My radio seems to be at a 1/4 charge and the base red light goes on when I install the radios but it does not raise my battery power at all.My radio seems to be at a 1/4 charge and the base red light goes on when I install the radios but it does not raise my battery power at all.
You can't post conmments that contain an email address.
common. The contacts are dirty most likely. Unplug the charger, get a small piece of fine or extra fine sandpaper and lightly sand the metal wires you see. They will bend, that is normal. So, slow and careful. Still not working? (also common). The charger base or the charger AC adapter may be bad. If you have another charger, switch the wall adapters. If the base if base, you could try to take it apart and re soldier it yourself, but if it got wet, the game is over. Go to a used donation place, such as the Goodwill to get replacements. They are not sold new without a radio. Also, try another radio in the "bad" charger, it could be the contacts on the back of the radio need cleaning.
Replacement parts were never made available for the TalkAbout radios (other than the higher wattage TalkAbout Distance and Distance DPS). Your options are replace the radios, or watch for used radios for parts on ebay and other similar websites.
To the best of our knowledge the charging base and cord come together as a set. You can contact Giant Intl (who manufactures them for Motorola) and get replacements: 1-800-638-5119, [email protected] Best regards
Check your battery contacts, both on the radio and the charger. Clean with a pencil eraser if needed. It is possible you are not getting good contact. If both radios are not getting charged in a dual well charger, you may have a problem with either the wall adapter or the base. (Assuming your batteries are good.) Wall adapters burn out over time, somewhat like a light bulb.
I do believe it is a 9 volt charger. Look under the battery cover and it will say how many volts. It is probably 9 volts. Just have to find a 9 volt charger with the same plug as you have. Or contact Motorola for new one. Possibly E-bay
