Question about GE Microwave Ovens
New spacemaker microwave lost power. checked the outlet for power, it is good but no power to the micro.
  • GE Master
  • 9,098 Answers
Being new, it would be under warranty, so I would contact GE Customer Service at http://www.geappliances.com/service_and_support/contact/
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 08, 2008
GE Spacemaker (LVM1750) Microwave Oven
If the source voltage, the fuse inside the unit are good someone has to follow the voltage in to see where it stops.
Dec 23, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Where is the reset button located on spacesaver micro wave oven
  • locate the microwave's power supply cord.Remove the power supply cord from the wall outlet.Wait one to two minutes.Re-insert the power supply cord into the wall outlet. The microwave is now reset.
  • Mar 24, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
    My old GE Spacemaker II microwave (JEM21K001) died. I was using it, heard a little pop, and it lost all power. Is this something simple to fix like replacing a fuse or is it bulk trash at this point?
    HELLO.
    take on these steps to solve the problem.
    Check if there is electric power on wall outlet.
    If the microwave plug has fuse,check if it has not burnt.if these are okay there is need to take the last step.
    things needed
    1.Screwdriver
    2.Ohmmeter
    3.New fuse
    1. Unplug the microwave from the electrical outlet to prevent electrocution. Place the microwave in a well-lit area to be able to locate the fuse.
    2. Use a screwdriver to remove the outer cabinet of the microwave, and follow the power cord to the fuse. The fuse is located 2 to 3 inches within the microwave and is attached to the power board.
    3. Observe the fuse to determine if it is blown. Blown glass fuses will produce burn marks on nearby surfaces, or the internal fuse wire will be black and melted, while ceramic fuses show no outward appearance of being blown.
    4. Determine if a ceramic fuse is blown by testing it with an ohmmeter. If the ohmmeter reads zero ohms, your fuse is not blown. Other readings on the ohmmeter show that your fuse is blown.
    5. Replace the blown fuse by popping it out of its holder, and snapping a new fuse in its place. Tighten the fuse clips by squeezing them together with your fingers.
    6. Replace the outer cabinet of the microwave, and plug the microwave back into the electrical outlet. Test the microwave to see if it's working properly.
    Thanks.
    Sep 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
    Micro spacemaker XL 1800 does nothing like not getting power not at panel or or outlet there good
    Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
    Microwave Oven Basic Troubleshooting Tips
    heatman101
    May 05, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
    Micro GE Spacemaker XL1400 Sunday I was warming up soup for three minutes when ready open door and I heard a click, micro shut down I tested the power outlet with the blender and It work An hour later the...
    IF YOU SMELLED BURNING TAHTS BAD, IT SOUNDS LIKE YOUR MAG TUBE WENT OUT (ITS WHAT MAKES THE MICROWAVES) iT WILL BE CHEAPER TO REPLACE IT, NEW UNIT STARTING FROM $115 FOR THE SAME MODEL
    Jun 07, 2010 | GE Microwave Ovens
    My Ge SpaceMaker XL1800 Microwave Oven won't power on any more.
    1.Check power outlet for working.
    2.If it is than you have broken fuse inside the m/w.
    3. To change the fuse you have to disconnect the power to m/w, take the upper grill off, take the screw on top of control panel, lift the control panel up and removed. The 20 Am fuse located behind this panel.
    Dec 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
    Our oven does not come on at all.
    Hi, the door micro switch not working ,also the fuse need to check if it is fine check power outlet and breaker recock it.
    Jan 17, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
    GE Spacemaker Microwave Oven JVM1330BW200
    all...you should first check to make sure the outlet you're using is good. Really. Next, check internal fuse and thermosafety in the unit. They are both found inside the button area. The safety is about the size of a dime and 3/8 inch thick with two wires. Sometimes they open. They should be continuous. Not it? Let me know.
    Dec 16, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
    Dead micro
    It could be a bad in-line circit breaker fuse. Unplug the microwave and take the outside cover off. Look for the in-line circuit breaker fuse. Use a plastic fuse puller (not your hands or a metal tool as there is still voltage stored in the microwave even when it is unplugged). Look at the fuse and see if it is blown. (The metal wire running length of tube will be broken. If you have one, test with an Ohmmeter.
    Jun 03, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
    Microwave Ovens Logo
    21 people viewed this question
    Top GE Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    vince
    Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
