Question about Garden
I have a wall fountail run via a versa gold series model g210 pump @ 115v. 60hzof4. it recently stopped working. is there something i can do before i replace it?
  • 22,156 Answers
Not really it has two chances it works or it doesnt ,eventualy the motor will wear out which is what i think has happened in this case
Posted on Oct 12, 2010
Running pump stopped
I assume that the plug in is working properly. Always check power supply first. Is there a GFCI circuit that it is plugged into. Then check the pump to make certain it us turning. How long had it been on before unplugging it. It could be worn out. Sometimes it takes a jolt to start the motor again. How big is the motor. Possible bad capacitor. Could be a solid state motor, then it's bad. Is it a magnetic motor, that could be turning the wrong way.
May 16, 2014 | NEC Versa Gold Submersible Pump
I have an whirlpool gold ad50gpusb from canadian tire. The pump will no longer pump via the clear rubber hose and instead the water accumulates in the bucket. Do you know if there is a simple fix to...
For the others who follow
I have the same model, same problem on a 2 year old purchase made in 2014. This unit has a pump (and a hose) to drain the condensate.
The pump light started blinking about a week ago, turning cycling power worked for a while, until pumping stopped altogether.
After investigating:
-the hoses are not blocked but there was some algal growth in the tray which I cleaned
-the pump no longer pumps.
-my favorite parts suppliers and other on-line sources have no record of the model/parts etc.
-Called "whirlpool" consumer line in manual
-Whirlpool has been purchased by Garrison and that company has no parts for this discontinued model but did provide a phone number for the pump 800-799-0991. Unfortunately the cost of this small solenoid pump is $74.
I will drain the condensate via gravity to a floor drain as I don't see spending that much for something that broke so quickly and appeared poorly made..
Sep 24, 2013 | Dehumidifiers
My Friedrich QuietMaster Series KS15L10 115V model will being to blow cold air and then after 5 to 10 minutes will trip the circuit breaker. We recently had a heat wave for about 2 weeks in which the unit...
Hello
Yes the northeast had temps that went past the limits of modern a/c.
Try cleaning the outside fins and coils.
Spray a product called simple green on the fins while unit is off.Leave on for 5 min.
Then rinse off with a hose.
This should keep your compressor running cooler.Also clean any filters in the inside unit.
Aug 03, 2011 | Friedrich QuietMaster KS15L10...
Water stopped running in house, I was running hose for about an hour and water justed stopped. reset breaker and still no water
take the screws out of the bottom of the pump maybe sand in the impeller.that pump s/b off the bottom of the pit on like a brick or something
Apr 22, 2010 | Goulds Pumps Goulds 1/3 Hp 115V 1 Phase...
The VCMA-20ULS pump is not shutting off
These pumps have a float arm inside that tell the pump when to turn on and off, it sounds like your arm is stuck or broken. The top of the unit can be taken off of the reservoir to check for damage.
Good luck
Sep 29, 2009 | Little Giant 115V 60Hz Condensate Removal...
I have versa gold submersible pump, it works intermittently. There is enough water in the pond and it is submerged
Intermittent running usually points to intake or impeller obstruction. Remove the impeller screen and cover, inspect the impeller, the screen the discharge exit point for debris. Unlike other brands the impeller is not replaceable if worn or damaged.
Jan 25, 2009 | NEC Versa Gold Submersible Pump
Kenmore 80 series. RUNS LOUD, THEN TURNS OFF AND RESETS...
you have something gotten into your pump ,,, it trys to drain and spin but overloads the motor and shuts down till the motor switch resets .... remove the pump and take out whatever gotten in it and if that not possable replace the pump.
Nov 24, 2008 | Kenmore 24032\24036 Top Load Washer
Garden Logo
108 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
