Question about Gateway MC7321u Notebook
We have a Gatewat MC7321u laptop and the battery will not charge. Do you think it is a battery issue or an issue with the power cord. It works find when plugged in, but it says the battery is not charging. Thanks for your time.
  • 2,567 Answers
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Oct 12, 2010
Samsung 145
Dear frnd,
Probably its battery problem but before change the battery you have confirm first its battery or Adopter problem. you need do first check the adopter to another laptop which has same charging pin . if its doesn't work with another laptop then you change the adopter but if the charger works with other laptop then you need to change your battery. try it..
Jan 15, 2014 | Samsung N145-JP01US Netbook
My laptop is not charging. i plug the power in but still doenst charge. im not sure if its on the power cords or on the laptop please help asap i need my laptop for school :(
Does the laptop work on AC ? Is the battery or cord/charged a replacement? First, try another cord/charger of the EXACT same specs as original. Second, Is the battery good? How old? Over 4 years? Have it tested. Beware of inexpensive aftermarket batteries and cord/chargers. I assume the laptop works on AC? If you unplug the AC , with battery in, the laptop shuts down immediately?
Nov 26, 2012 | Lenovo IdeaPad Y450 Notebook
My laptop wont charge i think it has a broken internal power supply
Bad cord/charger, bad battery? What give you the idea that " i think it has a broken internal power supply" Your saying your laptop will not charge the battery? Does the laptop work? If so the power supply is OK.
Nov 06, 2012 | Sony VAIO VGN-CS310J/W PC Notebook
Evertek e500 not chargijng
Does the laptop work with just the power cord plugged in? If so, that means your power cord is ok and if your battery is not taking a charge then the battery is dead. Batteries only have a useful life, then they have to be replaced.
If you laptop is having issues staying on or booting up with the power cord then either your power cord is bad or the DC Power Jack where the power cord plugs into the laptop is bad. Either one will cause the battery not to charge.
Maybe your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Jun 03, 2012 | Computers & Internet
R60 Wont Charge
What's the make and model of your laptop? Most times the flashing lights will tell what the issue is.
If the laptop will not boot up so you can use it then the things below applies.
Sounds like your power cord is bad. Or the DC Jack is not soldered on good. Just because the power cord is new does not mean it works. Some Power Cords have a little green light on the adapter to show that it is plugged into the wall and getting power, check yours.
Anything ever post to the screen when you hit the power button? Do the fans start up, the hard drive spins? If not, maybe your power cord has enough power to emit a light but not enough to start the fan or disk drive.
If it's not the power cord or dc jack, then you have a Memory or Video Card issue.
OK after reading your post a 2nd time I think your only issue is that the battery is not charging, correct? If that is true the things below applies:
Either the battery is bad or the power cord is bad. Just because they are new don't mean they work. See if the Adapter portion of the power cord has a green indicator light that comes on when you plug it to an outlet. If it does, and that light is not on the power cord has issues. Also I hope you did not buy one of those one size fits all power cords from the big box stores where the end has a bag of different interchangable parts until you find one that fits into the laptop. If so, buy a power cord off ebay that is made for your laptop.
The battery might be bad and not hold a charge. I have seen new batteries that did not work.
May 16, 2012 | Computers & Internet
My Sony laptop is not charging when it is pluged in on to the electric oulet
If the battery is not charging when the power cord is plugged in then the battery is completely dead and needs to be replaced.
Are you sure your power cord is good and that you are not operating on battery power?
Take the battery out and see if the laptop stays on. Or you can reboot with the battery out and the power cord in. If it fails that means the Power Cord is the issue and you were working off the battery.
If you leave the power cord off and insert the battery, then reboot. If it boots up and stays up that means the battery has some charge in it. If it does not boot up or boots and shuts down, the battery is drained and you will need another one if the power cord is good and it's not charging.
Mar 25, 2012 | Sony Computers & Internet
I have DELL LATITUDE D810 I am having an issue charging it`s battery, when the AC Power adapter is connected the notebook works fine, but the battery does not charge, as soon as I disconnect the power cord...
Yo! i think you should try something.get a friend that uses your type of adapter, try charge it with that and see if it responds.if it doesn't charge, you will have to replace your battery which means its spoilt.
Jul 24, 2011 | Dell Latitude D810 PC Notebook
My laptop wont come on (Dell Inspiron 2200)
I have experinced the same issue with the Dell laptops.
My remedy was to purchase a new power supply..(This is the name of the power cord that came with your laptop). You can purchase the power cord from any computer store.
Ask he sales person if you can try the new power cord prior to leaving the store just to make sure this solution works.
I hope this solution works for you as well.
Feb 10, 2009 | Dell Inspiron 2200 Notebook
Compaq Presario X1000 power issues
Unassemble the fan and see if there is a lot of dirt and dust in there. If the fan is NOT working you need to fix that issue before you do anything else. Does the computer randomly shut down ?
Robert
Aug 27, 2008 | Compaq Presario X1000 Notebook
Gateway MC7321u Notebook Logo
289 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
