Question about EdgeStar AP410HS Portable Air Conditioner
Getting an error E1 on my AP410HS Edgestar Portable Air Conditioner. I am being told by their tech support that I need to replace the circuit board. Do you have any instructions for replacing this board? Thank You Danny
  • 3074 Answers
SOURCE: What does E1 mean when it is showing up on a
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed
the instructions above EXACTLY.
Posted on Feb 27, 2011
SOURCE: Need circuit board for Maytag portable a/c unit
my portable a/c unit works but blows not so cold air what can i do to help it blow colder air
Posted on Jun 26, 2009
6ylucy
  • 742 Answers
SOURCE: boston innovative products MOB 10KDCHR portable
i found the user manual for it at:
manualfox.com/link/bostoninnovative.htm
Posted on Feb 13, 2010
aroracaty2
  • 503 Answers
SOURCE: We have a portable air conditioner. It keeps
panel.
button.
If you doubt the veracity of this information, or it does not work as
expected, you can get it directly from the source at:
1-800-237-4277
which is the Sharp customer service line. But, you'll need to call
between 7 AM and 7 PM US Central time, and have your model number and
serial number ready
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Posted on Jun 28, 2010
  • 51 Answers
SOURCE: Hello.. I am looking for the bottom squirrel Cage
If you take off the back filter panel, you can look down into the innerds of the unit and you will see the squirrel cage.
Posted on Jul 10, 2010
Keep getting code e1
According to page 24 of your owner's manual, the E1 error is indicative of a short circuit in the Indoor Air Thermistor. The unit will likely require service.
Good luck,
Marty
Jun 21, 2014 | LG Electronics LP0910WNR Portable Air...
How do I replace the exhaust fan on edgestart portable airconditioner AP12000S
I have an Edgestar AP 420HS and I need to replace the horizontal hamster wheel type exhaust fan that is rattling badly. I removed all screws and still can not remove the back of the unit. Two screws required a 7 inch long hex screw driver. Please post any information that may be helpful.
Aug 13, 2012 | EdgeStar Portable Air Conditioner Heater
My Edgestar AP410HS triggers the circuit breaker in the circuit box outside the house after it's been running a few minutes in air conditioner mode. This is new, it hasn't happened until a few days...
Breaker tripping likely from a loose or bad connection. Wire is getting over heated from not being tight. CAREFULLY INSPECT ALL CONNECTIONS. Including inside the disconnect box outside. Possibly even a bad breaker. HIGH VOLTAGE IS DANGEROUS , if even the slightest bit nervous, call a professional! Good Luck
Mar 29, 2017 | EdgeStar AP410HS Portable Air Conditioner
I getting a E7 code
Check the water resevoir and empty it. If its already empty check the level sensor.
Jun 23, 2010 | EdgeStar AP410HS Portable Air Conditioner
Stopped pumpin heat displays E7
Follow the link below to find the information about your unit. Also, if you can't find the information that you need then they will have a way to get you the tech support that is brand specific.
http://www.edgestar.com/support/portableac.htm
Mar 20, 2009 | EdgeStar AP410HS Portable Air Conditioner
THERE'S NOT A PROBLEM I NEED YOUR OPINION
This EdgeStar 10,000 BTU portable air conditioner heats and cools for year round comfort and is recommended for room sizes up to 350 square feet. This slim and light superstar uses the latest technology to squeeze the most powerful cooling from the smallest possible package this 10,000 BTU portable air conditioner has a footprint of just over a square foot and is under 28andquot high! This portable air conditioner is the most powerful portable air conditioner in its class and size range and can bring down mid size rooms faster than competitor's models.
Dec 27, 2008 | EdgeStar Portable Air Conditioner Heater
Edgestar 12,000 portale air conditioner and heater
There are 3 possibilities beginning with the most likely problem
1) If your heater heats up for a few minutes and then quits, chances are there is a blockage in the air flow, check for dust and grime blocking the air intake coarse filter , airgun blow to clear accumulated dust and otherwise clean the coarse filter .
2) If the heater fan blows but there is no warm air, the heating element needs renewal ( this happens very rarely)
3)If the fan stalls and the heater heats up and the thermostat kicks in, then this will be not be a DIY job. This is least likely as you said the air cooler works.
Apr 25, 2008 | EdgeStar Portable Air Conditioner Heater
EdgeStar AP410HS Portable Air Conditioner Logo
178 people viewed this question
Top EdgeStar Heating & Cooling Experts
Donni Steen
John Tripp
John Tripp
James Coghill
Are you an EdgeStar Heating and Cooling Expert? Answer questions, earn points and help others
