Question about HP Computers & Internet
I do not succeed in starting it. It runs and runs, but never starts.
  • PortCaptain Oct 12, 2010
    It is an HP laptop, that had the screen ruined and I am using it connected with a big screen.
    The brand is HP Pavillion dv2500 and has VISTA installed. Do you need the VISTA product key?
    Best Tito Mazza
  • 2,427 Answers
Hmm seems like u got a driver crash..
turn off and turn on the system
keep pressing f8 (as soon as you turn it on)
in the menu that appears select safe mode and hit enter (use the keyboard)
now click no to use system restore (after it boots it will ask you)
follow the onscreen instructions to restore your computer to a few days back when it did work..
u should be fine now..
Posted on Oct 13, 2010
    President:
  • 4,070 Answers
Hi! Do you have an HP laptop or desktop? Please write back for I may help you on this matter. Thanks!
Posted on Oct 12, 2010
How do I fix a 1999 Chevy Blazer to get it running?
Start with spark and fuel/ pressure. Then good battery. Proceed from there.
Jan 01, 2016 | 1999 Chevrolet Blazer
My acer aspire one turns on, goes to the "were sry windows didnt start right" screen and regardless of which way i try to start it it flashes a blue screen really quick and reboots back to the "were s
You will need to run the recovery disk that you were advised to make when you first started using the laptop. This will re-install Windows form the System reserved area of your HDD.
Dec 16, 2012 | Acer Aspire One Netbook 8.9" Notebook
Hello i have a problem with my nokia 3110c whitch is : when i flash my phone with phoenix i got this result : Flashing started Creating product data items list Product data items list created Backup...
Now what is the condition of the phone ? If the phone has still problem, uninstall the previous file you have installed and re-install this one3110c file.Select the product code 0544311 or 0556977.This two files can use universal.Use fully charge battery or insert charger when message prompt.I hope there will be no error.Thanks good luck.
Aug 16, 2011 | Nokia N70 Cellular Phone
Cant download skype, problem with toolbar, error 2738
Take a look in Event Viewer I looked in Event Viewer to find out what MSI-file that generated the error message and found:
Log Name: Application
Source: MsiInstaller
Date: 23.09.2010 21:58:26
Event ID: 1040
Description:
Beginning a Windows Installer transaction: C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}\SkypeToolbars.msi. Client Process Id: 6564.
2. Running MSIEXEC with logging options I started a "Command Promt" and used the command: "cd C:\ProgramData\Skype\{D103C4BA-F905-437A-8049-DB24763BBE36}" to navigate into the folder containing the MSI-file.
Now using the command: "msiexec /i SkypeToolbars.msi /lv log.txt" (msiexec options: /i = Install, /lv = Log + Verbose output).
After clicking away the error message I just wrote "log.txt" in my "Command Promt" to open the log-file. Near the bottom of the log-file I found this line:
DEBUG: Error 2738: Could not access VBScript runtime for custom action
3. DEBUG: Error 2738 After a quick search at Google I found out this error indicates that the VBScript engine is not registered on the computer.
The solution for a Windows Vista or Windows 7 32bit:
- Click Start -> All Programs -> Accessories
- Right click "Command Promt" and click on "Run as administrator"
- Write "cd %windir%\system32" and hit Enter
- Write "regsvr32.exe vbscript.dll" and hit Enter
- You should now get a message that says: "DllRegisterServer in vbscript.dll succeeded."
- Click "OK"
The solution for a Windows Vista or Windows 7 64bit:
- Write "cd %windir%\syswow64" and hit Enter
- Click "OK"
4. Try again... Now I tried once more to run "msiexec /i SkypeToolbars.msi /lv log.txt" (I kept the /lv log.txt option to look for changes if the installer would fail again).
If you still get the same Error than continue to step 5.
5. Cleanup registry first, then re-reg My installation still gave me the same error, so after some more searching and reading on Google I found a solution that explained what I tried before (with the regsvr32.exe) and also an alternative step if that one should fail. The alternative step was to remove the Registry Key pointing to vbscript.dll.
