Question about Garden
Wickes wire free alarm tamper switch keeps going off on control panel
4 Suggested Answers
  • 37 Answers
SOURCE: How can i get the tamper light to go out, so i can
Find out where the tamper fault is. This panel has tamper monitoring for external bell remote keypad zones and cover. Check all devices for loose covers ,wiring for breaks (especially if new carpets fitted) and bell box.You can check for continuety with a multimeter inside the panel you should have a short between A/T terminals and between 0v and TR if not check the wiring.
HTH
Posted on Nov 08, 2009
kdgrayson
  • 195 Answers
SOURCE: my wick control know is cracked inside and does
braze it
Posted on Dec 03, 2009
blueextc3221
  • 15935 Answers
SOURCE: kenmore elite oasis washer temp control on panel
It appears your timer/main controller/CCU has failed in this instance... and has a stuck/failed button.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 27, 2010
My car alarm keeps going off on my 1997 jaguar xj6, how can I disable it ?
not easy to just disable because it is part of the engine control system and will not start if the security system module is disconnected or tampered with but the most likeley cause is one of the door latches faulty or wiring around the trunk hinge broken/opencircuit the security system thinks a door or the trunk is open. the clue to help is check the dash warning saying door or trunk open when sat inside with ignition on and all doors etc. closed or even the hood switch
May 31, 2017 | Jaguar Cars & Trucks
15 year old micromark intruder alarm need to switch off
Not really enough info to give you an answer, but I can generalise...
You say Knocked alarm box with ladder alarm started"
If the fault is there permanently from when this happened there's a good chance that you have disturbed the tamper spring/switch on the cover of the alarm unit. when the front of the panel is removed you should be able to see the Sping/switch which is automatically depressed by this front panel, you may find the spring has fallen off the switch or gone out of alignment, refitting / realigning it should remove the tamper fault once the lid has been refitted properly. As for "bleeps when doors, windows opened"
This sounds like the "Chime" feature has been switched on and without the manual I cannot tell you for sure how to switch it off.
Chime is a feature which "Chimes" when a door is opened (Not often used on windows), if this started when the ladder fell on the panel it is most likely just a single key press to switch it off, Once the tamper fault is sorted you should be easily able to find the correct key press to turn the chime feature off.
Sorry for being a bit general but I don't have that particular manual. Hope the info helps you :o)
Mar 20, 2017 | Home Security
Hi, my house alarm ready light is not on since I opened the anti tamper box, when the box opened the alarm went off, I put in the entrance code number, the alarm went quiet, since then the ready light
Hi Terry,
Most alarm systems require you to reset the tamper alarm.
Most systems will reset the tamper simply by arming the system and then immediately disarming the system. However, you MUST make sure that the Tamper circuit you tripped is closed. If you removed the cover on the panel, make sure the tamper switch for the cover is in the correct position and that the cover is pressing the switch and closing its contacts. If you are trying to arm the panel with a cover off, the tamper circuit will not reset unless you defeat the tamper switch. Just make sure you remove the defeat when you replace the cover. You may also wish to try a google search on the type and model of panel you have so you can download a copy of the manual to check on the reset procedure. We also need to know what brand and model the panel is so we can help you further..
Nov 26, 2014 | Cars & Trucks
Turn off tamper on gardtec 350 so I can fix socket
If you are disarmed, you should only get a trouble signal when you remove AC power, This should clear when power is re-established. The tamper is a switch inside the panel that trips when the door is opened. This too should be only a trouble if the panel is not armed. (Unless the tamper is programmed for instant alarm like a panic or fire alarm input.) Check your manual for the programming instructions for bypassing or disabling the tamper. Another thing you can do is disconnect the backup battery before removing the AC power, this will stop any alarms, but you should notify your monitoring company first.
http://www.innovatealarms.co.uk/pdfs/GARDTEC350+ENGINEER.pdf
Nov 08, 2014 | Home Security
How do you wire a Honeywell FG 730 Glass Break?
2 for tamper, 2 for alarm and 2 for power. Extra wires are unused. tape off and tuck away from the terminal block.
Aug 20, 2014 | Honeywell Wired Glass Break Detector Fg...
Accenta plus alarm
If it is the tamper alarm configured by your BIOS (which you can determine by the sound's complexity--if you're hearing anything more complicated than a monotone beeping it's not BIOS controlled) I recommend restoring the default settings in your computer's BIOS setup.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/andrew_7b5641a71b84cd85
Jun 01, 2014 | Computers & Internet
Gardtec 370 repetitive bb tamper alarm
Yes any bell box will do. Just note your terminals.
you can link out the bellbox tamper from the control panel as a temporary measure until you replace the bellbox, assuming its faulty
Apr 12, 2014 | Home Security
Skylink sc-100 goes off when i input pin
The question is unclear. There are several possible cause for the control panel to go off after entering the PIN.
The control panel gives user four chances to enter the correct password. After the forth wrong password entry, the control panel will go off.
There is a silent alert command in which the control panel will activate the dialer and/or external siren alarm but the control panel remains silent. This is useful under duress condition.
The control panel has a tamper switch. If the control panel is disarmed, it will be ignored. If the control panel clamshell is opened and then the system is armed, the alarm will go off. The tamper switch prevents the burglar's attempt to remove the internal backup battery to shut down the system.
Oct 09, 2013 | Skylink Group Skylink Sc-100 Security...
I have a customer with an older Vista 100-12 Combo Burg / Fire Panel and he wantes to tie three tamper switches for PIV and OS&Y to zone 2 of this panel. Is this legal?
negative all os&y should be on their own zone. they are programmed differently. A panel tamper is just a tamper alarm supervisory alarm.
Apr 09, 2013 | Honeywell Ademco Vista-100 Fire And...
How can i get the tamper light to go out, so i can reset my alarm on the cooper menvier 9448+ alarm control panel
HTH
Oct 06, 2009 | Kitchen Appliances - Others
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
