Cord
Sep 01, 2014 | Garden
Stihl fs55rc rotor spring
Determine which direction it needs to go to pull the cord out of the hole and COMPRESS the spring. put the tab on the tail end into the housing, and put the white spool in the inner end of the spring. rotate the spool while keeping your finger on the spring to hold it onto the spool. Once it's sufficiently wound enough to fit back into the housing, insert it and reinstall the washer and clip.
Jun 04, 2012 | Stihl Garden
I have an MTD Snow Thrower Model 2M1 with a broken starter rope. I replaced the rope but cannot get it to rewind the rope after I pull it. What am I missing when I reinstall the rope and spool?
When you have the starter top removed, you must wind the spring BEFORE installing the rope. Wind the pulley until it is at maximum tension, then unwind it until the hole in the pulley lines up with the eyelet on the starter top. Now, put the rope thru the eyelet and into the pulley hole. It is helpful to have somebody holding the tension on the pulley, or you can insert a small tool thru the vent holes to hold the pulley in place. Use a figure 8 knot on the rope. Go ahead and tie the handle onto the other end of the rope, and release the pulley tension. It should now recoil into the starter housing. Test pull the rope several times to make sure it is moving freely. Reinstall the starter housing onto the engine and retest.
Dec 01, 2010 | Mtd Products Yard Machines 158CC Tiller
How to re-coil cord on UST-5500 ?
General rewind procedures for most engines. Remove the starter cover and place it on your workbench with the plastic rewind spool visible and remove the old rope noting how it was tied. The rope is sold in various sizes from # 3 to # 6.5. Most gens use a #5.5, with length of about 6 to 7 feet. You may not need this much but more is better. Now practice inserting the rope thru the hole where it comes out of the cover into the hole where it ties on the spool. Once you can do this you are ready to wind. The spool /spring winds when you pull the rope, that why it recoils when you let go of the rope. With that in mind, turn (wind) the spool in the same direction that it turns when you pull the rope. It should be getting tighter as you turn. Keep winding in the direction that it turns when you pull the rope untill it will not go anymore. It should be very tight. Now unwind one complete turn and align the hole of the spool to the hole in the housing and hold it there while you insert the rope from outside hole into the spool and tie knot. After the knot is tied slowly let rope rewind into the spool untill it stops on its own. You are done. You should have plenty of extra rope left to extend out and tie pull handle. Good luck
Sep 15, 2010 | Coleman Powermate Powermate 5000W...
Starter rope won't retract
You have to wind the spring as tight as you can before you put the rope on. Then allow the spring to unwind, pulling the rope onto the spool. Be very careful when you take it apart. Good luck...Lee
May 29, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
The starting cord has broken and I need to make repairs . I would like some guidence
Take the housing off for the pull rope. Inside you'll find a spool. Take that off and underneath you'll find a spring. Replace the pull rope and connect it to the spool like the old one is. With the handle outside of the case run the rope through the pull rope hole then attach it to the spool. Wind all but a foot or so of the new rope back onto the spool. The spring will have a way of attaching to the case and to the spool. Attach the springs to the case. There will be a notch cut into one side of the spool. You need to lay the rope into this notch and then place spool back into the case at the same time attaching the spring to the spool. Don't worry about tensioning the springs. Once the spool is back in you need to start winding up the spool in the direction that tightens the spring. You'll need to make about 5-8 rotations depending on the length of the rope. At this point, position the notch in the spool even with the hole where the pull rope enters the case. Pull on the pull rope handle until you pull the slack rope back through the notch and outside the housing. Then release the rope and the slack should be pulled back inside the housing and wrapped around the spool. Here is a video on changing a pull rope on a lawn mower. The idea is basically the same.
http://www.youtube.com/watch?v=i3ZMVFi0yqY
Nov 27, 2009 | Ryobi Garden
I have a broken pull cord and cannot figure out how to fix it.
Easiest way is to remove the complete blower housing assembly, remove the old rope, then twist the rope pulley around and around until the spring is tight, ease it back until the hole in the pulley for the rope lines up with the hole in the recoil housing and stick a small screwdriver through the pulley and the housing to hold tension on the spring. Next, take your new rope and feed it first through the recoil housing, then through the hole in the pulley, tie a good solid knot right at the end of the rope and pull it back out until you feel it pulling on the pulley. Now holding tension on the rope, remove the screwdriver and let the spring tension slowly pull the rope back into the the pulley until it is full, pull it back out about a half turn on the pulley and tie a slip knot against the outside of the housing to hold it in place and reassemble everything. Hook the end of your rope through the rope guide on your handle if it has one, slip the handle on and tie a knot to hold it. Cut off the excess, pop out the slip knot and it will pull up tight and you are ready to go
Sep 16, 2009 | Toro Lawn Mower With Toro Power Tools
Adjusting the start handle
After I get the rope rewound on the spool, I place the spool in the housing pull about 2 inches of rope through the slot in spool and rope end will be facing you. Then wind the spring by turning the spool in the same direction that you would pull to start. Then thread the rope through the starter housing and then tighten keeper that holds the spool in place. If is still will not keep tension, your spring is probably broken.
Apr 11, 2009 | Homelite Garden
Poulan starter rope
to fix starter rope first you must wind spring and place back in housing. just grab spring by middle and wind ,you will have to get it smaller than housing hole. One end should hook to a tab at housing rest of it sets inside itself. once set in housing dont let go, insert rope housing over top & screw in. rope housing should have some return spring to it when pulled. if rope is not tight on return pull simply add one winding to spool. hope it helps!
Feb 14, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Replacing a rope
Replacing the rope is not difficult but tricky. Remove the starter cover and place it on your workbench with the plastic rewind spool visible and remove the old rope noting how it was tied. The rope is sold in various sizes from # 3 to # 6.5. Most mowers use a #4.5 length of about 6 to 7 feet. You may not need this much but more is better. Now practice inserting the rope thru the hole where it comes out into the hole where it ties. Once you can do this you are ready to wind. The spool winds when you pull the rope, that why it recoils when you let go of the rope. With that in mind, turn (wind) the spool in the same direction that it turns when you pull the rope. It should be getting tighter as you turn. Keep winding in the direction that it turns when you pull the rope untill it will not go anymore. It should be very tight. Now unwind one complete turn and align the hole of the spool to the hole in the housing and hold it there while you insert the rope from outside hole into the spool and tie knot. After the knot is tied slowly let rope rewind into the spool untill it stops on its own. You are done. You should have plenty of extra rope left to extend out to the handlebar. Enjoy
Nov 20, 2008 | Poulan Pro 22" Self Propelled High Wheel...
Ryobi 26CC, 22 In. Hedge Trimmer Logo
323 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
