Question about KitchenAid Dishwashers
Does the KUDLO3FVSS2 dishwasher have a reset button? The electricity went off and then came back on in a minute. The dish washer does not work now. It's like its not getting any electricity. Its 1 year and 1 month old.
Rotu
  • 175 Answers
SOURCE: stuck on last minute
I have seen a lot of these dishwashers burn out the control board, and usually the symptom is the timer not working or inability to complete a cycle. Most of the ones I have seen, you can remove the control board assembly and its pretty obvious where its burnt. If you can do the repair yourself, the board is about $150. Hope this helps!
Posted on Oct 26, 2006
SOURCE: runs program but stops on 1 minute left and needs resetting each time
Did you manage to solve the problem with your dishwasher. I have the same model and it keeps sticking on 1 minute at the end of the cycle. Any advice please?
Posted on Sep 30, 2007
  • 298 Answers
SOURCE: top arm is not moving
Filter and rotor jets prob clogged.
In wash, the water is heated, supposed to dissolve the soap and then sucked thru a filter and pumped up the back and out the top to spray water everywhere.
Soap doesn't always fully dissolve and clogs the filter and some slimy gets thru and clogs the rotor jets.
To fix:
1. Remove Upper and lower dish drawers
2. Take off the Upper. Middle and lotwe rotors and clean their jets out with toothpick and frequent flushing (Plug a clean hole with toothpick to make water come out elsewhere) Use the sink on full blast to see if water comes out all holes.
3. Reassemble rotors.
4. Remove and clean filter. The filter is in the bottom above the Motor/pump and held in with 8 shiny hex-head or Torx screws. Take out all screws, lift out filter and clean in sink with warm or hot water from backside. Use garden hose for hard to reach areas.
5. Reinstall filter. Don't overtighten or you will crack it
6. Replace drawers
Done!
Posted on Mar 26, 2009
  • 677 Answers
SOURCE: My 4 1/2 year old Bosch dishwasher won't clean.
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Posted on Sep 05, 2009
woodchuck789
  • 4070 Answers
SOURCE: Leaving a white film on dishes.
Dishwashers have a part usually called a separator which traps the dirt from the water during the wash cycles while the water is continuously recycled to clean the dishes. At the end of the cycle the separator is flushed out and the trapped dirt goes down the drain. If it doesn't get flushed out the dirt builds up till it starts showing up on the dishes. Some separators have a hole on top and one on bottom with a valve which stops up one hole or the other depending which cycle it's running. The valve can be stuck or broken causing the problem.
Part 6 on this diagram appears to be this part on yours. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=MDB7851AWB0&productCategoryId=0130000&brandId=3048&brandDescription=MAYTAG&modelName=DISHWASHER&diagramPageId=00008&componentDescription=PUMP%20AND%20MOTOR%20PARTS&documentId=W0901031&blt=06
Posted on May 14, 2010
Dishwasher won't drain after a blockage was cleared. Is there a reset button for drain pump
Unplug the washer from power for 5 minutes and see if that clears it. Do not put food covered dishes in the washer in the future, pre rinse them to extend washer life.
Nov 19, 2016 | Dishwashers
Electrolux dishwasher control panic locked - how do I unlock? Have tried pressing LOC button for 3-5 seconds and have turned circuit breaker on and off.
Pull out the dish washer and unplug the machine for about 30 minutes. Then replugin the machine and open door. This should reset the electronics on the washer
Oct 17, 2013 | Whirlpool 24 in. ADP5966 Free-standing...
Dish washer the clean light stays on and the dish washer wont run
Hello & Welcome to FixYa
Flashing light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jul 15, 2011 | Whirlpool Dishwashers
How do you reset the spring on the door? the door falls down when opened.
just need to on do the unit from the two screws that hold the top of the dish washer in,,,make sure you have enough hose and power cord to pull the unit out just a little ways,,,but it is always best to unplug the dish washer,,,but the unit needs to be pulled out and the springs just need to be hook back on towards the bottom of the dish washer,,,always work safe,,unplug the dish washer. water and electrical never works together
Feb 19, 2011 | KitchenAid 24 in. KUDI01IL - Multiple...
Top draw 'locked' no power
try holding the power & start button down at the same time for about a minute ,if that doesnt work it must be the wiring. if it does work push the power button a few times til it goes back to the wash cycle time.
Aug 04, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Wont do anything, not even drain
Try unplugging the unit for 15 minutes then plug it back in. If that fails it sounds like the inline fuse which means you will have to pull out the dishwasher and look near the pump is blown and fuse needs to be replaed
May 26, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
''clean'' light flashing (whirlpool Dishwasher GU2300XTLS1 model)
I had the same problem recently and a repair person came to my home to fix the dishwasher. He said he had to reset the control panel. He did this simply by making sure the soap dispenser door inside the washer was closed, then making sure the main dishwasher door was closed and locked. Then he quickly pushed the Heated Dry button and the Hight Temp wash button alternately. He said each button needed to be pushed twice within five seconds. After he did this all the lights on the control panel came on, then turned themselves off before the washer went in to a test cycle. This simple reset fixed the whole problem. Works great so far.
Mar 26, 2009 | Dishwashers
Stopped working during a wash
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Feb 08, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher keeps running and countdown stalls randomly.
Sounds like The settings have messed up it happened to mine a while back you need to do a hard reset of the dish washer mine was unplugging the thing then plugging back in 30 seconds later then holding the cycle button a few seconds and then power on again. Find your hard reset combination of what your make and model of the dishwasher is I hope this helps.
Jul 16, 2017 | Kenmore 15952 Dishwasher
Dishwashers Logo
53 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
