Question about Sima SUR-20 LCD Touchscreen Remote Control
Need new 4 digit manufacturers codes
Need new 4 digit Pre-programmed codes for the SUR-20
I have the 4 digit codes. Let me know how to get them to you or post them here. Let me know if you figure out how to insert them into the SUR-20. When I press 2 digits, the Sima beeps like it is finished and goes back to remote control mode. Thanks.
Posted on Aug 16, 2008
I locked myself out. how do I reset the system so that I can access programing on the honeywell Lynx touch 7000.
If you power down the alarm panel completely, when you power it back up and press star and pound at the same time. You should see 20 if it worked. If it worked, press pound 20 to see the installer code. You are now in programming. If you want to change the program code press star 20 and enter a 4 digit code and that will be the new program code. Press star 99 to get out of programming and your done
Sep 29, 2014 | Home Security
Trying to get installer code on Honeywell Vista 15-P
hit *20 then put in whatever 4 digits you want as installer code. write this down on your program sheet for future reference. yes, you should have a program record sheet to follow and know how to navigate in programming or else you could make things worse.
Jun 29, 2012 | Honeywell Ademco 6160 Alpha Keypad Vista...
What are the 4 buttons on the front of Servis Washing machine M6500W
hi i have the manual in front of me and reading left to right the buttons are
1. wash plus - the washing machine is programmed to provide the most efficient wash however if you want to extend the wash period press this button to extend the wash by approx 20 mins
2. pre-wash - press to perform a pre wash in the cycle (can only be used on cotton and synthetics programs)
3. no spin - eliminates the spin speed, program will simply wash and drain
4. start - dont think this one needs an explanation!
Oct 23, 2011 | Washing Machines
Hello i have a problem with my nokia 3110c whitch is : when i flash my phone with phoenix i got this result : Flashing started Creating product data items list Product data items list created Backup...
Now what is the condition of the phone ? If the phone has still problem, uninstall the previous file you have installed and re-install this one3110c file.Select the product code 0544311 or 0556977.This two files can use universal.Use fully charge battery or insert charger when message prompt.I hope there will be no error.Thanks good luck.
Aug 16, 2011 | Nokia N70 Cellular Phone
Is there a way to setup my universal remote for my dell 2400mp dlp projector? if so what is the 4 digit code?
You need a learning remote as most "universal" remotes don't have the codes pre-programmed for projectors. The Logitech Harmony is worth it's weight in gold, and it looks cool, but will set you back about $100. There are cheaper learning remotes, and they may suit your purpose better, look on New Egg and Ebay.
Jul 02, 2011 | Dell 2400MP DLP Projector
What is the comcast cable code for this tv for the digital box
Hello
Comcast remote codes for Emerson TV are:-
10154, 10451, 10236, 10463, 10180, 10178, 10171, 11963, 11928, 11913, 11911, 11909, 11905, 11665, 10282, 10280 10270, 10183, 10181, 10179 10177, 10038, 10019
You have to check with each code, until you find which code sets for your TV
programming TVcontrol
The Comcast Digital Adapter remote control is pre-programmed at the factory to operate the Digital Adapter. The Comcast Digital Adapter remote also contains a universal TV library to allow you to control the Power and Volume of your TV.
1. Turn on the TV
NOTE: Please read steps 2 to 4 completely before proceeding. Highlight or write down the codes and device you wish to program before moving on to step 2.
2. Press and hold SETuntil the Red Light blinks twice, then release SET.
3. Locate the code for your device in Manufacturer's Codes on the back of this user guide. Brands are listed in alphabetical order with the most popular codes listed first.
4. Enter the first five-digit code for your TV. If you perform this procedure correctly, the Red Light will blink twice
NOTE: If you enter an invalid code, the red light will display one long blink and exit the programming mode. Repeat steps 2 to 5 with a valid code.
5. Aim the remote control at your TV and press Power once. The device should turn off. If it does not respond, repeat steps 2 to 4, trying each code listed for your brand until you find one that works. If it still does not work, try Searching For Your Code.
If your brand of TV does not respond to the remote control after trying all of the codes listed, or if your brand is not listed at all, try searching for your code.
1. Turn on your TV.
3. Enter in 9 - 9 - 1. The Red Light will blink twice.
4. While pointing the remote control at the TV and press and release the CH + key until the TV turns off. (Note: You may need to press [CH+] numerous times).
NOTE: In the search mode, the remote control will send IR codes from its library to the TV.
5. Press SETonce to lock in the code. The Red Light will blink twice.
OK.
