Question about Asko D3531XLHDSS Stainless Steel Built-in Dishwasher
Need to replace s.s. panel with a wood door to match kitchen, need instructions on removing panel
    Champion:
  • 246 Answers
Depending on the type of dishwasher there should be screws on the side of the door that can be removed on one or both sides to remove the frame surrounding the old panel. If your dishwasher door seems to wrap around the sides, you may have to order a custom panel from the manufacturer or you can check out ApplianceArt.com and see if they can help with a magnetic or vinyl cover that would goo over your existing panel.
Posted on Oct 29, 2010
Can you tell me a company that deals with the production of wooden doors manufactured with the appropriate interior and design ?
An increasing number of people are turning away from plain ready to paint, unvarnished or inexpensive wood imitations from the DIY stores. Real wood doors are in with made to measure doors and door frames of high quality veneer which are making their entrance back to UK apartments and houses. All doors and door frames made of veneer are the result of time-consuming and manual craftsmanship whereby the suitable veneer are selected and further processed for each job. This ensure optimum colour matching of door leaves, door frames and architraves. Each piece of veneer furniture is unique, even if it is manufacture in series production. Therefore finished wood surfaces bring nature into the living room, kitchen, bedroom and offices and create a pleasantly homely atmosphere.
Aug 22, 2014 | Home
Dishwasher blows out steam and has ruined wood floor in kitchen have to replace wood floor
The door seals (Gaskets) surrounding the door are not tight. The door adjustment, is dependent on the tilt backward and height adjustment (adjusting levelers) on the corners. If the upper locking tab screwed to the counter tops underside is loose or misaligned, bent, or broken, the door won't close fully and cause the same problems.
Mar 17, 2014 | Dishwashers
What are the different types of cabinet doors?
wikipedia provides a good explanation, quoted below:
Frames
. In the U.S. solid wood frame and panel construction, using either mortise and tenon or cope and stick jointed frames, is traditional, with maple, cherry, oak, birch, and hickory among the most commonly used species. Mortise-and-tenon frames, with their greater strength and permanence, are more costly to produce and less commonly used as compared to cope-and-stick frames. As an alternative, miter joint frames, which may be identifiable by face-surface relief that follows continuously around the frame, have become popular. Miter-jointed frames typically employ embedded metal fasteners to secure frames elements (stiles and rails) cut at a 45 angle. Captured within frames, panels may be either solid or veneered engineered wood (either particle board or medium density fiberboard). Laminates, including those designed to resemble hardwood, can typically be identified by a more rounded appearance associated with the minimum bending radii necessarily entailed by the manufacturing process of applying laminate to an underlying substrate. By comparison, solid surfaces, and solid hardwoods in particular, can be milled with more sharply defined corners, edges, or grooves on either a panel or frame.
  • Panels. Panels used in frame-and-panel kitchen cabinet doors may be fashioned either of solid wood or covered by paint, veneer, or laminate in which case they are fashioned of engineered wood. The panels are typically not fastened with glue or nails but rather "float" within the frame to accommodate seasonal expansion or contraction of the wood frame.
  • Solid-door construction. Doors may be fabricated of solid material, either engineered wood (particle board or medium-density fiberboard, but not typically plywood) or solid wood. Engineered wood panels may either be used as slabs or may be shaped to resemble frame-and-panel construction. In either case, engineered wood panels are generally painted, veneered, or laminated. Solid wood panels are typically formed of multiple boards of the selected wood species, jointed together using glue and may either be painted or finished. Solid wood construction offers the possibility of refinishing in case of damage or wear.
  • Decorative panels. Cabinet doors panels can be used decoratively on cabinet sides, where exposed, for a more finished appearance.
  • Glass door construction options. Doors may have glass windows constructed of muntins and mullions holding glass panels (as in exterior windows). Other designs either mimic the divided-light look of muntins and mullions with overlays, or may dispense with them altogether. Cabinets using glass doors sometimes use glass shelves and interior lighting from the top of a cabinet. A glass shelf allows light to reach throughout a cabinet. For a special display effect, the interior rear of a cabinet may be covered with a mirrors to further distribute light.
Jan 30, 2013 | Hardware & Accessories
Dishwasher door drops hard when opened.
Sounds like one of the doors springs is broken or has come detached from the dishwasher housing frame. If you have a plain dishwasher door, ie one that does not have a wood panel matching your cabinets, and the spring(s) are broken, new springs cost about $20. If you have wood panel on the dishwasher door, then you may need heavy duty replacement spring at about $22.
Jan 15, 2010 | GE Dishwashers
Driver side door problems
Get a set of hinge pins and bushings. There is a tool that you can get at harbor freight or tool king for removing the bushings. I use a floor jack and a 4x4 block of wood to support the door. you will need a spring compressor to remove the door "hold" spring. Once you have that removed, you can use a brass drift or similar rod to tap the pins out. once they are out the door will be resting on the wood. I use heater hose to wedge between the fender and the door to prevent dents and scratches. tap out the bushings. ever so gently tap in the replacements. apply a generous helping of white grease to the bushing and pin. line up the door and insert the pins. you may have to apply an ever so light amount of tapping pressure on the pins to set them final. reinstall the door spring and lube the joints with white grease. be proud of yourself as your just saved a **** load of money.
May 21, 2009 | 2000 Chevrolet Blazer
Need stronger Door Springs, to able wood door panel
The best suggestion I could give you is contact either Sears or Bosch and ask for recommendations. You will require the proper springs designed for dishwashers.
Feb 03, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Electrolux ESL6114 built in dishwasher door
Although it is a different model than yours, here is the link to the installation manual for an Electrolux DW and it is likely similar. The custom panel instructions begin on page 22 and show templates and how to remove and reinstall the factory door and a custom installation panel: http://www.electroluxicon.com/Files/International_English/0-999/EDW5505ESS_install_en.pdf
Jun 25, 2008 | Electrolux 23 in. ESL6114 Built-in...
How to make a panel, install it and a handle for Kitchen Aid model KUDU03FTPA panel ready dishwasher
Hello babies5 what it means by panel ready is a cabinet door style front to match the cabinets. I have installed many of these panels, however they where always supplied by the cabinet shop who built the cabinets. As to handle, that also always matched the cabinet pulls on the rest of the kitchen. The idea of this unit is to hide the dishwasher. In my kitchen, simple doors, so I would use 3/4 inch plywood and paint it white with the same pulls as my current doors and drawers have.
May 10, 2008 | Dishwashers
Asko D3531XLHDSS Stainless Steel Built-in Dishwasher Logo
167 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
