Question about Century Versaflex Stretching Machine From Sporting Goods
Directions for assembly - Century Versaflex Stretching Machine From Sporting Goods
Dont have directions for assembly
This is the closest I could find to your model, hope it helps you with assembly...http://www.elitescreens.com/images/pdf/userguides/user_guide_ezframe_seriesrev010410-ja.pdf Follow the directions here to assemble yours...they should be similar
Jun 24, 2012 | Elite SCREENS ER110WH1 SABLE FRAME SERIES...
How do you change a parking light?
front: pop hood, look behind the lense for the assembly. twist and remove the assembly. twist bulb out of holder. put in new bulb. put back in, twist into place (opposite direction).
rear: pop trunk, may need to remove a panel to reveal the assembly. same directions.
Sep 18, 2010 | 2005 Mazda 6
How do you access and replace directional signal bulb
Hello my name is Ben. You must first remove the headlight assembly since the directional signal is underneath it. Raise the hood and you will see two gray colored rods on top of the headlight assembly. Release those rods by rotating them forward and pull them straight up. Now you can remove and unplug the headlight assembly to remove it. You will now have access to the directional signal bulb. I hope this helps with your repair, Ben.
Aug 28, 2010 | 1999 Chevrolet Silverado 1500
Instructions to replace door lock assembly
Hello,(1)Open the door and remove the two screws in the door lock latch plate on the edge of the door by backing them out with a Phillips screwdriver in a counter clockwise direction.
(2)Remove the two screws (located on the interior lock face plate)holding both halves of the lock assembly to the door by backing them out with a Phillips screwdriver in a counter clockwise direction,pull each side of the lock assembly from the door,using a flat blade screwdriver to pry them off if needed. (3)Pry the latch bolt out of the door by inserting the edge of a flat blade screwdriver under the latch plate on the edge of the door.slide the latch assembly out and set aside.(4)Insert the new latch assembly into the hole left by the old latch bolt.Trim the recessed opening with a sharp chisel if the new lock latch plate is larger than the old latch plate.Secure the latch to the door with the two screws provided by turning them in a clockwise direction with a Phillips screwdriver.(5)Hold both side of the new lock assembly to the holes in the faceof the door.Line up the shaft from the lock cylinder into the slotted hole in the latch assembly.Make sure the lock face plate with the screw holes is facing the inside.Attach the lock assembly to the door by turning in the screws with a Phillips screwdriver in clockwise direction.(6)Remove the old striker plate from the door jamb by backing out the two screws with a Phillips screwdriver in a counter clockwise direction.Install the striker plate that came with lock kit with the screws provided using a Phillips screwdriver in clockwise direction.
(7)Close the door and test the operation of the lock from the inside and outside using the turn lever and the key.Make adjustment to the striker plate if needed by removing the holding screws.Reposition the striker plate and replace the screws
Thanks
May 26, 2010 | Ovens
No assembly directions
Here is a link to a website with the assembly instructions. You can view it as a PDF or HTML...depending on your internet connection. Hope this helps ya.
Assembly Instructions
Jan 17, 2010 | Fitness Quest Ab Lounge Ultra 1ea
Machine makes loud grinding noise and the drum will not spin.
Ok, your direct drive system is experiencing gear breakdown issues. the transmission(gearbox) is stripped and causing the grinding situation. The clutch is ruined as well. you may have some minor electrical motor trauma as well. i recommend disassembling the unit if possible, to inspect the direct drive and transmission/clutch assembly. you should see the drive/transmission under the drum assembly.
Check thoroughly for trauma spots. replace the direct drive assembly if damage is noticed.
There should be some kind of oil leakage around the drive assembly. inspect the motor as well.
If the motor is not smoking or humming, it should be fine. More than likely, it will be the drive and transmission assembly that will need to be replaced.
Please rate and have a great day:)
May 13, 2009 | Fisher Paykel EcoSmart GWL15
Assembly directions
Looks simple enough to me . Lay out your bottom pieces first then assemble your a frames. Set the a frames onto the foot rails. Then start attaching your tin or canvas what have you.
May 10, 2009 | Heating & Cooling
Assembly Directions
Found the directions in my son's room.
Jan 19, 2009 | Meccano Erector 40 Model Set
Seiko Watch band Adjustment
hi. you have to push or hammer the pin out in the direction showen by the arrow, so the arrow is dis-assembly direction.
May 21, 2008 | Seiko Diver's Watch
Crib assembly
I need direction for crib model172097350 from Simmons
Sep 13, 2006 | Pali April Crib
Century Versaflex Stretching Machine From  Sporting Goods Logo
293 people viewed this question
Top Century Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Century Cycling Expert? Answer questions, earn points and help others
