Question about Epson Stylus Photo R300 InkJet Printer
Error message says close the dvd/cd guide but already is
  • 1 more comment
  • Anonymous May 14, 2009
    What?! None of the above answers were helpful in the slightest!!! You think we didn't try those obvious solutions before coming here?!?!
  • faran23 May 26, 2009
    My printer wont power on cause its saying the cd/dvd guide is open but it is closed.How can i resolve this
  • Johann Toledo
    Johann Toledo May 11, 2010
    Are you running on a Microsoft windows os or macintosh?
    In any cases, make sure that the printer settings is correct.
  • 54 Answers
What jackboy suggested is a good one however if ever you already checked on your printer then it should be the settings in your computer.
Posted on Jun 17, 2008
    Genius:
  • 2,985 Answers
Simply open and close the door.
Look in the LCD is the door indicator off?
Posted on Jun 14, 2008
R300 error message close cd dvd guide the guide is closed but it will not print
Have you contacted Epson directly? I had a problem with the R200 some time ago and it was down to the tracking of the CD/DVD tray being out of alignment. Due to cost of the printers now it is not worth paying to get them fixed. Lookout for Epson deals where you can trade in your old R300 for a newer model. I still have my R200 still going strong and an RX858.I am sorry I have no firm advice to fix it direct.Mac#
Oct 25, 2011 | Epson Stylus Photo R300 InkJet Printer
Two Red LIght Blink
CD/DVD guide error
When turning on the printer or printing on paper, the CD/DVD guide is open.
Close the CD/DVD guide.
Carriage error
The print head carriage is obstructed by jammed paper or other foreign material and cannot return to the home position.
Turn off the printer. Open the paper support and the printer cover then remove any paper or other obstructions from the paper path by hand. Then, turn the printer back on.
Sep 25, 2010 | Epson STYLUS R230 InkJet Photo Printer
I get an error message to use a blank or erasable DVD
I would try simply copying one of the already completed discs using a stable and well known burning program like Nero. Programs like Pinnacle can be very temperamental when exporting their projects to disc.
Jul 19, 2010 | Gear Head 8XDVDEXT DVD External Slim...
I keep getting the close the cd/dvd guide
When you flip the main cover up, and flip the CD/DVD tray down, look at the cartridge color guide label (the colored dots). See the LIGHT CYAN dot? Directly across from that dot around underneath the gray cover is supposed to be a little plastic fin. That fin pushes the sensor switch in the CD/DVD tray to let the printer know if it is open or closed. If it breaks off, then the printer always thinks the tray is open. If it's broken off, you will have to either stick a toothpick or something into the switch, or glue a new thin piece of plastic in its place.
Mar 01, 2010 | Epson Stylus Photo R320 InkJet Printer
Close the cd/dvd guide
Is there a button for to close the CD/DVD guide? Your Printer stays on CD/DVD printing mode, that's why
Use it. IF NOT Reset the all settings, Check for your userguide Troubleshooting.
Check epson support page for helfull links.
Aug 12, 2009 | Epson Stylus Photo R300 InkJet Printer
Espon 1400 prob. with vista close the cd/dvd guide. It is CLOSED!
I am having the same problem. I am on my 3rd printer from Epson in 2 weeks.
The solution may be to buy another brand, but I have more in Epson ink & paper than I have in the printer.
Jun 04, 2009 | Epson Stylus Photo 1400 Printer
Epson 300
It sounds that there is a possible hardware failure concerning CD/DVD guide cover. We can try this to resolved that issue:
1. Turn off the printer.
2. Close & open the CD/DVD guide cover for three times and make sure that the CD/DVD tray is not inserted.
3. Close CD/DVD guide, Turn the printer on. If printer is ready, press the maintenance button.
4. Try printing again.
If the above step wont resolved that issue your printer may need to send to a nearest Epson Authorized Service Center.
--->>> Tirzo
Jun 04, 2008 | Epson Stylus Photo R300 InkJet Printer
Burning to cd
According to hp help and support
When using iTunes for Windows you may get a disc failed error. An unknown error occurred (4280)
In this situation, if you attempt to burn a disc, the following error message may display: The attempt to burn a disc failed. An unknown error occurred (4280) You can resolve this error message by modifying a file in the iTunes CD Configuration folder. First, you need to verify the model of optical drive present. Verifying the Model of the CDRW/DVD Drive Verify that your PC has a Sony CD-RW/DVD CRX830E optical drive installed:
  1. Open iTunes.
  2. In the iTunes Help menu, click Run CD Diagnostics .
  3. Insert an audio CD in the optical drive.
  4. Click OK .
  5. View the results in the CD Diagnostics window:
    • If IDE/CdRomSONY_CDRW/DVD_CRX830E is listed, proceed with the procedure below to resolve the error message.
    • If another drive name is listed, this document does not apply to your computer.
Resolving the Error Message When an IDE/CdRomSONY_CDRW/DVD_CRX830E model optical drive is present, do the following steps to resolve the error message: CAUTION: Take care in using the following steps.
  1. Close iTunes and any other files and software that are open.
  2. Click Start , My Computer , Drive C: , Program Files , iTunes , and CD Configuration to view the files in the CD Configuration folder.
  3. Locate the file gcdrtype.cfg in the CD Configuration folder.
  4. Right-click the file gcdrtype.cfg .
  5. In the drop-down menu, click Open (you may need to select Notepad ) to edit the file gcdrtype.cfg in Notepad .
  6. In the Notepad window, scroll to the bottom lines of the file gcdrtype.cfg .
  7. Locate the line that reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05
  8. At the end of this line add " | NOSENDOPC " (the first character is a blank space), so the line then reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05 | NOSENDOPC
  9. At the top of the Notepad window, click File , Save .
  10. At the top of the Notepad window, click File , Exit to close the window.
  11. At the top of the CD Configuration window, click File , Close to close the window
  12. Restart the computer.
You should now be able to burn an audio CD without displaying this error message. ---------------------------------------------------------------------------------------------If this answers your question please rate this as fixed.
Thanks for using fixya support..You have a wonderful day
Jun 03, 2008 | Samsung SH-S182 DVD±RW Dual Layer Burner
Epson stylus r300
Hi Chillyslade,
Try this..
Close the CD/DVD guide, then press the font28.gif maintenance button.
If the CD/DVD tray is inserted, remove the CD/DVD tray, then close the CD/DVD guide
Hope this works, kindly let me know by providing your valuable rating.
Thanks,
Robosoft.
Jan 04, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus Photo R300 InkJet Printer Logo
709 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
