Question about Maytag Washing Machines
I own a neptune front load washer the water does not shut off in washer
    President:
  • 1,294 Answers
You simply have to change your water inlet valve; easily done. Note: too little pressure in the faucet can also cause a leak.
Posted on Jun 01, 2008
I have a Maytag Neptune MAH 6700 AWW. It is shutting off and giving error code tE. Customer service does not recognize the error code. Can you help?
This is a problem with the signal from the water heating element "Thermistor" a Thermistor is a solid state sensor that senses temperature, in this case water temp. The Thermistor is part of the washers water heating assembly and not sold separately from it. There is a factory repair bulletin associated with the problem and the new part has improved reliability. I can't understand what the Maytag folks you called would tell you it is not listed, it is a common fault in the Neptune. Please rate my help. Thanks
Jan 23, 2012 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune front load washer keeps shutting off during the wash cycles. Any idea as to what is wrong and how to fix?
my matag neptune front load washer keeps shutting off durning the wash cycles,and the letters LP keep appearing.Any idea as to what is wrong and how to fix it?
May 01, 2010 | Maytag Neptune MAH5500B Front Load Washer
Sometimes there is water that fills in my washer after I use it. It does not happen right away but by the next day. I don't know the model but I do know this is an old washer....gold....I have had it for...
Q - My washer seems to keep filling  with water, the water keeps coming in the washer and going out the drain without the washermotor running.
A - This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
  1. Boot change helps
  2. Consumer Display Code Table on the Electronic Display Maytag Neptune Front load washer
  3. Free on-line repair manual for the Neptune washer MAH3000, MAH4000, MAH5500, MAH7500  ( Acrobat reader required )
  4. How to access the console on the mechanical timer models
  5. How to access the workings of the washer
  6. My washer door is locked and it will not open up...HELP
  7. My washer will start when I push the start button, but a few seconds later, it will shut off
  8. My washer will not pump out + pump noise problems
  9. My washer will not spin
  10. Odor complaints from the front load Neptune washer - mildew complaints + a new "freshen up" procedure
  11. Parts breakdowns/exploded of the Maytag Neptune front load washer ( mechanical timer models )
  12. Problem chart for MAH3000 & 4000 Neptune washers
  13. Readers repair tips
  14. Trouble shooting tips from the Neptune manual for MAH3000 and MAH4000 models
  15. Tips from our friendly engineer on changing the boot and re-installing that clamp and spring
  16. Tips on changing the washer belt  ( acrobat reader required ) Belt parts link
  17. Tips that show what components need to be checked/replaced if a certain resistor on machine control board is bad. It is as follows: Burnt resistors in Maytag Neptune washer models MAH4000 and MLE/MLG2000
  18. Washing one item in a front load washer
Apr 01, 2009 | Maytag Washing Machines
Maytag Neptun will not agitate or spin
Change your timer. or timer sensor. behind your knobs
Feb 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
F-h is the problem magtag neptune front load
fh is a NO WATER fault, check your incoming water supply, watch out some new stainless steel inlet hoses marked" floodsafe" are imfamous for shutting water supply, if you have these hoses i strongly reccomned replacing with "NORMAL stainless steel inlets" FLOOD SAFE brand no good
Jan 21, 2009 | Maytag EPIC MFW9700S Front Load Washer
Maytag neptune stackable washer dryer stopping
Maybe a water fill problem ,washer will stop if no or not enough water enters the tub in a given time
Dec 04, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Neptune washer front load may4000awq
Check your washer belt has not slipped off.
Just so you know thats not the problem.. Ours went ga ga and it was only the belt!
:o)
Aug 03, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer
Maybe you over-loaded, or you did not shut the door properly. Try reading the users' manual.
Mar 12, 2007 | Maytag MAH6500 Neptune Front Loading...
Washing Machines Logo
24 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