The alternative solution for a Windows Vista or Windows 7 32bit is then:
- Write "reg delete "HKCU\SOFTWARE\Classes\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Click "OK"
The alternative solution for a Windows Vista or Windows 7 64bit:
- Write "reg delete "HKCU\SOFTWARE\Classes\Wow6432Node\CLSID\{B54F3741-5B07-11CF-A4B0-00AA004A55E8}" /f" and hit Enter
- Write "cd %windir%\ syswow64" and hit Enter
- Click "OK"
Now using the command "msiexec /i SkypeToolbars.msi /lv log.txt" the installer started perfectly, ran all the way thru and Finished.
Conclusion This message indicates that VBScript engine is not currently registered on the Computer running the installer.
Vbscript.dll must get registered to solve the problem.
Ref: http://community.spiceworks.com/how_to/show/1577
Apr 25, 2011 | Computers & Internet
My msn doesnt work error code 80040154
Error: 80040111 or 80040154 If you are receiving the error 80040111 or 80040154 when you sign into Messenger, please try the following: 1. Reregister msxml3.dll. To do so follow the steps below that are applicable to your operating system version: 1.a.Windows Vista:
1.a.i. Click "Start," click "All Programs," click "Accessories," and then right-click "Command Prompt." 1.a.ii. Click "Run as administrator." 1.a.iii. If you are prompted for an administrator password or for a confirmation, type the password or click "Continue." 1.a.iv. Type the following command, and then press ENTER:
REGSVR32 %windir%\system32\msxml3.dll 1.a.v. If the file can be located and is available, you receive the following message:
DllRegisterServer succeeded in C:\Windows\System32\msxml3.dll is succeeded. 1.a.vi. If this step is not successful, go to step 2. 1.a.vii. If this step succeeds, go to step 3.
1.b. Windows XP:
1.b.i. Click "Start," click "Run," type the following command, and then click "OK":
REGSVR32 %windir%\system32\msxml3.dll 1.b.ii. If the file can be located and is available, you receive the following message:
"DllRegisterServer succeeded in C:\Windows\System32\msxml3.dll is succeeded."
1.b.iii.If this step is not successful, go to the next step.
1.b.iv. If this step succeeds, go to step 3. 2. Reinstall MSXML3. To do so, follow the steps below:
2.a. Visit this Microsoft Web site.
2.b. Click the "msxml3.msi" link near the bottom of the page, and then follow the wizard to complete the installation. 3. Restart the computer, and then sign in to Windows Live Messenger again.
Dec 21, 2010 | Microsoft MSN Messenger Connect Service
My messenger wont let me sign in cause it says that i have an error..... error info:8e5e0152 please help me!
1.b. Windows XP:
Oct 16, 2009 | Microsoft Windows Live Messanger
The network connections folder was unable to retrieve the list of network adapters
Goto Start --> Run and type (1 line at a time and don't forget to press enter or the [OK] button for each line):
regsvr32 netshell.dll
regsvr32 netcfgx.dll
regsvr32 netman.dll
After each line you should get a popup stating something like "DllRegisterServer in <file> succeeded", if not, please post the error message here. When all succeeded, reboot and check the "network connections folder", the error message should be gone now ...
Aug 16, 2009 | Computers & Internet
Problems creating an account
Hello acrosbyabc...If you are getting an internet exlplore script error..
You can try the following.
Open IE (Internet Explorer)
Go to Tools then select Internet Options
Go to Advanced tab
Tick Disable Script debugging (other)
Tick Disable Script debugging (internet explorer)
Press Apply then click OK
or..
1. Go to the Start menu and choose "Run..."
2. Type "regsvr32 actxprxy.dll" and click "OK." You should see some text that reads "DllRegisterServer in actxprxy.dll succeeded".
3. Now go to the Start menu again and choose "Run..."
4. Type "regsvr32 shdocvw.dll" and click "OK." You should now see some text that reads "DllRegisterServer in shdocvw.dll succeeded".
5. Restart your computer....
Also you can try useing another browser...like Firefox.
Good luck..i hope this helps, please rate me a fixya.
Aug 01, 2009 | Acer Aspire One A150-1006 Notebook
Error code 80040154
1.b. Windows XP:
1.b.iv. If this step succeeds, go to step 3. messenger-support.spaces.live.com/mmm2007-10-25_18.59/'%3EKorean%3C/A%3E% 2. Reinstall MSXML3. To do so follow the steps below:
2.b. Click the "msxml3.msi" link near the bottom of the page, and then follow the wizard to complete the installation. 3. Restart the computer, and then sign in to Messenger again.
Mar 17, 2009 | Microsoft Windows Live Messanger
Computers & Internet Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
