Question about PfaFF Creative 7570
I need the base circuit board and synchronizer for my 7550. My local shop says they are no longer available. Is there any sosurce for parts for these machines?
2 Suggested Answers
SewExpress
  • 41 Answers
SOURCE: Pfaff 7550 synchronizer
Hi Britt,
Pfaff repair parts are only available to authorized Pfaff service technicians. You can locate your local dealer using Pfaff's Dealer Locator.
Hope you are able to get ***********'s machine up and running soon - not fun to be without!
Happy stitching,
Kim & Linnette
www.sewingexpressions.com
Posted on Nov 29, 2008
Bernina 150 circuit board - according to local shop my bernina 150 main circuit board has desceasesd. Please help me get find replacement
Bernina would probably be the best place to check. Next might be finding a donor machine with a good board.
Dec 05, 2016 | Bernina Sewing Machines
Trouble shooting a Singer Athena touchtronic 2000 Sewing machine I have a Singer Athena touchtronic 2000 Sewing machine. The light comes on but the needle will not move when you step on the foot pedal. ...
Yes it's true, most parts are not available for this machine anymore. You might try to push the red reset button on the bottom of the machine. Also make sure that the reset button is not being depressed by anything that the machine is sitting on, and that the reset button pushes in and out freelyl.
Apr 27, 2011 | Singer 3116 Simple
Have Viking 990 and feed dogs not working. Local repair man kept for over a month and then said it was the circuit board and that Viking no longer making circuit board for 990-- or, that machine can't be...
Is it that the feed dogs won't go up and down, or that you can't adjust the stitch length? If the feed dogs won't go up and down after you have released the feed dog button and cycled the handwheel one revolution, than there is a mechanical adjustment needed. I the stitch length can't be ajdusted, that It's either a circuit board of a step motor problem. The repair shop should be able to tell you that they swaped the feed motor with the zig zag motor to test this issue.
Apr 14, 2011 | Husqvarna Viking 1
My Pfaff 7570 will not run. Thought it was the foot pedal. Tried a new one which also didn't work. Changed the AA batteries.Display lights,but will not sew. Husband thinks it is some kind of...
Could be motor brushes or a bad base plate board circuit board. That is a great machine but may be hard to find someone to fix this problem. Take to only to a pfaff repair shop. Motor brushes should be around $50-100 repair and base plate could be up to $500. I would also check it with a nother foot control just to be safe.
If your husband wants to do the job here are some tips.
The motor is right behind the display board, you will need to remove the diplay and motor to get to the brushes.
For the base plate board, Remove the 4 large flatblade screws to get the base plate off.
Right next to the trasnformer there 3 small fuses, (they are back and say fuse on them) if one is very carroded and white there is a good chance that is bad and replacing it will fix the probem.
Lots of work for bolth if the repairs and I recomend you take your machine in.
Apr 03, 2011 | PfaFF Creative 7570
I need a replacement pedal for my Pfaff 7550 cd, or can I replace the variator with a potentiometer or similar?
NOOOO. Do not replace the variator with a potentiometer. You could cause a fire. You can get the pedal from any sewing shop or try:
http://www.sewingpartsonline.com/pfaff-sewing-machine-parts-model-list.aspx
I don't know this dealer. You could try Pfaff for a nearby parts supplier.www.pfaff.com/us
Mar 21, 2010 | Sewing Machines
\i have a viking 190 sewing machine..it was put
throw the machine away I had a riccar machine I had to throw away for the same reason I bought it used in 1983 and could not get it parts it needed
Dec 13, 2009 | Husqvarna Sewing Machines
Foot pedal doesn't work after replacing batteries
The circuit board has a very small fuse that could have blown. Your dealer will need to look at it. The older Pfaff computerized models like the 1471, 1473 and 1475 had a small fuse on the circuit board that could be replaced for considerably less than replacing the entire circuit board but I'm not sure if this is the case with the 7550.
Jul 24, 2009 | PfaFF Creative 7570
Hi Britt,
Happy stitching,
Kim & Linnette
Nov 22, 2008 | PfaFF Creative 7570
Bernina 1230, I think the pc board is bad
Where can I buy new circuit board for 1230 sewing machine Mary b
Sep 21, 2008 | Sewing Machines
Husqvarna Viking #1 blown fuse
You will most likely find that ALL of the "better" manufacturers; Bernina, Husqvarna, Pfaff, will not sell proprietary parts to non-brand dealers. Ultimately, this protects the customer.
With that being said, chances are the problem you are having is NOT a bad circuit board, but a bad power supply. But, since you don't trust your local dealers, find a dealer that is not so local. A two hour car ride is going be a lot cheaper that replacing the wrong part, and NO dealer will return your money on a part that the customer diagnosed as being faulty. I assure you, a Viking dealer somewhere will help you with your problem. You might want to try a Pfaff dealer. They can sometimes obtain Viking parts.
I would try replacing the power supply first. Its a cheaper priced part, and more likely your problem. Its also easier for DIY'ers, but extreme caution must be taken to ground yourself to the machine. Static is always a concern with electronic sewing machines, and even more so this time of year. Proper grounding equipment should be worn while performing any internal repair or adjustment in any electronic machine.
As far as replacing the circuit board yourself, if necessary, also be very careful when disconnecting and reconnecting wires. The connectors are very small and bend easily. Also, care should be taken when tightening screws. Overtightening can cause faults within the circuit board by cracking the solder paths or just plain break the board.
Dec 02, 2007 | Husqvarna Viking 1
Sewing Machines Logo
81 people viewed this question
Top PfaFF Sewing Machines Experts
SewTechWayne
SewTechWayne
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
