Question about Craftsman 20 hp 42 in. Deck Yard Tractor
After about 30 minutes engine will start surging, by partly pulling the choke out it will run better. The carb has been recently rebuilt as well as new filter and fuel line to carb. Tried different fuel cap as well. My next idea is to replace or clean gas tank and replace fuel line to fuel filter. This a 20hp.42inch briggs engine. The tractor seams to run fine right up to the 30min. time. Is there anything else I should look at or am I on the right track with the gas tank.
  • 110 Answers
Typically a surge is caused by a lean condition. I'd say the float is set to low and this is causing the engine to lean out & when you apply the choke it richens it back up.and the surge stops.
Posted on Oct 23, 2010
1986 mercury 45 clasic 50/actslike its not getting fuel when you try to start /just had it serviced carbs rebuilt.etc.
Sounds like a dealer issue. Not sure if this engine has a choke plate or a fuel primer system. Checking the operation of the "Choke" or "Primer" system would the first to check. I also believe that the synchronization of the engine's timing to carburetors is not correct. Throttle plate should be completely closed at idle and there is a specific adjustment for maximum timing and throttle opening.
Oct 22, 2014 | Boating
Kohler engine troubleshooting
If you can keep it running with the choke pulled out or partially pulled out I would check to see if there is a fuel filter on the machine and most likely you have a carb problem and it is gummed up and needs to be rebuilt.
Jul 04, 2014 | Poulan Garden
Engine starts runs well but after 45 minutes or so will die . I can choke as it starts to die and engine will continue running.When it dies will restart easily.Ihave replaced gas filter ,cleaned tank,new...
Carb. needs to be rebuilt. If your choking the engine it to keep the alive and you've cleaned and replaced everything else, I would recommend carb. overhaul.
Sep 23, 2013 | Garden
Engine idles excesivly high after carb was rebuilt.
You need a new choke pull off. They are around $30 dollars.
Dec 09, 2009 | Ford F-250 Cars & Trucks
Governor keeps surging fast and then slow
Check to see if the engine runs smooth will slowly pulling choke out. if it runs better without surging, then its a carb problem.
Also may have an air leak in carb gaskets
Nov 20, 2009 | Craftsman Garden
Yamaha TW 200 starts but won't run.
If the bike has sat for a long period of time without being run - the gas that is sitting in the carb(s) will shellac.. Then the carb(s) would need to be cleaned and "rebuilt"..
Sep 14, 2009 | 2001 Yamaha TW 200
Running poorly
Not much to go on, but I would say carburetor issue. Have they ever been rebuilt, have they been balanced recently?
You can look at a manual here, hope it helps you - http://www.texaschapteru.org/GWServiceManuals.htm
Jan 09, 2009 | 1983 Honda GL 1100 Gold Wing
Craftsman 20 hp 42 in. Deck Yard Tractor Logo
416 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
