Question about Cameras
When the camera was turned on, the display area just suddenly shut down, the shutter didn't close. The battery was tried to another camera and it worked well.
    President:
  • 4,070 Answers
Hi! The circuit board of the camera surely gone bad, you will need to visit a reputable technician for this will require an on hand fixing for sensitive parts and circuits are at risk. Hope this helps and thank you for using FixYa!
Posted on Oct 12, 2010
My camera says..lens error will shut down automatically restart camera..! so my lens wont close even when i turn my s100 on or off. please help???
Make sure there is no dust or foreign material that could be jamming the lens and lens shutter. Have you tried removing battery or battery pack or try to reset camera? Just a suggestion.
Oct 02, 2013 | Canon PowerShot S100 Digital Camera
I have a Cannon PowerShot S2 IS digital camera, about 5 years old. The LCD Monitor and Viewfinder both only show a black screen with some of the Dispay Icons across the top and bottom, and after a few...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 06, 2011 | Canon Cameras
Black screen
First try pressing the DISP or DISPLAY button. If that didn't work, have you tried downloading the photos, and are they also black? If so, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. Finally if the photos are fine, and it's just that the screen is black, then it's likely just a loose ribbon cable connector to the screen. In that case, you would need to opne up the camera to reseat the cable.
Mar 15, 2011 | Canon PowerShot SD750 / IXUS 75 Digital...
Black lcd screen
First press the DISP or DISPLAY button to make sure that you just didn't accidentally turn off the screen. Next, have you downloaded the pictures it takes, and are they also black? If so, A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Feb 12, 2011 | Canon PowerShot A620 Digital Camera
My display screen is black when I go in camera mode, how can I resolve that problem
First try pressing the DISP or DISPLAY button to verify that you didn't accidentally turn it off. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Nov 07, 2010 | Canon PowerShot SD1000 Digital Camera
LCD monitor is not working ( the photo taken is not displayed on the LCD screen whereas other details like AUTO, S/L/M, no of photos can be taken are displayed) pl. help
One of two possible things. First try pressing the DISP or DISPLAY button on the back of your camera. This manually turns the LCD screen on and off to save batteries. You would then use the optical viewfinder in its place. If this doesn't fix the problem...
Aug 08, 2010 | Canon PowerShot A580 Digital Camera
I am not getting an image either through the viewfinder or on the LCD monitor. The display is clear and bright and the batteries appear to be fine.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 26, 2010 | Canon PowerShot S2 IS Digital Camera
My Canon Sd1000 will not take pictures. You can
Note that your camera does not have shutter priority mode (Tv) as listed in the link. Instead, put the camera in manual mode and turn off the flash, and also turn off the LCD display (press the DISP button). With these settings, try the fix in a darkened room, opening the battery door immediately after taking the picture. Give it several tries, if no luck consider also trying step 5a described in the link.
Dec 29, 2009 | Canon PowerShot SD1000 Digital Camera
Camera shuts off after hitting the shutter button
Your fix could be as simple as cleaning the camera's battery contacts, or it could be something more serious and expensive. Before you pay for expensive repairs that you may or may not need, check the Kodak Help Center by clicking on the link below. It uses a simple Q&A format to diagnose problems and propose solutions.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Jul 21, 2009 | Kodak EasyShare DX6440 Digital Camera
Suddenly turning off...
all figured out,,,,the shutter button is too close to the shut off button,its happened to me many times ,next time it happns try to catch yourself and see which button you pressed,,guaranteed!!! it sucks
Apr 20, 2008 | Fuji FinePix A345 Digital Camera
Cameras Logo
18 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
