Question about Enterasys APC Smart-UPS 2200 XL (SU2200XLI) UPS System
UPS is not getting proper back even batteries are healthy.
  • 922 Answers
UPS batteries are only good for 2-5 years depending on their usage. I have all of my clients replace batteries every 4-years no matter what. I recommend that you write down the serial number of your UPS and call APC. They have some of the best phone support around. You can explain your problem in detail to them and they can guide you to the best resolution. ((800) 555-2725 / www.apc.com)
BTW: Enterasys is just a rebranding of an APC product so they won't be as much help as APC can.
Good luck! Please vote for my solution if it helps.
Posted on Oct 12, 2010
Can't get any power on the battery side of my ups
If you have had that UPS in service for two years, the battery could be dead in which case the issue of backup power is moot.
Jan 15, 2014 | Energizer ER HM450 (ER-HM450) UPS System
Site wiring fault
Hi Viqtah, (<------ Clever!!)
If you hit the ESC key and get to the main menu there is a Setup submenu. In there you can change the line voltage values coming into the UPS. Sometimes a previous owner will change those values and cause the UPS to fault when properly connected. NOTE: A CERTIFIED ELECTRICIAN SHOULD VERIFY ALL CONNECTIONS ENSURE PROPER PHASE ROTATION.
Reply or call if you have any more questions -- 800.260.2259
Oct 04, 2013 | APC Smart-UPS VT 10kVA - SUVT10KH2B2S UPS...
Even when it was brand new, my computer loses power even if it is not black out and my Back-UPS RS 500 blinking and cotinously beeping, and always my computer did not properly shut down. please help me to...
You need to replace the battery. Go to APC site and order the battery for your model. http://www.apc.com/resource/include/techspec_index.cfm?base_sku=br500i go to about the middle of the page, there are two models for replacement batteries. If you're not sure which one, call APCs customer support. 800-555-2725 I don't know what the shelf life is for your model but the battery usually last 3 yrs or so. Your battery is probably dead now.
Mar 02, 2011 | APC Back-UPS RS 500VA (BR500I) UPS System
My UPS burnt due to short circuit in main line. After that the UPS don't give back-up even for second. After recharging the battery and connected to the UPS, the UPS don't give power at the output from...
if there was a short circuit, chances are that its toast. get a new one. DON'T ATTEMPT TO OPEN IT YOURSELF. THESE THINGS STORE POWER SO YOU CAN BE ELECTROCUTED EVEN IF YOU UNPLUG IT.
Feb 02, 2011 | Computers & Internet
Beeping!!
Check the back of the UPS to see if the fuses/breakers are properly closed or open.
May 28, 2010 | APC Back-UPS ES 350 - UPS ( external ) -...
Overload Red button is on even after pressing reset button @ back
Try unplugging some equipment from the UPS. The total load should be less than 865 W. Printers and scanners often are culprits.Some gaming desktop computers can have a power supply that will be too much for this UPS. (I've found that even having the printer on the surge only part of the UPS can be a problem. I have the printer on a separate surge protector.)
Since the overload is new, did you add any equipment to the UPS recently or upgrade components?
If you reduce the load, and the problem continues, the UPS may have a fault in the circuitry. If it is under warranty, contact APC.
I hope this helps.
(I have replaced APC units after 3+ years when they can't properly recharge the battery - with a new battery. The symptoms are 1) getting a overload when a small load is on the UPS. Small load - desk lamp, 13" TV or 2) not keeping the item on when the power goes off.)
May 17, 2010 | APC 1500VA BX1500 8 Outlet UPS UPS System
House power fluctuates, UPS and computer die.
Sounds like the internal battery of the UPS needs replacement. Contact APC and ask for a qoute for a replacement battery/service. It'll probably work out a cheaper to buy new.
Make sure you dispose of the old unit properly if you do replace
Jul 07, 2009 | APC Back-UPS CS 500VA UPS System
APC back UPS 400 fails to give back up
I have the same problem with an apc smart-ups VS 650.
New batteries - charge in batteries is good (also tested under load).
When AC power fails, no power is supplied to PC connectors by the UPS.
UPS self test works fine. UPS does not report any problems via software - Power Management under Windows XP.
Oct 12, 2007 | APC Back-UPS 400VA (BK400) UPS System
Enterasys APC Smart-UPS 2200 XL (SU2200XLI) UPS System Logo
144 people viewed this question
Top Enterasys Computers & Internet Experts
George Nalley
Level 1 Expert
Marcin
Nathaniel Berrios
Nathaniel Berrios
Are you an Enterasys Computer and Internet Expert? Answer questions, earn points and help others
