Question about Drills
I have a 1/2 Mastercraft 5A hammer drill, Model 54-2986-4 Seial number K-B 1070. I lost the chuck for it and it seems that none are available at Canadian Tire. Where can I find one.
  • 7,733 Answers
Giva a try here..
Posted on Oct 14, 2010
Looking for a live centre and drive end spur for a Mastercraft 554508-0 cast iron wood lathe
Such accessories tend to be universal rather than dedicated to any particular make or model of lathe.
Such accessories are available from many outlets and catalogues containing items for the wood-turning enthusiast.
The tailstock of most lathes would be produced with a Morse taper numbers 1, 2 or 3 and with a variety of adaptors a number of live or dead centres, drill chucks or morse taper drill bits can be used.
Similarly the headshock spindle should be found to have a standard thread capable of accepting a number of chucks, faceplates, drive spurs and so forth.
The headstock spindle thread and the tailstock taper should be listed in the machine specifications and then armed with that information you can shop around a multitude of suppliers to find the best deal.
Apr 19, 2016 | Tools & Hardware - Others
How do i change the sds chuck to the standard chuck on an kango 220k hammer drill
do not think that is an option . get another drill with standard chuck .
Oct 05, 2015 | Hammer Drills
Want user manual for Mastercraft 1/2" hammer drill
Go back to the vendor and ask for it OR look it up on the web and usually you can download one there
Sep 19, 2014 | Electric 1/2" Hammer Drill Ul
Drillbit stuck
Can not see what model you have. Is it a keyless chuck or an SDS chuck? With a keyless chuck hold the machine in a vice by the drill bit. now tap the chuck with a hammer or pin punch & hammer. DONOT hit the chuck on the jaws gut on the rim around them. I have had success using this method. If it is an SDS type chuck pull the chuck cap up as far as possible along the bit them if there are any ring springs you will have to try remove them then slide the sleeve up the bit, now you should be able to remove any steel balls. If the bit does not come out now hold bit in vice as before and tap on tool holder.
Mar 02, 2014 | Bosch Drills
I have an old hilti, model: te 12 s. it wont drill. when i press the botten it only hammers. i have tryed to open the machine but i can not find the problem.
IT could be one of two problems. 1 The Rollers are missing out of the chuck so that it is not turning the bit. 2 the clutch is worn out causing the gears to slip. The problem is there are no longer parts available for the 12S. You would have to find them on Ebay or some place like that.
If the bit seems to lock into the chuck then it is not the rollers. It is more than likely the clutch.
Aug 08, 2010 | Hilti 375847 TE-CX 3/4" x 12" Masonry...
How do u fit a drill bit into a rotary hammer drill model number fmtc850rhd
Pull back on the chuck and then turn the bit til it drops in place, release the chuck and it will hold the bit...
heatman101
Jun 08, 2010 | Rotary Drills
Can't remove the chuck on my mastercraft drill press.
generally they are a taper fit, is there a slot cut into the spindle?? If so you should have a wedge when you bought it to slide into the slot and tap with a hammer to release the taper shank. Let me know if it is something other than that. on some of the Jacobs chucks they also made special wedges that you put in from either side to remove it again tapping one wedge at a time to put equal pressure on them.
Jan 03, 2010 | Drills
Need to replace chuck on 1/2'' mastercraft hammer drill. Which chuck do I need??? model 54-2986
took off the old chuck , measured, and took it with me to purchase a new one.
Dec 09, 2009 | Drills
Mastercraft seized up chuck
being that new, it should not have seized up, all you can do is try spraying wd40 into the chuck between the teeth and mandrill. if it doesnt work, replace the chuck, it is fairly inexpensive
Sep 02, 2009 | Drills
Drills Logo
330 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
