Question about Miele Novotronic T240 Electric Dryer
Miele t494c start and then trip the fuse on main fuse box what is the problem
    New Friend:
Had exactly the same problem. First, I tried with changing the plug - worked ok, but wasn't really the right solution. Then, cleaned with a high pressure washer (like the one you wash your car with). The result: no more problems!
Good luck.
Posted on May 18, 2013
  • Sasha Bozarevski May 23, 2013
    I meant "cleaned the CONDENSER UNIT with a high . . . ."
4 Suggested Answers
SOURCE: I have a Miele dryer, model T494C. The system
It's most likely one of the heat/humidity sensor tubes that needs to be replaced. This has happened twice to my T494C in 12 years. Miele (or your dealer) will come out and replace it for a cost. Do NOT leave wet clothes (or semi-dry clothes) in the dryer for any length of time when the dryer is not operating. Apparently this is one of the problems.
Posted on Apr 16, 2010
  • 3 Answers
SOURCE: I have in indesit tumble dryer model
Hiya drodger, i had the same problem with my hotpoint dryer, (same company) if this is a condenser dryer make sure the drawer is collecting the water there is a small hole at the bottom of the drawer if you have a straw poke it in and clean it out, also at the back of the dryer there is a clear plastic pipe and a black one take them both off and clean them, your problem is exactly the same as mine so you will probably have to buy a new heating element (they are a lot cheaper from ebay) they are so easy to fit just 2 clips (i did it and im not dead yet!) hopefully you will then find the dryer will work perfectly, word of advice though clean the collecting drawer out at least once a month.
Hope this helps
Posted on Oct 04, 2009
  • 83 Answers
SOURCE: Dryer trips the fuse box
I had this problem with our hoover tumble dryer, it might sound stupid but i changed the plug and it worked ever since, ours blew 5 fuses and tripped out the main fuse every time
hope this helps martin
Posted on Jan 24, 2009
Miele washer does not power on at all
check the door switch or the mains fuse. they are both on the inside.
Feb 15, 2016 | Miele WT 2780 Front Load Washer
How do I open washing machine door
check mains going into mechine
Feb 27, 2015 | Miele Washing Machines
TRIPS FUSE IN MAIN HOUSE BOX
you may have to add a different fuse line in your box....PLEASE DONT ADD IT TO EXISTING FUSE LINE
Sep 23, 2014 | Zanussi Washing Machines
Miele WT945 dryer is no longer heating but is spinning. I've followed all the steps in ww1223's useful guide (http://www.fixya.com/support/r4177912-miele_wt945_dryer_problems_stage_stage) up to stage 3,...
Check your main breaker box...It might have tripped...If so I would assume your heating element has burned out....Its behind the unit under the metal....It's shaped round..Sometimes the medal support in Laddies bra's will com out and go through the holes and short the element out... Something to look at..
Oct 12, 2017 | Miele W320 Front Load Washer
Our miele condenser dryer with the miele washing machine will often trip the whole house's electricity. Sometimes it will trip on the house circuit board. while other times it trips the external trip...
have the neutral power connection on that circuit and back to the main house panel and then have the neutral connection checked at the power companies side also, it sounds like you have a high resistance neutral connection somewhere in the circuit and its looking for another return path due to the high resistance on the line to another feed circuit line to make connection
Dec 07, 2009 | Miele Novotronic T220 Electric Dryer
I have a Miele dryer, model T494C. The system starts rotate right then stops and when rotates left and immediatly the main relay of the house falls. After three days the dryer works fine. Is there...
Nov 23, 2009 | Miele Dryers
Miele Dryer heater bank
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Mar 21, 2008 | Miele Novotronic T220 Electric Dryer
Miele novotronic 510 keeps tripping fuses
Possibly the heater bank. Try running it on cool air, still same problem, then you will need to post more info. IE. Does it trip when you switch it on via the button?
Does it trip as soon as you press start?
Does it trip after a seconds of mins after you start it?
Feb 08, 2008 | Dryers
Miele Novotronic T240 Electric Dryer Logo
827 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
