Question about PSC QuickScan 6000 Plus Handheld Barcode Scanner
Having trouble programming the scanner..I have the product guide but I am not sure of to set the scanner too..........
  • 922 Answers
I recommend that you first come up with a question to ask. Then go to the website of the manufacturer of the scanner. Search support for answers to your question. If you don't find them use the phone number or email address on the website to contact them.
Posted on Oct 12, 2010
My scanner is scanning but why it's not coming in system notepad while scan sound everything is ok fine?
Your scanner may be set/programmed for a mode other than "keyboard wedge". Scanners typically come with a quick start guide with multiple barcodes that you can scan to program the scanner for your particular needs.
If you are trying to scan into Notepad or other text application, you will want to make sure the scanner is in keyboard emulation/wedge mode, and if you want it to have a "return" or "tab" after the scanned barcode, you should have options for that also.
If you have a used scanner and do not have the quick start guide or manual, you will want to look it up and download it from the manufacturers website.
Mar 26, 2016 | Computers & Internet
Purchased a BC345crs. Having great trouble setting up. Should I return and get a more user friendly product or can I find more help than the manual?
There is not much of a more user friendly scanner. Maybe a local Radio Shack or similar store would program for you if you tell them what you want in there.
Jan 17, 2015 | Uniden Radio Communications
Have an online manual for LS4004 I000. How do I get the scanner to transmit an enter key after scanning a barcode?
try reprogrammimg, it should default after it scans an item to enter whaT WAS SCANNED
Jan 31, 2013 | Computers & Internet
I've got a all-in-one printer of HP LaserJet M1120 MFP. When I switch it on the screen shows "Scanner Error 20". And I cannot use the scan function. It can print when connected to computer. I've rea
Follow these steps to scan using HP software:Step one: Load the item to be scanned
  1. Make sure that the product is connected to the computer.
  2. Turn on the product.
  3. Load the item in the document feeder tray or on the scanner glass
Tip
Load the following items in the document feeder tray :
  • Single items
  • Items that are not easily damaged
  • Multipage, single sided items that you want to scan into one file
Load the following items on the scanner glass :
  • Single items
  • Items that are easily damaged, such as old documents and photos
  • Multipage, double sided items that you want to scan into one file
  • Option one: Document feeder tray
    1. Place the item into the document feeder tray. The printed side faces up and the top edge goes into the tray first.
    2. Adjust the width guides to fit the item.
  • Option two: Scanner glass
    1. Open the scanner lid.
    2. Place the item with the print side down on the scanner glass. For the correct position, see the engraved guide near the corner of the glass.
    3. Close the scanner lid.
Step two: Scan the item Use one of the following methods to open the HP scan window:
  • Double-click the HP scan icon (c02436443.gif ) on the Windows desktop. note.png NOTE:If you have more than one HP product installed, double-click the HP scan icon (c02436443.gif ) for the product you are scanning with.
  • Click Start (c01827528.gif ), click All Programs , click the HP folder, click the name of your HP product, and then click HP Scan .
Click the scan option for the item you are scanning. note.png NOTE:Depending on your HP product, you might not have all the following scan options available. c02448891.gif
Save as PDF Use this setting to scan text documents that are not editable. Use the Save as Editable Text (OCR) option to scan text that you can edit. c02448892.gif
Save as JPEG Use this setting to scan pictures and images.
Hope this information will be helpful.
Let me know.
Regard
Oct 29, 2011 | HP LaserJet M1120 MFP All-In-One Printer
I want to program my LS2208 Symbol following: ? Baud Rate ? 9600 ? No Parity ? 8 data bits and 1 stop bit ? A prefix character of the tilde (~) character ? A Carriage Return (CR) suffix character
In order to program the device please refer to the "Programming Reference" on the guide available on this link.
There are sample codes you can scan to set up the device as per your requirements listed above.
If this doesn't work for you, please comment and let me know, and I will be happy to assist you to further resolve your issue.
I will appreciate your feedback and positive rating for this solution.
Thank you.
Nov 03, 2010 | Symbol LS2208-7AZK0100S Handheld
When you connect the device works, it has power, b...
Have you properly programmed the scanner? Are you sure the codes you are scanning are readable and are programmed as active in the scanner? Is the scanner set up to communicate properly with your PC/other device? I'd review the User's Guide and follow their instructions. Here's a link to the guide. Choose the first User's Guide on the list. Good luck
http://www.honeywellaidc.com/Site.aspx/na/en/product_center/product_support/?category=5&product=297
May 21, 2010 | Metrologic Instruments 9520 Voyager
I have a symbol barcode scanner and want to program it so I
you will need to download the product reference guide from www.symbol.com . You will find it within the product manuals.
In that guide you will have the barcodes to program this scanner.
You will need the following:
Scan options.
Data - Suffix
TAB.
This will sort your problem. If you don't manage to do it, get back to me and i can find the barcodes and email them to you.
Apr 23, 2009 | Symbol LS2208 Handheld
Quickscan psc GP5385-need a program manual
You can download a manual (06656 User's Guide/Programming Guide) at the DataLogic site. They bought PSC in 2005.
http://www.scanning.datalogic.com/sitefiles/result.aspx?m=Product%20Manual&p=53XX&l=english&d=1&t=search&s=NonCurrent
Caps Lock settings are on pages 36 & 37.
Label_Guy
Oct 02, 2008 | PSC QS6000 Plus Handheld
Computers & Internet Logo
303 people viewed this question
Top PSC Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Jax Planet
Jax Planet
pkwc
Are you a PSC Computer and Internet Expert? Answer questions, earn points and help others
