Question about HP Pavilion dv6000z Notebook
HP G60 laptop will not start. 2 weeks ago the charger stopped working so I replaced it. All was fine then the battery stopped charging, even though the power led was on. The battery icon appeared as if it was not on charge. The battery went flat and now it will not start even with the power plugged in and switched on
  • 2,567 Answers
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether
Posted on Oct 12, 2010
Testimonial: "Very detailed reply thank you. I know where to start now."
Why will the battery not charge?
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
Nov 27, 2012 | HP G60-120US Laptop
I have a hp g60, i have a really weird issue. Some times my laptop stops charging suddenly and the small led next to my charging input slot does not show any light. I checked my charger its showing...
Kind of vague. It could be the port on your laptop where the charger plugs into. It could be bad, or could have a bad connection to the motherboard due to use or manufacturing defect. When the charger stops charging then it has to use the battery power. This morning the battery may have had a low charge causing the laptop to shut down. Did you notice the battery's power level before it shut down? If you are wiggling the end of the charger that is plugged into your laptop to get it to start charging again, then that is most likely your problem. Do not wiggle it , for it could fry your motherboard. If that is the case then that port needs to be re-soldered.
Jan 24, 2011 | HP G60-230US Notebook
My HP g60 will not charge when plugged in.
First try to use your charger on another laptop to see if it will work, if it does not, then it means your charger is faulty and needs replacement.
If your charger works fine, then it is the charging port of the laptop that is bad and needs replacement, have a repairman resolder it back or replace it for you and it will be in good condition once again.
Take care and good luck
Oct 15, 2010 | HP G60-120US Laptop
My Hp g60 laptop battery is not working
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all.
OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time.
If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Mar 24, 2010 | HP G60t Notebook
Not charging
No, there is nothing wrong with your charger. Its a voltage irregularity problem. Once it happens next time, remove the charger, remove the battery, put the battery back and try again.
I use HP 530, and I experience the same problem once in while but not every time.
Good luck.
Mar 17, 2010 | HP Pavilion g60-440US Notebook
My HP G60-235dx will no longer power up. The
Remove the Battery and connect the AC Adapter it charges fine than Battery is Faulty replace the Battery if the Notebook is is less than 1 year old than get the battery replaced by HP for free under standard warranty if still the problem than try another Known good AC Adapter if the problem persists than send the Notebook to HP for the bench repair to repair the Notebook from HP under warranty
Oct 11, 2009 | HP G60-235DX Notebook
My hp 6715s laptop wrecks chargers, im on the 6th
2 possibilities
Either unstable AC current in the house (Generally, other items that have AC adapters would be failing too)
Motherboard charging Circuit issue (Motherboard replacement)
Sep 14, 2009 | Computers & Internet
HP Wireless "working" but it won't connect to networks
I had a similar problem with my HP g60-243cl and new drivers solved the problem. I also have to turn off wireless and turn it back on a couple times if I switch networks.
Apr 09, 2009 | HP Pavilion G60-120US NoteBook
HP Pavilion dv6000z Notebook Logo
409 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
