Question about Xerox C2424 Copier
The Scan head belt broke in our C2424. Where can I get a replacement- technician said we have to order the entire scan head for $500 but all I need is the belt. (No Warranty)
    Director Badge:
    Uploaded 100 video answers.
  • 160 Answers
Yeah, Xerox doesn't spare that part. Item Inc offers this part refurb for $350, or $300 if you send them your broken one as exchange. Here's a video of how to replace it. Good luck
Posted on Feb 24, 2011
  • Steven C
    Steven C Feb 24, 2011
    CORRECTION - Xerox doesn't spare the belt, you have to replace the entire scanner assembly, Item Inc offers this part refurb for $350, or $300
    President:
  • 2,072 Answers
Yep, thats about it. Xerox spares almost nothing on that machine except entire units. I looked on E-bay and no scanners, just a few old machines for sale.
Posted on Oct 12, 2010
How do you fix blank copies on a canon ICD 1320?
A scanners is made up of the following basic hardware: (that is, as long as it is of a CCD design)
1.) The scan head, which contains a lamp (could be a standard fluorescent type, a cold cathode fluorescent type, or xenon type),
2.) Mirrors (two or three depending on manufacturer design),
3.) a lens,
4.) a color filter,
5.) a Charge-Coupled Device (CCD);
6.) a step motor which operates the scan head through the use of a 7.) belt,
8.) gears,
9.) and a stabilizer bar.
10.) the power supply;
11.) control circuitry;
12.) and interface ports (parallel, scsi, usb, or firewire)
Then there is the software driver- necessary for the computer to communicate with the scanner. The common language most scanners use is TWAIN. This driver acts as an interpreter between any software application that supports the TWAIN standard and the scanner; like Adobe Photoshop or Acrobat, and others.
There is also firmware (permanent software programmed into a read only memory chip)
And any additional software that came with the scanner (i.e. scanning utility and an image editing application)
Any of which could necessitate updating.
The other design type of scanner is the CIS- Contact Image Sensor. The hardware difference between this and the former is in the image sensor mechanism. It replaces the CCD scan head altogether. Instead, the CIS uses rows of red, green, and blue L.E.D.s and image sensors (between 300 and 600) that cover the entire width of the scanner glass; so when an image is scanned, the LEDs combine to create a white light and the illuminated image is captured by the row of sensors.
I would surmise, based on the limited info you posted, you may need to replace either the lamp or the entire scan head. But to be sure, you'll need to obtain the service manual for your printer/scanner and go through the troubleshooting procedures to evaluate the condition of the scan head.
Feb 27, 2015 | Canon Office Equipment & Supplies
Xerox C2424 mpc tray 1 is broke and flops down
You will need to buy the entire front door, part number 200-4678-80. It includes the door frame and the part that folds down.
It is easy to install. Just flex the plastic.
Whit Item, Inc
Nov 22, 2010 | Xerox C2424 Copier
The wiper blade is stuck to the print head of my xerox c2424 printer. how do you take the ink cartridge tray out to get to the print head. i have it torn down that far...bonnie
The printhead and wiper could be heated to soften the ink.
Enter Diagnostics by holding the back arrow and "i" button while powering up. Go to the Monitor menu and turn on "All Heaters"
After a few minutes, it should be able to be moved away.
This situation may have broken 2 Camshafts and perhaps even motors. If you continue to get an error 07,010 then buy this kit "C2424-Z2" It may require a technician to install.
Whit
Item, Inc.
Oct 01, 2010 | Xerox C2424 Copier
I have the message "Unlock scan head" when I turn the screw to the left to unlock it, I get the same message. Is there anything else I should be doing?
If you receive this error even after unlocking the scanhead xerox suggests replacing the scanner assembly. Item Inc offers this part on exchange for much cheaper then xerox. Here's a video to show you how to fix this error/replace the scanner.">
Aug 05, 2010 | Xerox WorkCentre C2424DN All-In-One Laser...
Scaner belt broken need diagram
Yeah Xerox does no spare this part, you need the entire lower scanner assembly (109K01870). Item Inc offers them in exchange for pretty cheap compared to Xerox prices. Here's a video to show you how to replace it. Good luck!">
Nov 16, 2009 | Xerox C2424 Copier
The printer is making a gear clicking sound.
I had exactly the same problem with my OfficeJet 6110 as reported above (i.e. the scan head not knowing where the end-stop is). This is how to fix it (this method worked for me) 1) Lift up the scanner/copier hinged lid. Around the edge of the scan glass are 4 Torx screws. Undo all four screws. 2) Carefully prise the control panel faceplate off. The buttons underneath are on a single panel. Slide this to the left and lift off. 3) Jiggle the lid of the scanner to get it off the main body of the printer. 4) Locate the scan engine motor (top right corner) and remove the two motor retaining screws (one on the left of the motor, the other on the right). 5) Lift out the entire mechanism (rod, drive belt, scan head) and turn over. 6) Thoroughly clean all glass and mirrored areas of the scan head. Also clean the scan lamp on the top of the scan head. Clean the tray inside the scanner (where the scan head travels back and forth). Also clean the inside and outside of the scanner glass pane itself. 7) Refit all parts, using the technique described above, in reverse order. 8) Switch on printer. It should now work OK. Hope this helps, guys.
Jun 02, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Linux or Mac OS X support for Scanning
You need to download the correct drivers for the OS.
You can go to this link:
http://www.support.xerox.com/go/results.asp?Xtype=download&prodID=C2424&Xlang=en_US&Xcntry=USA&source=XOG
And download drivers from there according to your OS. Please Select proper OS otherwise you will be downloading Windows by default. On this link there is also utility programs free and so forth; you might find something useful.
Please Rate :) Porfavor
Oct 02, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Workcentre c2424 Scan - Won't find me so I can scan to personal images
It seems somehow your address was deleted. Recreate the box on the machine and it should be ok.
Mar 29, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox workcenter c2424 error code 39,014.40;33151
Could be a dirty scanner. Not much to check, it is a lamp issue.
You can try disconnecting the cables to the document feeder and scanner. The one on the right side of the machine, where the power cord, thats is odd to access and tighten often works loose.
Here is the entire documentation troubleshooting procedure, this is from the service manual.
Step Questions and Actions Yes No
1 1.
Cycle power to the system to clear.
2. Did the error recur?
Replace the Complete.
2 1.
2.
3.
3 1.
Are the lamps on?
2. Run the diagnostic test:
Go to Step 3. Replace the
lamp(s).
4 1. Is the scan head in the home position? Replace Replace
Mar 28, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox C2424 Copier Logo
215 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
