-   HELP IT IS HOT!!!!. I have a similiar problem. It comes on but the fan is not turning. I can't take the unit apart because to clean the fan because it is attached to the house. If I tried to take it apart, it would mess up everything. Does anyone know how to clean the fan without having to take it apart?-   tooke1973
Jul 25, 2008
-   Mine hums when I turn it on and that is all it does. Help it's hot here in Georgia.-   sweetthang
Jun 09, 2008
-   i have the same problem with mine .help! my son really needs it on the top floor-   Guest
Jun 09, 2008
-   simply doesn't turn on, press button, and nothing...-   maveryk
mer. It does blow refrigerated air (just doesn't feel like its cold enough), compressor comes on,...
(More)
mer. It does blow refrigerated air (just doesn't feel like its cold enough), compressor comes on, etc. I set the "temp" to 64 (lowest) put it on "low fan", "power save". It cycles like it's supposed to, then the temp gauge for the room temp goes to 64 or sometimes even lower (I know it is not 64 degrees or lower in my house) and the compressor goes off. If I put it on "high fan" and "cool" it seems to bypass the temp setting but it still doesn't seem to get cold enough. Any ideas? Coolant leak? Thermostat problem? This is only it's second summer.
we recently replaced the thermostat on the ac unit and did not shut off the power in doing so and...
(More)
we recently replaced the thermostat on the ac unit and did not shut off the power in doing so and now we cant get the ac unit to come on
