Question about LG Televison & Video
LG 52SX4D-UB DLP TV - tv tries to come on with the white lights scrolling from bottom to top and then the bulb light flashes 10 times and then the power light stays red - my question isit sounds like either the bulb or the ballast how can i check either one parts to determine if they are good or bad - i have component level experience but cant find a schematic to check the ballast (input/output voltage) Please Help! thanks, michael
  • phatcav Oct 14, 2010
    i dont belive the lamp even tries to light - lamp hasnt been replaced before and all fans run properly.. but tell me more about the ballast board what do you mean by "They Ck Big capaciotr on the Ballast board,alot of times when it is the lamp the ballast board has a spark cap on it that looks look a big Diode blue and white it will ark"
    thanks,
    michael
  • phatcav Oct 18, 2010
    i ordered a new lamp friday - hopefully that will fix it! thanks
  • 712 Answers
Checking the lamp in another working television would be the best way to identify whether it is the ballast or the bulb which is the source of the problem.
Cheers. Thank You.
Posted on Oct 16, 2010
  • LG Master
  • 5,138 Answers
If Lamp has never been replaced, Lamp will be the problem . Mats has them for $99.00 1-800-628-1118
First check all the Fans make sure they are running,if they are OK,They Ck Big capaciotr on the Ballast board,alot of times when it is the lamp the ballast board has a spark cap on it that looks look a big Diode blue and white it will ark.If Lamp trys to light and Lamp Fan Stops running then Lamp will not light means defective Lamp Fan.
Encompass Parts Distribution has Parts for this Model 1-800-638-3328 or Visit their website and type in your Model#.
Posted on Oct 14, 2010
  • ladywinn
    ladywinn Oct 14, 2010
    If the Big Capacitor or any capacitors are vented or puffed up on Top they are Bad.
  • ladywinn
    I would Replace the Lamp that should Fix your TV.
  • 4,889 Answers
If you want to test the ballast then you are gonna need the schematic which can be downloaded from the link below.
http://www.free-service-manuals.com/Television/LG_Televisions/LG_52SX4D-UB_Service_Manual_L26770/
The ballast has two DC out pins accross which you have to measure the voltage and compare it with the voltage in the service manual. Be careul. The ballast output voltages are usually in the range o 500V minimum and upto 1000V in certain models.
Posted on Oct 13, 2010
  • eagle338
    eagle338 Oct 18, 2010
    If the lamp is not coming on at all then its definitely a ballast issue. That is why I have told you to test the ballast. Why did you reject my solution without even testing it first?
  • 1,476 Answers
Michael c250,
I have fixed 100s of DLP projectors and have yet to see a bad ballast, but that does not mean yours couldn't be the first. More than likely from what you have descibed your lamp is bad. They have a limited number of hours, approx 6 to 8 thousand. Sounds like a lot until you do the math. Generally a lamp is done in about 6 years. In addition if your lamp light is flashing you definitely need a lamp.
I have a tip at http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv which explains the problem, how to identify the problem and how to remove and change the lamp as well as where to get the new one at the best price for the quality. If you remove the lamp and it is cloudy it is definitely bad. Follow the instructions in my tip and do not touch the lamp with your bare hands.
Thanks for using FixYa and for the great rating.
hardrocko
  • bobby caesar Jul 14, 2013
    hey kim am bobby caesar a member with fix ya i do have a problem with lg dlp tv model re-44sz21rd its color is greenish n i wanted to access the submenu as9883 in the ez main menu how do i activate the ad9883 cos its not highlighted in white as the other coices meaning when i scroll down to choose it the pointer skips it how do i go about it cos i have the ad9883 values to input?
Recently we replaced the bulb in our LG 52SX4D-UB. Once the bulb was installed we reset the hours for bulb according to the instructions that we reviewed on-line. Once the power button is pushed on the...
Tv goes off and on.It have alots of clicking noise sounds too?Yes.The board that call the Ballast board it is also dead too.The Ballast board only job it is to help to ignite the tv projection lamp.Tries websites like Partstore.com,Ebay.com to buy the Ballast board for the replacement.
Apr 03, 2011 | LG 52SX4D 52" HDTV
My LG projection tv (serial number 52sx4d-ub) won't turn on, an orange light flashes then turns red. How do I know if I need to change the bulb or the ballast? And how much does it cost to change the...
