Question about Athearn Toys
I need help with a question. I have a Genesis Challenger 4-6-6-4 i would like to put a smoke unit in but which one, in the book is says seuthe #9 or #10 what is the part numbers for each unit? Model trains Athearn
2 Suggested Answers
What is maximum wheel size that can be used on merits challenger scooter
Only the stock size.
Merits Challenger Three and Four Wheeled Scooters - Independent ...
ilcaustralia.org.au/products/5611
Nov 30, 2016 - A rear wheel drive scooter with rear suspension, suitable for outdoor use. It is available with three or four wheels. Closed loop handles allow ...
Merits Parts - All Mobility Brands - Mobility Scooter and Power Chair ...
www.monsterscooterparts.com/mobility/mobility-brands/mehepr Merits Atlantis (P710/P7101/P7102) Power Chair Parts. ... Monster Scooter Parts carries Merits parts for all models, including scooter and power chair replacement battery chargers and battery packs. ... As an authorized Merits parts dealer, Monster Scooter Parts can help you find just the ...
Merits Health Products - scooter, power wheelchair, manual ...
www.merits.com.tw/ Merits is the professional manufacturer of health products. We specialize in scooter, wheelchair, home care bed, accessibility, patient aids and other home ...
Merits Challenger 4 Wheeled Scooter - Assistive Technology Australia
https://at-aust.org/items/6176 Nov 9, 2016 - Merits Challenger 4 Wheeled Scooter - UNAVAIL (Deleted). Learn More. Approximate Price: $4350. No supplier. (0 suppliers). For information ...
[PDF]Merits Pioneer 3 and 4 Owner's Manual.pdf - Scootaround
https://www.scootaround.com/.../merits/Merits%20Pioneer%203%20and%204%20Ow... Congratulations on the purchase of your new Pioneer 3 or 4 power scooter. We at ... tiller assembly, battery charger, and owner's manual. Contact ... Wheel Size.
maximum wheel size that can be used on merits challenger scooter Google...
Apr 05, 2017 | Health & Beauty
What is the mechanical fuel pump pressure supposed to be for a 1970 340 6-pack T/A Challenger?
Hello Steve Lemke,
My guess would be you are all EXQUISITE if you are at
6 PSI & 20 to 30 GPH @ 1800 RPM.
That was the red engine, not the blue... I have THE FACTORY books buried in the basement...
I've seen two: 6 to 7.5 (not to exceed)
and
Manual pump pressure (psi): 4 to 5.5 psi
Hope this helps.
http://www.rockauto.com/en/catalog/plymouth,1970,cuda,5.6l+340cid+v8,1231726,fuel/air,fuel+pump,6256
http://www.rockauto.com/en/catalog/dodge,1970,challenger,5.6l+340cid+v8,1078433,fuel/air,fuel+pump,6256
Incorrect flow rating (pretty sure):
More Information for CARTER M6866
Nov 26, 2016 | Dodge Challenger Cars & Trucks
My hard wired smoke alarm has had a new 9 volt battery installed and even a second new one installed and is still chirping 4 times every 30 seconds.
On many of the newer smoke alarm installations, all of the units are wired together so that if one goes off, it triggers all of the others so that no matter where you are you will definitely hear the maddening noise of the alarms! And if one of the other units has a bad or weak battery not only will it chirp but so will the others.
Only way around this is to cut any and all wires going to each smoke detector. They will still work because each has its own battery but there will be no more triggering of other units.
Oct 27, 2016 | Cars & Trucks
How do you hook a sega mk-1631 to a hd tv?
Close to the power supply input is a 9-pin round connector.
You will need a cable that connect this output to your TV.
You can find the description here:
http://www.gametrog.com/GAMETROG/SEGA_Genesis_1_2_3_Information_Specs.html
Halfway the page you will find the description of the MK-1631 with details about the cable you need.
There is a picture of the cable here:
http://www.gametrog.com/GAMETROG/How_SEGA_AV_Audio_Video_Cable_RF_Box_RCA_Composite_S-video_Component_HD_for_Genesis_CD_32x_Saturn_Dreamcast.html
You can also google for a "9-pin A/V Cable for SMS & GENESIS".
I hope this helps!
May 17, 2014 | Sega Genesis Console
Challenger A1515
It appears that Siemans, Murray, Eaton, and Square D are compatible. Look for those brands with "1515" in the part number, such as MP1515, Q1515, BR1515, HOMT1515. Challenger is presume\ably no longer in business.
Nov 13, 2012 | Challenger Circuit Breaker
I have a Mitsubishi challenger 2.8 turbo diesel Which just started smoking and when I leave sometimes the level counter is not picking up causing excessive smoke from the exhaust pipe.I don`t know what...
What is a "level counter"? I am not familiar with this terminology.
What colour is the smoke from your tailpipe? White: possible coolant leak/head gasket failure. Blue: Possibly running too rich or burning oil. Black: Burning oil
Nov 02, 2012 | Cars & Trucks
Hi, I have this Challenger 2HP pump out on the bench but can not separate the pump housing and impeller from the motor. I've removed the 3/8 bolt from the center of the impeller. And the band is off...
Take a look at this picture:
http://www.poolcenter.com/parts_pumps_pacfab_challenger_highflow.htm
Make sure you remove the mounting screws item 15 (2 ea) and item 9 (4 ea)
There are also 3 screws 120 deg apart item 12. Screw holes can be seen on item 2.
The impeller has a Locking screw item 10 that if it is not removed makes it impossible to remove the impeller.
Thanks for choosing FixYa,
Kelly
May 21, 2011 | Pentair 2 hp Challenger Pump
No sound on my sega genesis i need help on how to fix it
If you are using the 8 or 9 pin RCA DIN cable, make sure that one of the pins is not bent or missing. If you are using the RF adapter, make sure that the channel selection switch is completely on either channel 3 or 4.
Aug 02, 2009 | Sega Genesis Console
My Cobra 29 ltd classic
Hello MyPete,
You have some form of short circuit in your CB, most likley I would suspect the Power supply or the RF Power Output Amplifier. Here are some basic instruction on how to tell wher the smoke is coming from.
1) disconnect and remove your CB from your vehicle and put it on a workbench
2) remove the cover from your CB and expose the circuit board to view
3) connect your CB to an external 12 volt power source and antenna or a dummy load
4) power up the CB and determine where the smoke is coming from then turn off the power supply to the CB
5) At this point you will need a schematic of your CB (get one from www.servicemanuals.com)
6) find the point on the schematic that relates to the point where the smoke is coming from
7) using a ohmmeter determine which component and or components are shorted
8) replace the shorted and or malfunctioning components.
9) test the system (power on, transmit and receive)
10) close the unit back up
11) reinstall into vehicle
12) run tests again.
This should help
Thank you
Shutle832
Nov 01, 2008 | Cobra 29 LTD CB Radio
Toys Logo
41 people viewed this question
Top Athearn Toys Experts
Tom Chichester
ray gallant
Are you an Athearn Toy Expert? Answer questions, earn points and help others