Dec 03, 2010 | Emerson EWC1303 13 in. TV/VCR Combo
How to set up th ebatteries in my sentry safe DSW5781?
Locksmiths agree
1. Remove and discard the screw (if
equipped) at the base of the lock case.
2. Turn the electronic lock case to the
right (clockwise), from 12 o’clock to
2 o’clock, and remove.
• Insert 4 new AA batteries (not included) to power
this lock.
• Replace the electronic lock case and turn to the
left (to 12 o’clock) to reassemble.
NOTE: The yellow LED will light when the batteries
need to be replaced.
3. Turn the key (if your safe is equipped with a key
lock) to the right so the lock cylinder pops out.
4. Enter the factory code. When the green light appears, you
have four seconds to turn the handle down to
open. Try this several times before proceeding to
the next step.
To unlock safe:
Enter the 5-digit factory code, a pre-programmed
user code, or a pre-programmed user pin
programming instructions. When the
green LED lights you have 4 seconds to turn the
handle and open the safe.
To lock safe:
Close the door and return the handle to the
horizontal position. For greatest security, depress
the key lock (if equipped) with your finger.
Aug 15, 2010 | Sentry Fireproof Safe
Anyone know how to use and program a SIMA universal remote SUR-20?
On the philips universal remote, i just hit code search til light was steady, then hit tv, and hit channel up til it found the freQ then hit ok! problem solved. But my sima remote! it is touch screen and contols everything but the WIFE! i cant find any codes online for my electronics, and it is a fancy bugger model # SUR-20 AND HAS A Batch # as well 8188 its made in taiwan, and im thinking about shipping it back to them, along with a grenade! LOL
Feb 04, 2010 | Philips Magnavox Learning Universal Remote
I need to program the Fisher Price Inerac tv to the dvd and or the tv so I need the instructins on how to I lost the and the dvd it was programed to is broke, can you help it is about 7 years old. it says...
spacer.gifThe following steps will allow you to program your InteracTV controller:
  1. Make sure the InteracTV controller has good batteries. Slide the 3 position memory switch, on the back of the controller, to the desired memory position. The controller is capable of being setup for up to 3 different DVD players in 3 different locations.The controller must be setup and tested individually for each of the 3 DVD players, but once that is done the controller will retain the manufacturer's code and does not need to be setup again.If the consumer accidentally enters a new valid 4-digit manufacturer’s code, then they must set it up again for that DVD player.It is a good idea to write the 4-digit manufacturer’s code in the labeling area provided on the back of the controller.
  2. Insert the compilation DVD into the DVD player and turn on the DVD player and TV.
  3. Insert the programming card into the controller; the green light should blink twice.
  4. Locate the manufacturer’s codes in the user’s manual.
  5. Enter the first 4 digit code listed under the manufacturer. Use the right arrow button for the number. The light should blink after each button press and blink a long blink after the 4th digit is entered.
  6. Remove the programming card.The light should double blink when the card is removed
  7. Insert the test card into the unit;the green light should double blink.
  8. The DVD should skip to the test screen, if it does not, repeat from step 3, choosing the next manufacturer’s code on the list. If the test card skips to the footage, which resembles the test card, then proceed with testing the unit.See Testing the unit section of you manual or quick setup instructions.
  9. If you have tried all of the manufacturer's codes listed and you cannot locate an acceptable code, see programming the unit using manual search in your user's manual.
You also might want to check this site for full product support:
http://service.mattel.com/us/product_detail.asp?id=B9376&Ntt=B9376&Pn=1&Brand=Technical+Products&Cat=InteracTV
Hope it helped.
Nov 15, 2009 | Video Game Consoles & Games
Magnavox 15MF400T/37 Channel chosen is not correct channel
Check the instrucitons to verify if the channel table is pre-setable to designate your own numbers.
Most TV sets have an autoprogramming for the channels. Look in the menu for the auto programming and let the set re-program the channels if your set has that option. This feature will re-program the channals, and re-set their defaults.
If the channels are not able to be pre-setable to a custom table, then this indicates that there is a pre-scaling fault in the tuner or in the uPC. In this case, the set will need service.
Jerry G.
Mar 25, 2008 | Philips Magnavox 15MF400T 15 in. LCD...
Sima SUR-20 LCD Touchscreen Remote Control Logo
293 people viewed this question
Top Sima Televison & Video Experts
Electro Med Services...
Are you a Sima Televison and Video Expert? Answer questions, earn points and help others