Orange blinking light under a small picture of a light bulb? Then turns to a red light?
Sounds like the same problem I had when I picked up my LG 52SZ8R. After replacing the lamp the TV ran fine.
Easiest way to see if the lamp is the problem is to take it out, and look at the peice of wire in the globe as you would an old light globe.
If you need help, download the following manual, and look at page 9.
http://www.jordansmanuals.com/ServiceManuals/LG/TV/PROJECTION/62SX4R/62SX4R%20Service%20Manual.pdf
If it does come down to you needing to replace the ballast contact: http://www.statewideapp.com.au/index.php?selectedContent=1188381775
They should be able to give you a quote and part number, if you don't like their quote you can always use the part number to search for one thats cheaper.
Mar 07, 2011 | LG 52SX4D 52" HDTV
LG 52SX4D turns off randomly.
My Lg 52"tv turn off and on
Apr 29, 2009 | Televison & Video
Lg 52sx4d not starting up
The flashing green bulb light means the access door for the bulb on the lower right side of the TV is open or loose. There are two screws that hold it in. If they are tight, maybe the interlock switch is bad or disconnected. Open the door, and hold in the little white interlock button while turning on the TV. If it still doesn't work, there are wires leading from the switch to a connector about halfway across the TV on the bottom. Connector might be loose. Unfortunately, it is hard to reach. You might have to remove the screws across the bottom rear edge that hold in the chassis and gently slide it out to reach the connector.
Mar 01, 2009 | LG 52SX4D 52" HDTV
How to reset after replacing bulb
mute on remote+ok on tv panel at the same time
Jan 24, 2009 | LG RU-52SZ30 52" Rear Projection...
Lg RU-52sz30 rear projection tv does not go on
I have an lg dlp projection tv Model # 52sx4d-ub.I replaced the bulb,everything correctly,but no picture. LG says I have to have a tech come out to reset? Can you help.
Jan 23, 2009 | LG RU-52SZ30 52" Rear Projection...
LG DLP not turning on
well i know what the problem is... if your getting the white scroll and then the red light flashes but the fans are comming on and you got a new bulb the broblem is the ballast. i know cuz i had the same problem and a good friend of mine has a tv shop and i had him look at it but the good news is that its not that hard to change. if you try to go through LG thay wont be able to sell you the ballast if your just a coust. good news is that you can fined the ballast on ebay from s.gifeasywaylamps its about $130.00 bucks shiped. bad news about is that thay are from china(it is where i got mine) but it works great and hasent gave me a broblem yet. if any one eles has the same problem and it was something eles.... PLEASE POST IT. i hope my info has been helpful to someone.... thanks Brad Ross of East Moline Illinois... you can email me at plopit40@yahoo.com
Nov 11, 2008 | LG 52SX4D 52" HDTV
Light bulb flashes 3 times, TV won't turn on
well i know what the problem is... if your getting the white scroll and then the red light flashes but the fans are comming on and you got a new bulb the broblem is the ballast. i know cuz i had the same problem and a good friend of mine has a tv shop and i had him look at it but the good news is that its not that hard to change. if you try to go through LG thay wont be able to sell you the ballast if your just a coust. good news is that you can fined the ballast on ebay from s.gifeasywaylamps its about $130.00 bucks shiped. bud news about is that thay are from china(it is where i got mine) but it works great and hasent gave me a broblem yet. if any one eles has the same problem and it was something eles.... PLEASE POST IT. i hope my info has been helpful to someone.... thanks Brad Ross of East Moline Illinois
Aug 30, 2008 | LG 52SX4D 52" HDTV
Lg 52sx4d problem
If the red light scrolls through, you need to replace the bulb. I replaced the my own bulb, and when I tried to turn on the tv the light kept scrolling. What was wrong? I DIDNT FULLY REASSEMBLE THE TV AFTER REPLACING THE BULB.
Make sure that all the screws are put back in and it will probably work if you have replaced the bulb.
May 14, 2008 | LG 52SX4D 52" HDTV
LG DLP 52SX4D/Will not power up
Ours did the same, it was the colour wheel in the tv, it was stuck [from dust and smoke] and the tv wouldn't go past that problem.
Jan 19, 2008 | LG 52SX4D 52" HDTV
Televison & Video Logo
719 people viewed this question
Computer Repairing
Computer Repairing
