Question about LG WM-2277HW Front Load Washer
Intermittant 'OE' error code
Repair man said he removed a piece of tape that was blocking the drain hose. The machine worked fine when he ran it through the sanitary cycle, but two days later the 'OE' error reappeared while doing a regular load.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 210 Answers
OE means it has not fully drained with in 10 minutes. Check your button trap and make sure nothing is there. If you want, make sure there is nothing in the unit and you can put it into test mode and check out to see if the drain pump is working.
Sgt 48
Posted on Jun 04, 2008
OE error please
There may be a few different reasons why the OE error code can display on your washing machine. Is it the LG washer getting the OE error code? The OE error code on the LG washing machine display is an indication of a NO DRAIN issue. The 3 issues that may cause this fault code is a bent drain hose, the drain pump filter is blocked, or the drain pump may have foreign objects lodged in it making it unable to drain. All these issues can cause your LG washer to display the error code OE. With all these different reasons, checking all 3 components will clear the error and fix your LG washing machine.
Oct 29, 2017 | Washing Machines
Wash cycle works ok but will not spin and oe appears in digital display then it switches off. We have just had drum and shaft and bearings replaced, repair man ran it then when we trid to use it it has...
This is what "OE" Means :
"OE" Drain error. Cause: not fully drained within 10 minutes Check there isn't a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge
Feb 09, 2011 | LG Washing Machines
OE error
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 09, 2010 | LG WM2233H Front Load Stacked Washer /...
My washing machine showing an OE error before end of cycle
OE error is noyhing but an Outlet Error.. OE simply means “the pump is blocked”. Clean and straighten the drain hose / clean the drain filter. Check the hoses (drain hose) and the pump filter but if it didn't cure the problem then turn the thing upside down and strip the pump out of it check if anything is caught in the impellor.. if so remove it and everything will be fine..
Jan 18, 2010 | LG WM-2277HW Front Load Washer
LG WM2277 "OE" ERROR. PLEASE HELP
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!
Jan 12, 2010 | LG WM-2277HW Front Load Washer
What does the error code OE mean on a LG dishwasher model number LD14At3?
OE drain Error Not fully drained out in spite of 5 min. drain operation The Drain Hose kinked or blocked. Wiring connection is OK? The drain outlet of sump is blocked. The Drain Pump/Motor or circuit is troubled...
Remove the cause of kink or block. Check the wiring connection. Measure the electric resistance of Drain Motor. (20-40 ) Replace the Drain Motor or repair the Circuit
Sep 22, 2009 | LG Dishwashers
Code OE
OE is a drain error
  1. The Drain Hose kinked or blocked.
  2. Wiring connection is OK?
  3. The drain outlet of sump is blocked.
  4. The Drain Pump/Motor or circuit is troubled.
  5. Remove the cause of kink or block.
  6. Check the wiring connection.
  7. Measure the electric resistance of Drain Motor. (20-40 )
  8. Replace the Drain Motor or repair the Circuit.
Sep 21, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
LG dishwasher with error code OE
Drain Error OE
Remove the cause of kink or block. Check the wiring connection. Measure the electric resistance of Drain Motor. (20-40 ) Replace the Drain Motor or repair the Circuit.
Sep 20, 2009 | LG Dishwashers
OE error code on LG front loader
The OE error code means:-
The Drain hose is kinked or blocked or the drain filter is blocked
Solution:-
Clean and straighten the drain hose and clean the drain filter
Nov 01, 2008 | LG WD-14124RD Front Load Washer / Dryer
Error code OE?
OE = drain hose blocked or clogged, or the drain filter is clogged
Dec 22, 2007 | LG WD-1080FD Front Load Washer
LG WM-2277HW Front Load Washer Logo
204 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
