Question about Plantronics Backbeat 903 Bluetooth Wireless Stereo Headphones Headset
My backbeat is paired and working with my sprint evo. but the music will not play at all through the headset? calls are fine but no stereo music . it was working fine before i got a jawbone and paired it with my phone. what do i need to do?
    President:
  • 1,118 Answers
I wonder if Adroid has some issues with its A2DP stack. You see, I have 3 different stereo headsets paired with my WM6.1 phone, and all of them (one at a time, of course) stream music without any flaws.
Anyway, you could try to delete the Backbeat from the list of paired devices on your phone, and, then, pair them again.
Just my 2 cents...
Hope you are able to sort your problems out soon.
Regards, Carlos
Posted on Oct 12, 2010
My headset just stopped playin sound???
If the stereo earphone output socket is in tact (not broken), most likely the problem maybe the Earphone-cord is broken.
May 13, 2014 | LG HBS-700 Bluetooth Headset
All working just won't pause or play with the button
To use this feature on the 903+ you must only tap it one time, on the music icon. If this still does not work I would get a replacement for the product from the vendor whom you purchased this through. See the link below for more help.
Plantronics BackBeat 903 User's Guide
Good luck from Headsets Direct!
Nov 10, 2011 | Plantronics Backbeat 903 Bluetooth...
When i listen to my music from my phone with my backbeat 903, the music skips like a sratched cd. why is this?
Here are a few things you can try to see if they will improve the quality of the sound:
You should always make sure that your mobile phone is located on the left side of your body and that there are no obstructions between it and your headphones.
Also make sure that your headphones are within 33 feet (10 meters) of your mobile phone. Going outside of this range can impact audio quality.
You can also try resetting the headsets and see if that will help.
While plugging in the AC charger, hold the power/pair button.The headphones will show a solid red or blue light when they have been successfully reset.
Below is a link to the Backbeat 903-906 User's Guide, which may give you some more suggestions.
Plantronics Backbeat 903-906 User's Guide
Oct 03, 2011 | Plantronics Backbeat 903 Bluetooth...
How to install the headset to my EVO 4g
To pair the Plantronics BackBeat 903 with an EVO 4G:
On the 903 headset:
With the headset powered off, press and hold the "Power/Pairing" button until the LED indicator flashes blue and red. This will put the 903 headset into pairing mode.
Use the iPod Touch menu to search for the headset and select 9xxBackBeat.
(If prompted, enter 0000 for the PIN code/passkey. Some devices also require you to accept the connection. Headset is paired when LED flashes blue.)
On the EVO 4G:
Turn the Bluetooth on from the Home screen, tap Menu, Settings, Wireless & Networks, Bluetooth.
Pair the EVO 4G by going to the Home screen, press Menu, Settings, Wireless & Networks, Bluetooth Settings, Scan for Devices. Follow the on screen prompts to pair the devices.
Good luck from Headsets Direct - 800-914-7996.
Aug 13, 2011 | Plantronics Backbeat 903 Bluetooth...
I cant sink with my iphone 4?
Once you make your iPhone discoverable, then put the Plantronics Backbeat 903 into pairing mode. With the headphones powered off, press and hold the Power / Pairing button until the LED Indicator flashes blue and red. Here is the link below for the Backbeat 903 user guide that has the pairing instructions as well.
Plantronics Backbeat 903 User's Guide
Jul 26, 2011 | Plantronics Backbeat 903 Bluetooth...
Pairs but won't control player to hear music
Try contacting Plantronics directly at 1-800-544-4660 x 5538. They will help troubleshot and determine if you have a defective headset or if you're experiencing a compatibility issue.
Good Luck from Headsets Direct!
May 04, 2011 | Plantronics Backbeat 903 Bluetooth...
I go to set up my wireless headset with my playstation 3 but it won't pick up any devices.
You must put both the PS3 and the Backbeat into pairing mode. See your instruction manual for the PS3 for pairing. Once you have both devices searching for each other they should pair right up.
Instructions for putting the Backbeat 903 in pairing mode:
With the headphones powered off, press and hold the Power/Pairing button until the LED indicator flashes blue and red.
Use the PS3's menu to search for the Bluetooth headphones and select 9xxBackBeat.
Here is a link for the User's Guide:
Plantronics Backbeat User's Guide
Mar 23, 2011 | Plantronics Backbeat 903 Bluetooth...
My headset keeps cutting over to "voice control"
I would suggest resetting the headset and see if that will take care of the problem. Here are the reset instructions: While plugging in the AC charger, hold the power/pair button.
Below is the link for the Backbeat User's Guide for more information.
Feb 19, 2011 | Plantronics Backbeat 903 Bluetooth...
I have my backbeat 903 synced to my ps3 and phone how do i switch to my phone when i leave the house and back to the ps3 when i want to use it in gaming
If you have the BackBeat 903 synced (or paired) to both devices, you should be able to toggle between the two seamlessly. The multipoint technology that Plantronics uses to pair its headsets to two devices at once works on a first ring basis. When you're out and about with your phone, the headset will respond only to it (33' bluetooth range for one thing). When you're paired to and having fun on your PS3, if your phone rings, you make the choice to keep playing or answer the phone. You're always in control, one doesn't override the other.
Jan 20, 2011 | Plantronics Backbeat 903 Bluetooth...
Cant hear music through my LG HBS-200 Bluetooth Stereo Headset
I have the same problem with my HBS-250. It was working fine on my iPod Touch. It worked the first couple of weeks on my iPhone 4 then stopped playing music. Phone funtion works. No music or podcasts or streaming from the web
Sep 12, 2009 | LG SGBS0001606 Bluetooth HBS-200 Stereo...
Plantronics Backbeat 903 Bluetooth Wireless Stereo Headphones Headset Logo
441 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
