P4M800P7MB RS2H Foxconn motherboard and 2G memory upgrade
Please help
I've got the following:
CPU name: Intel(R) Celeron D CPU 2.66GHz
Motherboard model: P4M800P7MB-RS2H
BIOS Name: Phoenix- Award V6.00 (584F1P12)
Memory device: 512M DDR2
OS:Windows XP Home+SP2
I've got two 512M DDR2 RAM in the memory slots at the moment.
I replaced it with two 1Gb DDR2 800's , but it registered only as 1Gb total memory with both cards in position. When I removed one of the 1Gb cards, it registered as only 512Mb memory. I got the same results with the other 1Gb card.
According to the motherboard's manual is support up to 2Gb. It also support DDR2 533/400. The shop where I bought the 2Gb's said it will work with the motherboard, but the speed will not be 800mb, but 533mb which is understandable.
The PC boot normally and so does everything else, except that the RAM is only 1Gb where it should be 2Gb with the two 1Gb cards.
  • Jackh3 Jan 08, 2009
    My problem is similar. I bought 2 Crucial 1Gb Memory Modules which they say are suitable for the Foxconn motherboard. Ref no 1GB 240 PIN DIMM 120Mx64 DDR2 PC2 - 5300 UNIBLUE. When I installed the two Modules to replace my 1 512Mb module the computer just gave long beeps and refused to start. I relaced the single 512 module and all was OK. When I then installed 1 of the new 1Gb modules in slot 2 the computer booted up and reported 1Gb of memory. Crucial suggest it is a BIOS problem from your post from diffie I'm not so sure!!
The 1gb memory modules need to be low-density ie chips on both sides. the motherboard can only recognise 512mb on each side of the memory module.
Posted on May 14, 2010
I went back to the shop where I bought the RAM - they haven't got slower RAM. There they replaced these two DDR2 1Gb 800 with equivalent RAM. The only difference being the set causing the low RAM value of 1Gb is a Samsung make and the the set of which the total RAM is 2Gb, is a Transend make. Everything is working now 100% ok
Posted on Jun 07, 2008
La maloz bios güncelleme yapılacak...
Posted on Aug 04, 2009
  • 326 Answers
U'll have to keep the speed of the ram within the limits of the processor. Exchange the new ram for the slower ram and it will be 2 gb.
Posted on Jun 01, 2008
Problems with new ram
This = NO
The Foxconn P4M800P7MB-RS2H motherboard supports ram memory that is either 400MegaHertz, or 533MHz.
You have installed 667MHz ram memory.
You also need to watch the Front Side Bus (FSB) of the processor you are using.
Ram memory typically operates at HALF of the FSB of the Processor.
Processor FSB support is 800MHz maximum.
Half of that is 400MHz.
You CAN use 533MHz ram memory, however.
(This is DDR2 Sdram ram memory.
PC2-3200 is DDR2 at 400MHz.
PC2-4200 is DDR2 at 533MHz. (Also known as PC2-4300. Depends on the ram memory manufacturer.
PC2-3200 actually operates at 200MHz. { Max} It is 'Dual Pumped'
PC2-4200 actually operates at 266MHz )
What to do?
Hopefully you saved the carton/s the ram memory came in.
Ship them back, get the ram memory you need.
What is the FSB of the Processor you have installed?
Don't know?
Post back in a Comment as to the model name, and model number.
(Example; Intel Pentium D model 805,
FSB support is 533MHz
No, you cannot use 533MHz ram memory. { PC2-4200 }
PC2-3200 is the max.
Pentium D model 820 for example, you can )
Nov 18, 2011 | E-Machines Computers & Internet
Characteristics of n15235 manual motherboard
- Intel® Pentium D, Pentium® 4, Celeron D processors, Socket T (LGA775)
- 533/800MHz front side bus (FSB)
- Single channel DDRII 533 / 400 x2 DIMMs
- 1 x AGP 8x, 3 x PCI
- ATA x 2 + Serial ATA x 2 w/ RAID
- 5.1 channel Audio, AC'97 interface (Realtek)
- 10/100M LAN (Realtek)
- 8 USB 2.0 ports
Also, if you need drivers for all that components, use this tool:
Sep 16, 2011 | Foxconn 6627MA-RS2H Motherboard
Need to know how to connect foxconn cn15235 switch on cable as well as the other loose cables' Find no markings on the mother board'
You can download manual on this page:
your motherboard model is P4M800P7MB-RS2H
If this helps orsolves the issue, please rate it and give a testimonial for myresponse
Feb 26, 2011 | Intel Foxconn Motherboard
Need to get a heatsink/fan assembly for foxconn 945gz7mc-rs2h motherboard in an esystem ei305 computer.
Any of the heatsink/fan assembly provided by Foxconn will support you're CPU.
Socket LGA 775. See manual pages 7 to pages 9.
Main web site;
This motherboard supports single processor including Intel® CoreTM 2 Duo,
Pentium® 4 Extreme Edition, Pentium® D, Pentium® 4, Celeron® D processors in
an LGA775 package.
May 30, 2010 | Foxconn 945GZ7MC-RS2H Motherboard
Foxconn motherboard n15235 no viedio
That motherboard is either a P4M800P7MB-RS2 or a P4M800P7MB-RS2H, even thou it has N15235 stamped on the board. The board
Supports VGA display function (S3 Graphics UniChromeTM Pro IGP)
but, also has an AGP 8X slot. A slot that allows you to install a AGP 8X (AGP 3.0) card. A AGP 8x is the VGA interface specification that enabled enhanced graphics performance with bandwidth speeds up to 2.1 GB/s.
Hope that answers your question.
Apr 23, 2010 | Foxconn 6627MA-RS2H Motherboard
I lost cd P4M800P7MB
Is this your motherboard (check link)?
Ther you have all from your CD ;-)
See 'Related Links' from right side.
Jan 26, 2009 | Foxconn 6627MA-RS2H Motherboard
PC Motherboard Query
Hi there
This Socket 754 board will accept up to 3GB of DDR 400 memory and an 8x AGP video card
Thanks for Using Fixya
Jan 13, 2009 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Audio drivers are gone
After some searching for that MoBO i found out that the name of your MoBo is P4M800P7MB-RS2H
And here is all avaliblr drivers for it
It the window "Search by download Type" you print P4M800P7MB-RS2H, in the window bwlow you select >DRIVERS, then you will see all drivers there is for that MoBO, select them you want and download them
Good luck to you
If you find my answer helpfull, plz dont forget to vote!
Dec 26, 2008 | Foxconn 6627MA-RS2H Motherboard
Foxconn manual for a n15235
There is no Foxconn mainboard (and will never be...) called N15235 although this is printed on the board. The right name is P4M800P7MB-RS2H and you can find all stuff here: LINK
P.S.: you can find the right model number printed on the board beside the RAM slot near the CPU and on small label above.
Tom (
Feb 18, 2008 | Computers & Internet
Computers & Internet Logo
3,366 people viewed this question
David Payne
David Payne
