Question about Samsung HLP4663W 46" Rear Projection HDTV
Humming noise in the back - Samsung HLP4663W 46" Rear Projection HDTV
  • Samsung Master
  • 5,138 Answers
Color Wheel : Encompass Parts 1-800-638-3328
Samsung Parts 1-800-627-4368
Posted on Oct 12, 2010
Why is there a humming noise in front end?
balance or wheel bearing starting to go. go back to place who fitted tyres
Jan 26, 2016 | Cars & Trucks
Why do my desktop computer speakers have a humming noise all of a sudden? They were turned off for a couple of days .
Check the speaker cables for connectivity. Be sure to securely plug in the stereo jack/s at the back of your pc
Jul 21, 2014 | Logitech Audio Players & Recorders
Humming noise
Possibly a bad cable or bad ground or bad outlet?. Easy solution, try a different outlet and see if the hum still exists. Also, make sure your speaker cables are NOT run parallel along with, or close to any power cables, Speaker wires can and will pick up AC "Humm" noise.
Apr 23, 2014 | Edifier Audio Players & Recorders
Humming Noise when exselerating on back diff.How can I reduce the noise
Sounds like a bearing. For now try a slightly thicker oil
Jan 23, 2014 | 2006 Volkswagen Touareg
Reason for humming noise even after changing wheel bearings of car
Depending on how the noise is affected by your driving, it could be an axle joint or the differential in the transaxle.
If it is coming from the back instead of the front you may still need hub bearings.
Sep 03, 2012 | 2005 Nissan Sentra 1.8
My tv started to hum have figured it to be part of the backlight NEED HELP?
Hello Sir, Hi, if that is the case, your inverter board is generating audible high frequency noise. the inverter board is true to produce high frequency pulse needed by the LCD, but if should not be audible. try replacing the inverter board and see if the noise will dissapper .
Jul 17, 2012 | Insignia NS-LDVD26Q-10A 26 in. HD-Ready...
Its making a whistling noise that sounds like its coming from the tires. What could it be?
humming or whistling noise..if it is a humming ..try this...going average speed turn your wheels side to side if the humming goes away and comes back then it is a wheel bearing
Mar 03, 2010 | 2000 Jeep Grand Cherokee
Loud humming noise
Stick you hand in the freezer, touch the back wall of freezer, see if you feel a strong or lite vibration equal to the hum you are hearing. If so, the you have a bad evap fan, if not then pull unit out from wall and see if hum is load toward the bottom rear portion of the frig, if so contact a repair tech.
Oct 01, 2009 | GE GSS25JEMWW Side by Side
Humming noise in the front end
Does the noise change pitch when you weave the wheel back and forth at 25. If yes you need bearings. I think they are pressed in on focus
Jul 04, 2009 | 2003 Ford Focus
Samsung HLP4663W 46" Rear Projection HDTV Logo
42 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
